    Hide Wikipost
Old 03-29-2017, 02:04 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Motiv RC
Last edit by: R Dodge
NEW FOR 2017 - MC2!
MOTIV M-Code motors, now MC2 for 2017, come pre-set to perform well in most applications. Each MOTIV M-Code motor comes with a specification check list specific to that individual motor. All MOTIV M-Code spec motors come standard with the new "S-HIGH" rotor. If you prefer a different rotor, please send an email via the "Contact Us" page on the Motiv site and reference your order.
Motiv dealers in the U.S. that have received MC2s are:
ProLevel RC
Fordham Hobbies
Lefthander RC
TQ RC Racing
Activ RC
Gripworks RC
Stormer Hobbies
AMain Hobbies
NorCal Hobbies
& More - Check your local hobby shop!
“Defy” Series Pro Li-Po battery weights
“Shorty” 2 Cell, 7.4v, 5000mah, 65c+ - 215 grams
“Thin Shorty” 2 Cell, 7.4v, 3900mah, 65c+ - 159 grams
2 Cell, 7.4v, 5000mah, 60c+ - 258 grams
2 Cell, 7.4v, 6000mah, 90c+ - 311 grams
Following are some suggested starting points for the MC2 line of motors for each class (we will update/add to this as often as possible). One key piece to pay attention to when adjusting your motor is Amp Draw. Try to keep spec motors around 3.0.
25.5 F1
FDR: 2.9-3.2
Timing: 42-45* measured on Motolyser
Rotor: 12.3mm standard
Fan: Yes
25.5 USVTA
FDR: 3.6-3.9
Timing: 44-46* measured on Motolyser
Fan: Yes
21.5 USGT
FDR: 3.9-4.1
Timing: 46-48* measured on Motolyser
Rotor: S-HIGH
Fan: Yes
17.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.1-4.4
Rotor: S-HIGH
Fan: Yes
17.5 TC (Outdoor/Larger Tracks)
FDR: 3.8-4.0
Rotor: S-HIGH
Fan: Yes
17.5 1/12
Rollout: 83-85mm
Rotor: S-MID
Fan: No
13.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.7-4.9
Rotor: S-HIGH
Fan: Yes
13.5 TC (Outdoor/Larger Tracks)
FDR: 4.4-4.6
Rotor: S-HIGH
Fan: Yes
13.5 1/12
Rollout: 78-80mm
Rotor: S-MID
Fan: No
WGTR
Rollout: 73mm
Timing: 46
Rotor: S-MID for larger tracks. S-HIGH for smaller tracks, or tracks with black carpet.
17.5 2WD Buggy
FDR: 5.85-6.0
Timing: 45-48*
Rotor: S-HIGH
Fan: Yes
17.5 2WD SC & Stadium Truck
FDR: 7.5-7.8
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
13.5 4WD Buggy
FDR: 7.0-7.2
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
Following are starting points for Mod motors in the MC1 line
7.5 2WD Buggy
FDR: 10.2
Timing: @ 28*
Rotor: M-MID
Fan: Optional
5.5 TC
FDR: 7.0-7.2
Timing: @ 30*
Rotor: M-HIGH
Fan: Optional
4.5 TC
FDR: 7.6-7.8
Timing: @ 20*
Rotor: M-HIGH
Fan: Optional
Every MOTIV Motor is hand checked, assembled and packaged by a professional in house at our WI, USA office. During this process every motor component must meet MOTIV requirements before assembly and packaging. Included is a specification check list which is filled out on a motor to motor basis all through the testing and assembly process to ensure the quality of our finished product
How its Made: Motiv RC Brushless Motor assembly w/ Paul Lemieux
Print Wikipost
Like Tree68Likes
Old 06-09-2017, 06:06 AM   #661
Trader Rating: 45 (100%+)
Very nice Jorge, thanks for the good data I'll go back and try it. What is the dyno and software you use? That would be nice to have!
Pro-Line/Protoform, HRP Distributing, PTRC Racing, Ho B Max
Antimullet is offline   Reply With Quote
Old 06-09-2017, 07:34 AM   #662
Jorge T's Avatar
It's a McPappy 1.0 w/eagletree logger, 5 loads and PC controlled ESC.
I use a modified version of the spreadsheet John Stranahan developed.
Just for sh**ts and giggles. This is a D3.5 17.5 maxilla on the dyno. This is my benchmark.
test volt 4.1(1S)
Antimullet likes this.
RSD
Jorge T is offline   Reply With Quote
Old 06-17-2017, 05:11 PM   #663
Fran's Avatar
Trader Rating: 156 (100%+)
How is the MC2 17.5 in 1S WGT-R configurations? Is it considered a short stack can? Thanks.
Fran is online now   Reply With Quote
Old 06-18-2017, 09:22 AM   #664
JAE
Trader Rating: 28 (100%+)
What is the take-away from this? A little less rpm at 40 degrees timing but more bottom end/torque and efficiency? What's the recommended gearing and timing in 2wd buggy? Thx!
Originally Posted by Jorge T View Post
Here is a recent dyno of my MC2 17.5.
I have attended 2 races with this motor on CRC Black Carpet, so it is well broken in.
I clean and dyno the motor after each race day and have not seen any power degradation.
The re-shim testing was done last month.
JAE
JAE is online now   Reply With Quote
Old 06-20-2017, 07:42 AM   #665
Jorge T's Avatar
You got it. The motor produces more power using less battery.
Not sure gearing for 2wd buggy.
If you were running 50* before, try 40 and go up 1 tooth first, then 2 teeth pinion if you are confident motor and esc temps are OK
Check lap times, Esc and motor temps to see what setting works best at the track.
Old 06-27-2017, 07:02 AM   #666
Tried the Motiv MC2 17.5 in my 1/12 this weekend. Set a personal best lap time and overall number of laps by 1 lap. Much more power through the run and little to no fade.
dr_hfuhuhurr, qcrc and bertottius like this.
Old 06-27-2017, 12:13 PM   #667
Trader Rating: 8 (90%+)
What did you end up gearing it at? I am running between 85-86 mmpr with about 3-4 tenths of fade after 8 mins. Motor has been as advertised
Johnny Carey is offline   Reply With Quote
Old 06-27-2017, 05:54 PM   #668
45 degree timing on a analyzer, right around 80mm rollout.
High grip crc black, and a medium size flowing track. These new motors like to rev.
Hero lap was 7.8. Average 8.1 and last few laps in the main of 8 minutes were 8.2 average. Not much fade at all really. The 7.8 was just me driving right once in a race.
Johnny Carey likes this.
Old 06-28-2017, 03:56 AM   #669
R Dodge's Avatar
Great info guys!
I've been running some 17.5 TC on a medium/large asphalt track the past 2 months. I started with similar settings to what I ran inside and found the timing to be a bit too high. Temps were higher than I'd like and fade was an issue. I've been backing off of the timing and adding more gear and that seems to be helping on both fronts. Currently at 45* on the motolyser and 3.9 FDR. Working my way towards trying a low timing/high gearing setup soon, hopefully this weekend.
Congrats Aaron on your new personal best!
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is offline   Reply With Quote
Old 06-30-2017, 11:57 AM   #670
liljohn1064's Avatar
Trader Rating: 17 (100%+)
Putting the 17.5 in my WGT-R and will hopefully find the sweet spot with gearing before racing starts.
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 07-03-2017, 03:18 AM   #671
Default 21.5 F1 timing?
Hey guys.
Just picked up a new 21.5 on recommendation from LHS. We run 21.5 for F1 instead of the 25.5. FDR of the fast guys is around 3.2. (96/30). Any advice on timing?
Asphalt track, high grip, long straight and sweeper. 120ft+ 15-17 seconds/lap.
Thx
mstrfahrenheit is offline   Reply With Quote
Old 07-03-2017, 11:56 AM   #672
Originally Posted by mstrfahrenheit View Post
Hey guys.
Thx
We were running 2.5-2.8 with a fan and at 42 degrees timing
mstrfahrenheit likes this.
Old 07-03-2017, 01:03 PM   #673
Mine arrived with 44 on the can. I didn't touch timing, but kept adding pinion through the night. I started with a 38, dropped to the 35 and then gradually went back up. At a 39 tooth the motor was coming off at the same temp as @ 35 and no fade. I didn't change it for the main, but it didn't get any hotter. I might still have more gearing to add. One other racer was running the same motor and was up to a 41 tooth pinion. I still need to work on my driving and find another tenth or two, but the motor held up its end of the deal.It is a short stack, with the S High Rotor.
Old 07-03-2017, 01:40 PM   #674
Cool! Ty
Old 07-03-2017, 06:24 PM   #675
Jorge T's Avatar
I started testing below 35 estimated timing Mark on the can on the Dyno.
This are the results.
Since we noticed the power at 30 mark we started testing on the Track.
The results are surprising using RO in low-mid 90mm instead of mid 80mm.
Even though there is close to the same power in the 45 range, what we found was that the motor ran hotter and lost more power at 130*F at 45 setting than at the 30 mark.
From 2 different makes of the newest stator design I've tested below 35* both have shown the same power increase at lower timing.
liljohn1064 and Rebuke like this.
RSD
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
magstaff
