Old 09-01-2015, 02:56 AM   #76
scoyle's Avatar
Originally Posted by NR View Post
Hi Guys
Got mine today, not having much luck with pairing with an IPhone 6+ it doesn't seem to find it in Bluetooth.
Anyone else using it with a 6+ or had any issues?
I use a 6+ with mine no problem at all... No idea what else you can check other than Bluetooth is on and you have put in the code on the back of the device correctly?
scoyle is offline   Reply With Quote
Old 09-01-2015, 04:02 AM   #77
Skiddins's Avatar
Hi Guys
Have you tried putting the box's serial number in in the app's settings, then get the app to do the bluetooth connecting for you.
If you search for the box using the iphone's Bluetooth settings it won't find it.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 09-01-2015, 05:32 AM   #78
NR
NR's Avatar
Trader Rating: 52 (100%+)
This might explain why I'm having issues
I did put the serial number in, however not sure how to get the app to do the bluetooth?
NR is offline   Reply With Quote
Old 09-01-2015, 06:20 AM   #79
Skiddins's Avatar
Turn on the bluetooth in the phone settings, then in the app, under the lap timer section, click the 'Auto' slider at the top.
Then a screen will appear with an option to 'Connect to PocketPt', click this and it should find the box very quickly.
You'll need to connect to the box each time you start the app.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 09-01-2015, 07:10 AM   #80
sakadachi's Avatar
Is there a retailer in the US that sells these? I checked around but could not locate one..
4PKS-R, DX4S, EX-5UR: Sabre4WD Mini, SabreFD Mini, M01, M02, M03, M04, M05 (2), M05ProV2, TA05 M-Four, CupRacer, BSR M-Rage, WR02, GF01 (2), CC01 (2), CW01, CR01, DF02, TT02B, TA02, RS4, MicroRS4, MR01, MR03-S (2), MR03VE, DigiQ (7), & more.. Updates of projects I am working on in my profile page.
sakadachi is offline   Reply With Quote
Old 09-01-2015, 08:11 AM   #81
Skiddins's Avatar
At present you can only get them from Zen Racing in the UK;
http://www.zen-racing.co.uk/catalog/
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 09-01-2015, 01:33 PM   #82
sakadachi's Avatar
Thanks for the info, Skiddins.
Old 09-05-2015, 10:55 PM   #83
Trader Rating: 27 (100%+)
So when you're done with your practice, or each timed run, where is the data saved? Can you email it to yourself? And if you do email it, will a windows machine open the attachment and view everything properly? I am curious because the lap counting app I'm currently using, everything works great if I open the files on my phone, but on my computer it's all mis-spaced and I have to tab everything into place to be read it.
jbrow1 is offline   Reply With Quote
Old 09-06-2015, 11:27 PM   #84
Any chance this being android compatible in future?
battler82 is offline   Reply With Quote
Old 09-07-2015, 07:21 AM   #85
Currently you hit save and the data is saved in the app under the history tab. If you want to get a feel for it you can download the app for free and just try it out with manual inputs.
No firm date. In the pipeline.
cyclonetog is offline   Reply With Quote
Old 09-07-2015, 08:18 AM   #86
Forgot I've already downloaded the app, just need to mess around with it. Thanks
Old 09-07-2015, 08:29 AM   #87
Let's get a US distributor for these! Zen is out of stock.
lmwong is offline   Reply With Quote
Old 09-23-2015, 11:24 AM   #88
Company Representative
Trader Rating: 15 (100%+)
Not sure if it is in the works or has been mentioned before but a 'Min lap" feature would be great.
I used mine for the 1st time this past weekend at a club race ( med size carpet track) I found it to work very well, almost to well as the box would pick up the car in random spots on the track creating false laps, in the end my pit buddy found an angle that seemed to work 95% of the time.
A min lap lockout would solve this and allow the box to be placed in more friendly locations.
For example:
If a average lap is 10 sec's mine would record a 10.?? then a 2.?? then a 8.?? then a 10.00 for the full run. it was random and could have been when I was off line passing or whatever.. but if I could have set a min lap of say 8 seconds then it would have ignored the 2 second lap and displayed the proper laps every time.
Like I said you can work around this by having a friend change the angle slighly of the box in relation to the track but that is an extra step I would like to avoid..LOL I use to have the old ORION lap counter ( same idea ) and I am pretty sure it had a min lap time.
Overall I would give this an 10 out of 10 as my gripe can be fixed within the app.
WCICS- Competition Director
Korgae is offline   Reply With Quote
Old 09-23-2015, 05:26 PM   #89
Dan the Man's Avatar
Trader Rating: 40 (100%+)
If this gets compatibility with Android I'll buy it in a flash.
|-•-|Hot Bodies Pro 5|-●-|The "F109X"|-•-|Xray X12 2015|-•-|
If you don't have clean bearings, good transmission and a perfect car, trust me when I say this...someone else does.
Dan the Man is offline   Reply With Quote
Old 10-10-2015, 10:31 AM   #90
This Android app works just great with the lap timer. However, it says your phone needs to have the new bluetooth 4.0. I am having great fun with mine
The following is a direct quote from the app's Google Play page:
V3.1 TimingBeam can now work with PocketPit’s Lap Counting System
This latest TimingBeam version is compatible with PocketPit’s Lap Timer which uses the new Bluetooth 4.0 Low-energy (BLE) protocol. A new BLE scanning function has been incorporated into the software to enable your Android device to scan for any such BLE-based Timers. Because Android’s support for Bluetooth 4.0 was only introduced since Android 4.3, please verify whether your Android device has Bluetooth 4.0 hardware support if you plan to connect TimingBeam with such BLE-based Lap Counting System.
a380danzer is offline   Reply With Quote
