    Hide Wikipost
Old 03-29-2017, 02:04 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Motiv RC
Last edit by: R Dodge
NEW FOR 2017 - MC2!
MOTIV M-Code motors, now MC2 for 2017, come pre-set to perform well in most applications. Each MOTIV M-Code motor comes with a specification check list specific to that individual motor. All MOTIV M-Code spec motors come standard with the new "S-HIGH" rotor. If you prefer a different rotor, please send an email via the "Contact Us" page on the Motiv site and reference your order.
Motiv dealers in the U.S. that have received MC2s are:
ProLevel RC
Fordham Hobbies
Lefthander RC
TQ RC Racing
Activ RC
Gripworks RC
Stormer Hobbies
AMain Hobbies
NorCal Hobbies
& More - Check your local hobby shop!
“Defy” Series Pro Li-Po battery weights
“Shorty” 2 Cell, 7.4v, 5000mah, 65c+ - 215 grams
“Thin Shorty” 2 Cell, 7.4v, 3900mah, 65c+ - 159 grams
2 Cell, 7.4v, 5000mah, 60c+ - 258 grams
2 Cell, 7.4v, 6000mah, 90c+ - 311 grams
Following are some suggested starting points for the MC2 line of motors for each class (we will update/add to this as often as possible). One key piece to pay attention to when adjusting your motor is Amp Draw. Try to keep spec motors around 3.0.
25.5 F1
FDR: 2.9-3.2
Timing: 42-45* measured on Motolyser
Rotor: 12.3mm standard
Fan: Yes
25.5 USVTA
FDR: 3.6-3.9
Timing: 44-46* measured on Motolyser
Fan: Yes
21.5 USGT
FDR: 3.9-4.1
Timing: 46-48* measured on Motolyser
Rotor: S-HIGH
Fan: Yes
17.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.1-4.4
Rotor: S-HIGH
Fan: Yes
17.5 TC (Outdoor/Larger Tracks)
FDR: 3.8-4.0
Rotor: S-HIGH
Fan: Yes
17.5 1/12
Rollout: 83-85mm
Rotor: S-MID
Fan: No
13.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.7-4.9
Rotor: S-HIGH
Fan: Yes
13.5 TC (Outdoor/Larger Tracks)
FDR: 4.4-4.6
Rotor: S-HIGH
Fan: Yes
13.5 1/12
Rollout: 78-80mm
Rotor: S-MID
Fan: No
WGTR
Rollout: 73mm
Timing: 46
Rotor: S-MID for larger tracks. S-HIGH for smaller tracks, or tracks with black carpet.
17.5 2WD Buggy
FDR: 5.85-6.0
Timing: 45-48*
Rotor: S-HIGH
Fan: Yes
17.5 2WD SC & Stadium Truck
FDR: 7.5-7.8
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
13.5 4WD Buggy
FDR: 7.0-7.2
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
Following are starting points for Mod motors in the MC1 line
7.5 2WD Buggy
FDR: 10.2
Timing: @ 28*
Rotor: M-MID
Fan: Optional
5.5 TC
FDR: 7.0-7.2
Timing: @ 30*
Rotor: M-HIGH
Fan: Optional
4.5 TC
FDR: 7.6-7.8
Timing: @ 20*
Rotor: M-HIGH
Fan: Optional
Every MOTIV Motor is hand checked, assembled and packaged by a professional in house at our WI, USA office. During this process every motor component must meet MOTIV requirements before assembly and packaging. Included is a specification check list which is filled out on a motor to motor basis all through the testing and assembly process to ensure the quality of our finished product
How its Made: Motiv RC Brushless Motor assembly w/ Paul Lemieux
Print Wikipost
Like Tree59Likes
Old 02-10-2017, 01:00 PM   #481
Great info guys.... Good luck at the Nats....
bertrandsv87 is offline   Reply With Quote
Old 02-16-2017, 11:55 AM   #482
Super Moderator
Marcos.J's Avatar
Trader Rating: 180 (100%+)
What's a good reference point fdr for 17.5 blinky tc?
Old 02-16-2017, 11:59 AM   #483
On the new mc2, anywhere from 3.92/lower 40's on timing or 4.22 and 48* timing is what is common.
~Xray~RCAmerica~Motiv~Gravity RC~ORCA~
Swift Racing Services, LLC.
JDC Motorsports
Boostinswifty38 is offline   Reply With Quote
Old 02-16-2017, 12:00 PM   #484
Super Moderator
Marcos.J's Avatar
Old 02-16-2017, 12:05 PM   #485
Dan
Dan's Avatar
Trader Rating: 45 (100%+)
What is Max timing on the MC2? just curious because the timing marks only go up to 40 deg and I don't have a motolyzer.
Dan is offline   Reply With Quote
Old 02-16-2017, 01:20 PM   #486
wkderf's Avatar
Trader Rating: 18 (100%+)
Infinite timing - there really isnt a limit. The can only has markings up to 40 degrees, but you can easily go past them.
XRAY MOTIV LRP ORCA SPEKTRUM HUDY
wkderf is offline   Reply With Quote
Old 02-16-2017, 02:24 PM   #487
^whqt he said. Highest timing Ive seen other team drivers running is around 52* in tc/1/12. Best area for overall temps and power seems to be 45-48*.
JDC Motorsports
Old 02-17-2017, 01:29 PM   #488
Any ETA when the 17.5T will be back in Stock?
iTz Nicholas72 is offline   Reply With Quote
Old 02-17-2017, 01:34 PM   #489
From talks with paul the last few days, he's working really hard on trying to supply the demands. Last I heard he had about 300 motors to sort through and assemble/test. Going as fast as he can and is rather stressed as you could imagine. I know we are all impatient, but having run them so far, it's worth the wait!
JDC Motorsports
Old 02-17-2017, 02:08 PM   #490
wkderf's Avatar
Some awesome stuff is coming out of Motiv.
Latest shipments that came in at my local shop had near perfect sensor boards, and rotors that were almost 1700 in strength.
Lovin the MC2s!
Boostinswifty38 likes this.
Old 02-17-2017, 07:05 PM   #491
tbrymer's Avatar
Definitely worth the wait!
CRC - C&C Motorsports - SpeedZone
tbrymer is offline   Reply With Quote
Old 02-18-2017, 03:38 AM   #492
Trader Rating: 14 (100%+)
Worth the wait.
Rcforlife13 is offline   Reply With Quote
Old 02-18-2017, 05:38 AM   #493
Super Moderator
Marcos.J's Avatar
mine is on the way
Old 02-18-2017, 06:31 AM   #494
dawgmeat's Avatar
Originally Posted by Marcos.J View Post
mine is on the way
Where did you order from?
dawgmeat is offline   Reply With Quote
Old 02-18-2017, 06:44 AM   #495
tbrymer's Avatar
One left you better hurry.
MOTIV M-CODE 17.5T Pro Tuned Spec Motor MC2 (2 Pole 540) ROAR APPROVED ? ActivRC
