Gearing for Carpet WGT Racing
Looking for help with a good gearing and rollout setup for my Xray X10 pan car on an indoor medium size high bite carpet track. Currently running avg 12-13 second laps with a pretty solid setup.
I have calculated a few pinion options based on the foams @ 52.5mm and 88 spur with the Team Powers 13.5 motor.
41 Pinion = 77.03 Rollout
39 Pinion = 73.26 Rollout
37 Pinion = 69.55 Rollout
35 Pinion = 65.67 Rollout
1. The larger pinion and more rollout produces more low end punch, correct? (Haven't noticed much power difference here at full timing)
2. Anyone running this same class and type of carpet track with the new 1S Trinity short stack 13.5 motor?
3. Any feedback on other 13.5 motors to be considered for this scenario?
Thanks!
Thanks!
Team Powers is a good motor, just stick with it. A track that size, you probably want to be more up in the 80s on rollout. Try max timing and 85mm and watch your temps.
Any weight to certified vs non-certified motors?
Lower rollout will give better acceleration out of the slow corners. Higher rollout gives more top speed. As usual, the gearing will be a compromise between the two. Start with the values wingracer mentioned and change from there for best lap time or to restrict the motor temperature.
I am running the Serpent S100 with a trinity 1s but D4 motor, on a track that sounds similar to yours. I am now running 88/40 at 50deg of timing. Car has great punch, and decent top end. I actually may go back to 88/42 to get my top end back. I started there, but felt I was lacking in the infield, but my times went up cause the car was too fast for me and I wasnt able to be as smooth through the infield. In short, 88/40-44 should work, try each and see what you like. I have a Team Powers motor and this gearing works for that motor also.
If it is within the budget, certified is the way to go, especially in a spec class. Every little bit helps...I run certified motors in my TC and vowed never to go back to non-certified unless a mfr doesnt offer it. I am trying to build my inventory where I can then do my own certification, where out of the 3 or 4 motors i have, I will measure the stators and rotors and put the best parts together from the cert motors I own. If you like the D4, wait till you run a D4 built by EA or Fantom racing...they build some wickedly fast D4 motors...
We have been all around this planet before. The answer on rollout is "it depends". Electric motors produce peak torque at stall and very little torque at full rpm. The peak power seems to be half way in between. You can decrease your acceleration by having to low of a rollout or to high. I have run WGT a long time and with most motors I hit 81mm rollout and adjust the timing to temp. This applied to D3, D3.5, Revtech and TSR. Our track is built in a 90x40 box (that is feet). I have been to other tracks that have different dimensions (all inside) and the rollout still stays pretty much between 77 and 83. When tuning rotors are an option I stick with a lower strength model. In Trinity it was the purple which was 12.3 and medium strength. All of this is for blinky mode.
Garrett, I am running a 43/88 on 51mm tires with 30deg timing and mine is very fast and has a lot of punch. But I am using a Thunder Power motor. I put 2 laps on the field Saturday with that.
Just run 6 minute runs in practice, note the times, temperature of the motor, timing etc., then change the gearing and/or timing and do it again, see which way gets you turning faster laps overall on average. Start writing it all down and you will see the patterns come to light.
Are you racing with us Saturday night? We should be running WGT again in prep for the races next weekend.
