Like Tree2Likes
Old 02-19-2017, 12:51 PM   #526
0verkill's Avatar
Which compound do you guys like on the BSR foams?
0verkill is offline   Reply With Quote
Old 02-19-2017, 02:04 PM   #527
Depends on the road. 1/8 BSR 35 and 40 shores have not worked well at all at my new road.
tc4basher is offline   Reply With Quote
Old 02-19-2017, 06:09 PM   #528
I sent him an Email. Waiting to hear back from John at BSR. Banana Racing Skinz just said he is waiting for his High Speed foam to come in.
Gunner1 is offline   Reply With Quote
Old 02-20-2017, 06:37 AM   #529
his new tires will have natural rubber in fused in the foam
long island rc is offline   Reply With Quote
Old 02-22-2017, 12:40 AM   #530
https://youtu.be/LBzRwM4HYHg
New 808 WR,she has a lil more left in her,lol!
MallenP30 is offline   Reply With Quote
Old 02-22-2017, 12:49 AM   #531
Team Purple is what I use and was specifically designed for speed runs! The XX-Pink are good as well, JuSt a bit softerough! Also foams can be a little tricky, you may have to play with tge suspension a little bit to get them to hook up!
Old 02-22-2017, 08:32 PM   #532
I saw this the other day. I have you sub'd on You Tube. Congrats on a new record.
Old 02-23-2017, 07:26 AM   #533
Thanks bro!
Old 03-02-2017, 07:25 PM   #534
phildoggg's Avatar
Trader Rating: 24 (100%+)
163mph with slash through traps.
https://www.youtube.com/watch?v=nVoH4uv6d2k&t=4s
phildoggg is offline   Reply With Quote
Old 03-02-2017, 07:26 PM   #535
fdjizm's Avatar
Jesus christ!
fdjizm is offline   Reply With Quote
Old 03-02-2017, 11:08 PM   #536
I saw that one Phil. You guys are smoking
Old 03-04-2017, 01:33 PM   #537
fdjizm's Avatar
Well... unsupervised on the internet again...
4070-CM 3210kv
Old 03-04-2017, 05:57 PM   #538
6S motor? 4.2 x 6 = 25.2 x 3200 = 80,640. A bit over the 75K limit.
Old 03-04-2017, 07:58 PM   #539
fdjizm's Avatar
Yes, 6s motor as per TP power.
It's never going to see that voltage or RPM.
On a real run (load in a 10lb car) I'm probably seeing 20-21 volts, I don't see it passing 65k.
Old 03-05-2017, 09:13 AM   #540
Ahhh I'm still learning electric. Lots different than gasoline.
