    Hide Wikipost
Old 03-29-2017, 02:04 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Motiv RC
Last edit by: R Dodge
NEW FOR 2017 - MC2!
MOTIV M-Code motors, now MC2 for 2017, come pre-set to perform well in most applications. Each MOTIV M-Code motor comes with a specification check list specific to that individual motor. All MOTIV M-Code spec motors come standard with the new "S-HIGH" rotor. If you prefer a different rotor, please send an email via the "Contact Us" page on the Motiv site and reference your order.
Motiv dealers in the U.S. that have received MC2s are:
ProLevel RC
Fordham Hobbies
Lefthander RC
TQ RC Racing
Activ RC
Gripworks RC
Stormer Hobbies
AMain Hobbies
NorCal Hobbies
& More - Check your local hobby shop!
“Defy” Series Pro Li-Po battery weights
“Shorty” 2 Cell, 7.4v, 5000mah, 65c+ - 215 grams
“Thin Shorty” 2 Cell, 7.4v, 3900mah, 65c+ - 159 grams
2 Cell, 7.4v, 5000mah, 60c+ - 258 grams
2 Cell, 7.4v, 6000mah, 90c+ - 311 grams
Following are some suggested starting points for the MC2 line of motors for each class (we will update/add to this as often as possible). One key piece to pay attention to when adjusting your motor is Amp Draw. Try to keep spec motors around 3.0.
25.5 F1
FDR: 2.9-3.2
Timing: 42-45* measured on Motolyser
Rotor: 12.3mm standard
Fan: Yes
25.5 USVTA
FDR: 3.6-3.9
Timing: 44-46* measured on Motolyser
Fan: Yes
21.5 USGT
FDR: 3.9-4.1
Timing: 46-48* measured on Motolyser
Rotor: S-HIGH
Fan: Yes
17.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.1-4.4
Rotor: S-HIGH
Fan: Yes
17.5 TC (Outdoor/Larger Tracks)
FDR: 3.8-4.0
Rotor: S-HIGH
Fan: Yes
17.5 1/12
Rollout: 83-85mm
Rotor: S-MID
Fan: No
13.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.7-4.9
Rotor: S-HIGH
Fan: Yes
13.5 TC (Outdoor/Larger Tracks)
FDR: 4.4-4.6
Rotor: S-HIGH
Fan: Yes
13.5 1/12
Rollout: 78-80mm
Rotor: S-MID
Fan: No
WGTR
Rollout: 73mm
Timing: 46
Rotor: S-MID for larger tracks. S-HIGH for smaller tracks, or tracks with black carpet.
17.5 2WD Buggy
FDR: 5.85-6.0
Timing: 45-48*
Rotor: S-HIGH
Fan: Yes
17.5 2WD SC & Stadium Truck
FDR: 7.5-7.8
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
13.5 4WD Buggy
FDR: 7.0-7.2
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
Following are starting points for Mod motors in the MC1 line
7.5 2WD Buggy
FDR: 10.2
Timing: @ 28*
Rotor: M-MID
Fan: Optional
5.5 TC
FDR: 7.0-7.2
Timing: @ 30*
Rotor: M-HIGH
Fan: Optional
4.5 TC
FDR: 7.6-7.8
Timing: @ 20*
Rotor: M-HIGH
Fan: Optional
Every MOTIV Motor is hand checked, assembled and packaged by a professional in house at our WI, USA office. During this process every motor component must meet MOTIV requirements before assembly and packaging. Included is a specification check list which is filled out on a motor to motor basis all through the testing and assembly process to ensure the quality of our finished product
How its Made: Motiv RC Brushless Motor assembly w/ Paul Lemieux
Print Wikipost
Like Tree59Likes
Old 10-27-2015, 07:10 PM   #76
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
Looks like a red Hobbywing V3.1 120a
Dan is offline   Reply With Quote
Old 10-28-2015, 01:43 AM   #77
Trader Rating: 32 (100%+)
Originally Posted by mschumi101 View Post
What were some of the temps you guys were seeing? I notice between Paul's and Drew's rides the fans are mounted on opposite sides of the motor. Does one work better at cooling it than the other?
In tc it was 150/160 in 1/12 130/135. I'm sure results will vary.
Monti
Monti is offline   Reply With Quote
Old 10-28-2015, 08:01 PM   #78
Trader Rating: 20 (100%+)
I've been running my fan in front of the motor for a while now. When I switched I did not notice a significant different in temp either way but it does more the weight of the fan forward and more compact to the center of the car. Packaging it up there does get a little tight so be sure not to hamper the flow of the fan by having it jammed up against something too tight.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 10-29-2015, 05:41 AM   #79
DBM
How much do the Defy 7800 2s and 1s lipos weigh?
DBM is offline   Reply With Quote
Old 10-29-2015, 08:25 PM   #80
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
I have been running mine behind the motor, but I have quite a bit of space in front of the motor if I wanted to run a fan there. Balancing it out weight wise could help though. I just want to make sure there is enough flow and that it will cool the motor well. Thanks
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 10-29-2015, 09:23 PM   #81
I don't have a 1S but the 2s is 321g on my scale.
Old 10-29-2015, 09:43 PM   #82
AlexPate's Avatar
Trader Rating: 19 (100%+)
I think the 1s was around 153
Alex Pate. www.gripworksrc.com
Motiv Rc, Hobbywing, ORCA, Protoform,
VBC RACING, XRAY, ROCHE, AWESOMATIX, TEAM ASSOCIATED,
ARC,CRC,AVID,MCKUNE DESIGN, PROLINE, JCONCEPTS, GFORCE, MACLAN, R1WURKS
AlexPate is offline   Reply With Quote
Old 11-26-2015, 08:30 AM   #83
Trader Rating: 112 (100%+)
What size are the bullet connectors ports on the bateries?
Dave
Sponsors: YuK-Foo Tire Prep
dragracer72nova is offline   Reply With Quote
Old 11-26-2015, 08:42 AM   #84
Ivan Dickson's Avatar
Trader Rating: 11 (92%+)
Dave
4mm
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 11-26-2015, 09:20 AM   #85
AlexPate's Avatar
Motiv power is working great so far, motiv motors took the win for f1 1/12 13.5 and scale spec at the big chill trophy race!
Old 11-26-2015, 12:27 PM   #86
Originally Posted by Ivan Dickson View Post
4mm
Thank you!
Dave
Old 11-30-2015, 09:58 AM   #87
bigcracing's Avatar
I Ran three Motiv motors this past weekend at the indoor champs and they where awsome a 17.5 and 13.5 and 21.5. All three were fast and Paul helped out with roll out and fdr and temps it was awsome I ran most if my motors below 140 Mostly between 130 and 140.
Thanks Paul for all your help and giving us good motors.
Thanks Chris Corven
bigcracing is offline   Reply With Quote
Old 11-30-2015, 12:48 PM   #88
Dan Hamann's Avatar
Trader Rating: 14 (100%+)
Motiv continuing the Stock TC hot streak, winning 17.5 TC at Indoor Champs.
RCAmerica - Xray - Hudy - RC^2 - Motiv - Team EAM - Sanwa - Avid - Max.FX - Protoform - Pro-Line - Gravity R/C - Prolevel R/C - 2MM Designs
Dan Hamann is offline   Reply With Quote
Old 12-08-2015, 03:31 PM   #89
dr_hfuhuhurr's Avatar
Trader Rating: 73 (100%+)
I'm going to be running a Motiv 13.5 in a 4wd offroad class. I have the low/mid/high rotors and was wondering which would be best to use? I assume the high rotor...From my motor checker:
40* Timing for both
Mid Rotor
- KV = 3427
- RPM = 27762
- V = 8.1V
- I = 3.2A
High Rotor
- KV = 3113
- RPM = 25219
- V = 8.1V
- I = 3.4A
Which rotor would you recommend and where would I go with timing?
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 12-08-2015, 06:34 PM   #90
R Dodge's Avatar
40* Timing for both
Mid Rotor
- KV = 3427
- RPM = 27762
- V = 8.1V
- I = 3.2A
High Rotor
- KV = 3113
- RPM = 25219
- V = 8.1V
- I = 3.4A
Per Paul, Mid or high rotor, 45deg timing on can. Fan on motor if possible.
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is offline   Reply With Quote
