    Hide Wikipost
Old 03-29-2017, 02:04 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Motiv RC
Last edit by: R Dodge
NEW FOR 2017 - MC2!
MOTIV M-Code motors, now MC2 for 2017, come pre-set to perform well in most applications. Each MOTIV M-Code motor comes with a specification check list specific to that individual motor. All MOTIV M-Code spec motors come standard with the new "S-HIGH" rotor. If you prefer a different rotor, please send an email via the "Contact Us" page on the Motiv site and reference your order.
Motiv dealers in the U.S. that have received MC2s are:
ProLevel RC
Fordham Hobbies
Lefthander RC
TQ RC Racing
Activ RC
Gripworks RC
Stormer Hobbies
AMain Hobbies
NorCal Hobbies
& More - Check your local hobby shop!
“Defy” Series Pro Li-Po battery weights
“Shorty” 2 Cell, 7.4v, 5000mah, 65c+ - 215 grams
“Thin Shorty” 2 Cell, 7.4v, 3900mah, 65c+ - 159 grams
2 Cell, 7.4v, 5000mah, 60c+ - 258 grams
2 Cell, 7.4v, 6000mah, 90c+ - 311 grams
Following are some suggested starting points for the MC2 line of motors for each class (we will update/add to this as often as possible). One key piece to pay attention to when adjusting your motor is Amp Draw. Try to keep spec motors around 3.0.
25.5 F1
FDR: 2.9-3.2
Timing: 42-45* measured on Motolyser
Rotor: 12.3mm standard
Fan: Yes
25.5 USVTA
FDR: 3.6-3.9
Timing: 44-46* measured on Motolyser
Fan: Yes
21.5 USGT
FDR: 3.9-4.1
Timing: 46-48* measured on Motolyser
Rotor: S-HIGH
Fan: Yes
17.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.1-4.4
Rotor: S-HIGH
Fan: Yes
17.5 TC (Outdoor/Larger Tracks)
FDR: 3.8-4.0
Rotor: S-HIGH
Fan: Yes
17.5 1/12
Rollout: 83-85mm
Rotor: S-MID
Fan: No
13.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.7-4.9
Rotor: S-HIGH
Fan: Yes
13.5 TC (Outdoor/Larger Tracks)
FDR: 4.4-4.6
Rotor: S-HIGH
Fan: Yes
13.5 1/12
Rollout: 78-80mm
Rotor: S-MID
Fan: No
WGTR
Rollout: 73mm
Timing: 46
Rotor: S-MID for larger tracks. S-HIGH for smaller tracks, or tracks with black carpet.
17.5 2WD Buggy
FDR: 5.85-6.0
Timing: 45-48*
Rotor: S-HIGH
Fan: Yes
17.5 2WD SC & Stadium Truck
FDR: 7.5-7.8
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
13.5 4WD Buggy
FDR: 7.0-7.2
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
Following are starting points for Mod motors in the MC1 line
7.5 2WD Buggy
FDR: 10.2
Timing: @ 28*
Rotor: M-MID
Fan: Optional
5.5 TC
FDR: 7.0-7.2
Timing: @ 30*
Rotor: M-HIGH
Fan: Optional
4.5 TC
FDR: 7.6-7.8
Timing: @ 20*
Rotor: M-HIGH
Fan: Optional
Every MOTIV Motor is hand checked, assembled and packaged by a professional in house at our WI, USA office. During this process every motor component must meet MOTIV requirements before assembly and packaging. Included is a specification check list which is filled out on a motor to motor basis all through the testing and assembly process to ensure the quality of our finished product
How its Made: Motiv RC Brushless Motor assembly w/ Paul Lemieux
Print Wikipost
Like Tree63Likes
Old 07-04-2017, 06:18 AM   #676
Fran's Avatar
Trader Rating: 151 (100%+)
Originally Posted by liljohn1064 View Post
Mine arrived with 44 on the can. I didn't touch timing, but kept adding pinion through the night. I started with a 38, dropped to the 35 and then gradually went back up. At a 39 tooth the motor was coming off at the same temp as @ 35 and no fade. I didn't change it for the main, but it didn't get any hotter. I might still have more gearing to add. One other racer was running the same motor and was up to a 41 tooth pinion. I still need to work on my driving and find another tenth or two, but the motor held up its end of the deal.It is a short stack, with the S High Rotor.
Thanks liljohn for the info, very helpful. Looking forward to ordering mine today. Happy & safe 4th to all!
Fran is offline   Reply With Quote
Old 07-16-2017, 06:59 PM   #677
Send a message via AIM to goop
Has any one got the new discharge bank from motive. That thing looks awesome.
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 07-16-2017, 07:29 PM   #678
R Dodge's Avatar
Yea I've used it 2 weekends and it is nice. Gotta plug in both leads as the 2nd set powers the fan so it runs continuously which is nice.
Ivan Dickson likes this.
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is offline   Reply With Quote
Old 07-24-2017, 11:47 AM   #679
Default New IR limits set by Roar.
How do the Mc2 fall in place are they legal still?
bigtee01 is offline   Reply With Quote
Old 07-24-2017, 11:57 AM   #680
tbrymer's Avatar
Yes they are legal
CRC - C&C Motorsports - SpeedZone
tbrymer is offline   Reply With Quote
Old 07-24-2017, 12:04 PM   #681
Roar's new rules takes into account the lowest IR for each wind. That's why it says the minimum could change before the rules go into effect. No motors that are currently legal will be impacted by the rules. If a manufacturer comes out with an even lower minimum resistance before Sept 1st, that will be the new minimum. The current minimum for 17.5 is set from the new Trinity motor (which is 17.8 per pole)
Antimullet likes this.
-Mike B.
Carnage9270 is online now   Reply With Quote
Old 07-24-2017, 04:34 PM   #682
Originally Posted by tbrymer View Post
Yes they are legal
There is a guy who runs one here in Arizona and I just know it's a cheater motor!!!!
glennhl is offline   Reply With Quote
Old 07-24-2017, 06:53 PM   #683
tbrymer's Avatar
It's legal, ask Paul!
bounce and glennhl like this.
Old 07-25-2017, 02:06 PM   #684
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
looks very nice
https://www.amainhobbies.com/motiv-i...ov0105/p632574
Old 07-25-2017, 02:46 PM   #685
Trader Rating: 18 (100%+)
That power cap looks amazing. #drool lol
iTz Nicholas72 is online now   Reply With Quote
Old 07-25-2017, 02:57 PM   #686
nubs's Avatar
Wonder if a stock version is also incoming?
Tamiya TRF419X | Tamiya TA07 Pro | Tamiya TB04 / Exo Six | AE B5 Converted to B5M
nubs is offline   Reply With Quote
Old 07-25-2017, 04:00 PM   #687
For that kind of money it better "swallow".
mleemor60 is offline   Reply With Quote
Old 07-25-2017, 05:32 PM   #688
Trader Rating: 8 (90%+)
Used the speedo 2 weeks, once for mod tc and once for stock tc. Very easily adjustable, responds very well to changes for throttle and brake settings. The power cap is slick. You won't be disappointed!!!
Johnny Carey is offline   Reply With Quote
Old 07-25-2017, 10:34 PM   #689
Originally Posted by Marcos.J View Post
ummm, why does it look just like a HobbyWing XR10 160 amp? Same exact price too.
belewis01 is offline   Reply With Quote
Old 07-26-2017, 01:40 AM   #690
R Dodge's Avatar
Not that I'm aware of & I've been testing this in stock TC for a month.
same price as its competitors, so I guess all of them should?
Not a HobbyWing at all. It has more similarities to the Team Powers speed control.
