Like Tree1Likes
Old 03-21-2016, 02:00 PM   #166
1spunspur's Avatar
Originally Posted by tc4basher View Post
Castle's 5700kv 4 pole on 4s is pretty reliable and runs fairly cool and is capable of MPH's in the 120's in a 1/10 scale.
Thanks, you think a 120 amp ESC would handle that?
P./
1spunspur is offline   Reply With Quote
Old 03-21-2016, 02:09 PM   #167
1spunspur's Avatar
Originally Posted by stick View Post
I don't think it would be safe running 4s in a motor that can only handle 2 or 3s. overheating, among other things, would be your enemy.
Thanks stick, that was pretty much my concern, HEAT. I've been seeing some motors being advertised as 1s/2s motors. I don't have the money to waste on unnecessary melt downs. I'm not sure what I'm going to do yet. I'm definitely going to look into that Castle mentioned above.
P./
Old 03-21-2016, 06:10 PM   #168
Yup 120a esc is perfect for a Castle 5700kv on 4s. I ran mine with a mamba monster 2 which is 120a and the esc never broke a sweat. Get a good heatsink and fan for the motor and maybe even the esc and check motor temps every pass or 2. If you cant touch the motor for 3-5 seconds, let it sit and cool with the fans blowing.
tc4basher is offline   Reply With Quote
Old 03-31-2016, 06:34 AM   #169
Default Mugen mgt7 8S build
What's up fellas, as the title states I'm working on a mugen mgt7 eco build, just got the kit and in the process of building it! It's going to be an 8S setup, mamba xlx with Poseidon 1700kv! I just wanted to introduce myself and ask for any input at all as far as gearing goes, obviously I'm going to be running at least 1:1 ratio, just wondering if there's any mods necessary to do so and if so what! Also are there any bodies like the Serpent 977e body available for the mgt7? Abby info would be greatly appreciated! Thanks, Mike
MallenP30 is offline   Reply With Quote
Old 03-31-2016, 04:39 PM   #170
phildoggg's Avatar
Trader Rating: 24 (100%+)
TC4 basher is the mugen master with worlds fastest..
phildoggg is offline   Reply With Quote
Old 04-01-2016, 02:17 AM   #171
True....
Old 04-01-2016, 02:24 AM   #172
Hope you have better luck with the XLX than I did. This esc seems to have been severely detuned in hopes of less failures I'm guessing. Didnt make any power for me. Castle tech support won't even admit anything is wrong or respond to my emails after they told me to send them my data logs.
As for bodies, Deltaplastikusa has tons of nice speed run bodies for 1/8 GT cars.
Old 04-02-2016, 06:22 AM   #173
thats good info to know and I understand that the 3800 can run 100mph too
stick is offline   Reply With Quote
Old 04-02-2016, 12:46 PM   #174
Yes. With enough gear and voltage a 3800kv is capable.
Old 04-03-2016, 12:53 PM   #175
By any chance did you run into any ESC fires with the XLX? I was looking into and someone was saying they had to return theirs because of a fire when running it on an 8S setup.
drivejumpfly is offline   Reply With Quote
Old 04-03-2016, 09:03 PM   #176
forgot to mention that 3800kv would be on 3s.
between the two, 3800 or 5700, which one to hit 100mph on 3s.
have you seen anyone run that fast on 3s?
Old 04-05-2016, 08:46 AM   #177
Yea we'll see how it goes, I just need to get it up and running first, trying to get this spool together
Old 04-05-2016, 06:27 PM   #178
phildoggg's Avatar
I would use the 5700 on 3s but the 3800 would do 100 also with good gearing.
Old 04-08-2016, 12:21 PM   #179
The GT2 VE is a solid car. I have had mine up to 126 mph. But I have had major problems with center dogbones/universal shafts popping out and bending during speed runs. It has happened at least 5 to 6 times. Its come to a point that I am afraid to do speed runs because of this issue.
Where can I find a motor mount for a gt2 that accepts large pinions? Thanks in advance
chrisgtoth is offline   Reply With Quote
Old 04-08-2016, 03:39 PM   #180
Ebay for like $40
