Go Back  R/C Tech Forums > General Forums > Racing Forum
Speed Run Electric (All Classes Welcomed) >
Like Tree3Likes
Old 07-08-2016, 08:43 AM
  #316
1spunspur's Avatar
Originally Posted by RepEvox
It can't for prolonged periods of time. There's nothing stopping you from running a 540 can on 8s either, but you can imagine the rotor disintegrating. I destroyed my 2200kv motor on 6s though because it was approaching 54k rpm under load. 60k is the rating for most of these motors.
Just wondering where you got this information?
1spunspur is offline
Old 07-08-2016, 09:20 AM
  #317
Originally Posted by stick
didn't realize the 2200kv could handle 8s.
You have to be very careful. Motor temps were very high at 168+°F after the pass!
tc4basher is offline
Old 07-08-2016, 09:36 AM
  #318
Trader Rating: 14 (100%+)
I'm sure you know of the RPM max ratings. They're displayed on the back of Castle creations cans. 2200 x 25.6v ~ 56000 rpm, but I was seeing lower RPM numbers according to the data logging feature on my MMX which makes sense under load.
Faster spinning motors always have lower LiPo cell ratings due to the 60k or 50k rating. A 5600kv motor for example is probably limited to 3s. You could pump 36v into a can not designed for it which speedrunners do already. These Castle 1/8 motors aren't rated for 8s, but there's nothing stopping you from using it with a 8s+ capable speed control, obviously.
RepEvox is offline
Old 07-08-2016, 09:42 AM
  #319
1spunspur's Avatar
No, I didn't know this. Thanks for the info.
Old 07-14-2016, 04:30 AM
  #320
XLX is finally fixed, haven't had the chance to get a full run in with it but I did mess around in front of my house and from what I can tell they definitely fixed the power issue , Just not sure if the overtemp is going to be an issue like it is with the MMX, I'll have to get a full run in before knowing that
MallenP30 is offline
Old 07-14-2016, 09:08 AM
  #321
Thanks for the info. I will definitely dust mine off and try it again soon.
Old 07-16-2016, 01:01 PM
  #322
phildoggg's Avatar
Trader Rating: 24 (100%+)
My latest pass on the Evul empire motor, if you havent heard of them check it out. motor makes power and runs cool.. hit 142 on 7s. comment like subscribe
https://youtu.be/lLG0V22loLE
phildoggg is offline
Old 07-17-2016, 06:24 PM
  #323
Trader Rating: 16 (100%+)
That 4290 2200kv motor is nasty... just put myself on the waiting list... Thanks for the heads up on Evul
Lanky is offline
Old 07-18-2016, 04:56 AM
  #324
What are the specs on this motor? Shows nothing on their site!
Old 07-18-2016, 11:07 AM
  #325
Here.
Funny, I just looked at those the other day and they were in stock...
RepEvox is offline
Old 07-18-2016, 12:55 PM
  #326
Here.
Yea I've been here, still says nothing as far as max watts, voltage, RPM, or even dimensions
Old 07-18-2016, 05:33 PM
  #327
phildoggg's Avatar
I'm not sure on the wattage its rated at 60k rpm. great motors for the price. def worth a look.. This was a motor loaned to me to use. checkk out the site or contact Micheal Behanna on FB.
Old 07-31-2016, 05:41 AM
  #328
phildoggg's Avatar
Worlds fastest Arrma Typhon 132mph pass.
https://www.youtube.com/watch?v=ij-LEGomP_k
Old 08-02-2016, 03:10 PM
  #329
Very nice phildoggg!
Old 08-04-2016, 06:05 PM
  #330
phildoggg's Avatar
Thanks pete. why you quit posting your runs?
