Motiv RC
#631
#633
Suspended
You'll probably want to be around 50* timing. Gearing I think would be around 3.7. Best to try it in practice, run 2-3 minutes and check temps. Make changes from there based on temp and how it feels on the track. I always try to keep the temp around 160 or less.
#634
Suspended
#635
#637
#638
#640
Has anyone tried MC2 - 13.5T on Stadium Truck? I am prepping T5M for Super Stock Truck class for a trophy race.
Suggested gear ratio per manual of T5M is 26/78 -7.80:1 and the track will be a large indoor clay track.
i will start with 26/78 and adjust, but would appreciate if you have any suggestion. Thanks!
#643
Ya, I got one of the 17.5 motors. I think I should go get a lottery ticket now but probably used what little luck I have up already.
#645
Motor smoked: my fault, plugged an esc in backwards. Tried to plug back in properly to see if he esc fried. Forgot to change capacitor before doing this (2nd mistake). Upon plugging battery back in properly the motor smoked right away. Anything worth salvadging likely? Wonder if I just need a new stator, if it damaged rotor etc? Anyone experience this? Thx in advance, am bummed as this was one of my best motors....ever
