    Hide Wikipost
Old 03-29-2017, 02:04 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Motiv RC
Last edit by: R Dodge
NEW FOR 2017 - MC2!
MOTIV M-Code motors, now MC2 for 2017, come pre-set to perform well in most applications. Each MOTIV M-Code motor comes with a specification check list specific to that individual motor. All MOTIV M-Code spec motors come standard with the new "S-HIGH" rotor. If you prefer a different rotor, please send an email via the "Contact Us" page on the Motiv site and reference your order.
Motiv dealers in the U.S. that have received MC2s are:
ProLevel RC
Fordham Hobbies
Lefthander RC
TQ RC Racing
Activ RC
Gripworks RC
Stormer Hobbies
AMain Hobbies
NorCal Hobbies
& More - Check your local hobby shop!
“Defy” Series Pro Li-Po battery weights
“Shorty” 2 Cell, 7.4v, 5000mah, 65c+ - 215 grams
“Thin Shorty” 2 Cell, 7.4v, 3900mah, 65c+ - 159 grams
2 Cell, 7.4v, 5000mah, 60c+ - 258 grams
2 Cell, 7.4v, 6000mah, 90c+ - 311 grams
Following are some suggested starting points for the MC2 line of motors for each class (we will update/add to this as often as possible). One key piece to pay attention to when adjusting your motor is Amp Draw. Try to keep spec motors around 3.0.
25.5 F1
FDR: 2.9-3.2
Timing: 42-45* measured on Motolyser
Rotor: 12.3mm standard
Fan: Yes
25.5 USVTA
FDR: 3.6-3.9
Timing: 44-46* measured on Motolyser
Fan: Yes
21.5 USGT
FDR: 3.9-4.1
Timing: 46-48* measured on Motolyser
Rotor: S-HIGH
Fan: Yes
17.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.1-4.4
Rotor: S-HIGH
Fan: Yes
17.5 TC (Outdoor/Larger Tracks)
FDR: 3.8-4.0
Rotor: S-HIGH
Fan: Yes
17.5 1/12
Rollout: 83-85mm
Rotor: S-MID
Fan: No
13.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.7-4.9
Rotor: S-HIGH
Fan: Yes
13.5 TC (Outdoor/Larger Tracks)
FDR: 4.4-4.6
Rotor: S-HIGH
Fan: Yes
13.5 1/12
Rollout: 78-80mm
Rotor: S-MID
Fan: No
WGTR
Rollout: 73mm
Timing: 46
Rotor: S-MID for larger tracks. S-HIGH for smaller tracks, or tracks with black carpet.
17.5 2WD Buggy
FDR: 5.85-6.0
Timing: 45-48*
Rotor: S-HIGH
Fan: Yes
17.5 2WD SC & Stadium Truck
FDR: 7.5-7.8
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
13.5 4WD Buggy
FDR: 7.0-7.2
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
Following are starting points for Mod motors in the MC1 line
7.5 2WD Buggy
FDR: 10.2
Timing: @ 28*
Rotor: M-MID
Fan: Optional
5.5 TC
FDR: 7.0-7.2
Timing: @ 30*
Rotor: M-HIGH
Fan: Optional
4.5 TC
FDR: 7.6-7.8
Timing: @ 20*
Rotor: M-HIGH
Fan: Optional
Every MOTIV Motor is hand checked, assembled and packaged by a professional in house at our WI, USA office. During this process every motor component must meet MOTIV requirements before assembly and packaging. Included is a specification check list which is filled out on a motor to motor basis all through the testing and assembly process to ensure the quality of our finished product
How its Made: Motiv RC Brushless Motor assembly w/ Paul Lemieux
Print Wikipost
Like Tree70Likes
Old 12-08-2015, 07:36 PM   #91
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
Originally Posted by R Dodge View Post
Per Paul, Mid or high rotor, 45deg timing on can. Fan on motor if possible.
Thanks Robbie... And Paul.
dr_hfuhuhurr is offline   Reply With Quote
Old 12-08-2015, 08:44 PM   #92
Sam Isaacs's Avatar
Trader Rating: 20 (100%+)
Great products as usual from Motiv and Paul. Motors were great at the US Indoor Champs that just passed--particularly the infield rip!
As Dan posted earlier, I ran a 4.05 FDR and timed the motor at 51 degrees for a track that was probably about 90x40 feet or so. This is a good starting point for anyone interested.
Sam
Awesomatix USA, Roche RC USA, Sanwa, Avid, TQ Wire, PCR, Team EAM, 2mm Designs, Timmy, CR Graphics MRH, JMR
Sam Isaacs is offline   Reply With Quote
Old 12-09-2015, 03:20 AM   #93
R Dodge's Avatar
No problem. I have little to no experience with off-road, but I imagine you'd want mid if you have small/few jumps w/ long straights and probably high if you have big/many jumps that you need to clear.
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is offline   Reply With Quote
Old 12-09-2015, 09:40 PM   #94
This is exactly what I use in 13.5 wheeler and it works incredibly well. No fan and geared to come off at 140-150 degrees.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 12-09-2015, 09:53 PM   #95
Trader Rating: 28 (100%+)
Anyone have a starting point for 1/12 17.5? Rollout/timing/rotor suggestions? Carpet track size is 100x48. Thanks in advance!
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 12-09-2015, 09:55 PM   #96
Thanks Troy. Can you give me an idea of fdr you are using?
Old 12-09-2015, 10:05 PM   #97
Dan Hamann's Avatar
Trader Rating: 14 (100%+)
S-Low rotor, 50* timing on a motolyser/motor checker, 89-93 rollout.
RCAmerica - Xray - Hudy - RC^2 - Motiv - Team EAM - Sanwa - Avid - Max.FX - Protoform - Pro-Line - Gravity R/C - Prolevel R/C - 2MM Designs
Dan Hamann is offline   Reply With Quote
Old 12-10-2015, 09:31 AM   #98
100' x 48' high bite clay track.
Los 22-4, 84t spur 32 pinion. Not sure of the fdr.
Old 12-10-2015, 11:13 AM   #99
Ivan Dickson's Avatar
Trader Rating: 12 (93%+)
Default Great results with 17.5 Motiv Rc Brushless motor
Just wanted say thanks Motiv Rc for AWESOME motors, at my local track I
have TQ 4 out 5 races in 17.5 class and I won four straight and leading the
winter series.
Paul has great customer support and I highly recommend his products!
Keep up the great work in our industry
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 12-10-2015, 12:46 PM   #100
bigcracing's Avatar
Trader Rating: 32 (100%+)
I just ran last night on a 95x40 track and geared at 76 56 and timed at 45 degrees,rear tire was 40.5mm, So my roll outwas 93.73 and temps were around 125 Earlier i ran 76 55 and my temps were 140+ and was 2 tenths slower
bigcracing is offline   Reply With Quote
Old 12-15-2015, 10:40 AM   #101
theproffesor's Avatar
Trader Rating: 58 (100%+)
Just picked up a 21.5 with the mid rotor for USGT. I'm running on a track with about a 65 foot straight with fairly technical infield. What would be a good place to start my timing and final drive.
Thanks in advance
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is offline   Reply With Quote
Old 12-15-2015, 10:50 AM   #102
R Dodge's Avatar
Thanks in advance
I would start at around 47-49* on the endbell at around 3.7-3.8 FDR. That's what Drew and I ran in USGT on a 80x36 track in October and we ran 1-2 all weekend until the batteries in my transmitter died in the main
Old 12-15-2015, 12:19 PM   #103
THANKS!!!
Old 12-20-2015, 07:20 PM   #104
Tandum4056's Avatar
Trader Rating: 111 (100%+)
Hi,
New to Motiv motors and I just picked up a 10.5 to run in my B5M buggy. Can anyone recommend gearing/ timing for a medium size clay track with some larger jumps? Thanks!
Tandum4056 is offline   Reply With Quote
Old 12-21-2015, 05:49 AM   #105
R Dodge's Avatar
Originally Posted by Tandum4056 View Post
Hi,
Hi Tandum,
Great - welcome! I don't know the answer to this, but if someone doesn't get an answer to you by this afternoon I will chat with Paul to see what he would advise and get back to you with that info.
Robbie
