    Hide Wikipost
Old 03-29-2017, 02:04 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Motiv RC
Last edit by: R Dodge
NEW FOR 2017 - MC2!
MOTIV M-Code motors, now MC2 for 2017, come pre-set to perform well in most applications. Each MOTIV M-Code motor comes with a specification check list specific to that individual motor. All MOTIV M-Code spec motors come standard with the new "S-HIGH" rotor. If you prefer a different rotor, please send an email via the "Contact Us" page on the Motiv site and reference your order.
Motiv dealers in the U.S. that have received MC2s are:
ProLevel RC
Fordham Hobbies
Lefthander RC
TQ RC Racing
Activ RC
Gripworks RC
Stormer Hobbies
AMain Hobbies
NorCal Hobbies
& More - Check your local hobby shop!
“Defy” Series Pro Li-Po battery weights
“Shorty” 2 Cell, 7.4v, 5000mah, 65c+ - 215 grams
“Thin Shorty” 2 Cell, 7.4v, 3900mah, 65c+ - 159 grams
2 Cell, 7.4v, 5000mah, 60c+ - 258 grams
2 Cell, 7.4v, 6000mah, 90c+ - 311 grams
Following are some suggested starting points for the MC2 line of motors for each class (we will update/add to this as often as possible). One key piece to pay attention to when adjusting your motor is Amp Draw. Try to keep spec motors around 3.0.
25.5 F1
FDR: 2.9-3.2
Timing: 42-45* measured on Motolyser
Rotor: 12.3mm standard
Fan: Yes
25.5 USVTA
FDR: 3.6-3.9
Timing: 44-46* measured on Motolyser
Fan: Yes
21.5 USGT
FDR: 3.9-4.1
Timing: 46-48* measured on Motolyser
Rotor: S-HIGH
Fan: Yes
17.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.1-4.4
Rotor: S-HIGH
Fan: Yes
17.5 TC (Outdoor/Larger Tracks)
FDR: 3.8-4.0
Rotor: S-HIGH
Fan: Yes
17.5 1/12
Rollout: 83-85mm
Rotor: S-MID
Fan: No
13.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.7-4.9
Rotor: S-HIGH
Fan: Yes
13.5 TC (Outdoor/Larger Tracks)
FDR: 4.4-4.6
Rotor: S-HIGH
Fan: Yes
13.5 1/12
Rollout: 78-80mm
Rotor: S-MID
Fan: No
WGTR
Rollout: 73mm
Timing: 46
Rotor: S-MID for larger tracks. S-HIGH for smaller tracks, or tracks with black carpet.
17.5 2WD Buggy
FDR: 5.85-6.0
Timing: 45-48*
Rotor: S-HIGH
Fan: Yes
17.5 2WD SC & Stadium Truck
FDR: 7.5-7.8
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
13.5 4WD Buggy
FDR: 7.0-7.2
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
Following are starting points for Mod motors in the MC1 line
7.5 2WD Buggy
FDR: 10.2
Timing: @ 28*
Rotor: M-MID
Fan: Optional
5.5 TC
FDR: 7.0-7.2
Timing: @ 30*
Rotor: M-HIGH
Fan: Optional
4.5 TC
FDR: 7.6-7.8
Timing: @ 20*
Rotor: M-HIGH
Fan: Optional
Every MOTIV Motor is hand checked, assembled and packaged by a professional in house at our WI, USA office. During this process every motor component must meet MOTIV requirements before assembly and packaging. Included is a specification check list which is filled out on a motor to motor basis all through the testing and assembly process to ensure the quality of our finished product
How its Made: Motiv RC Brushless Motor assembly w/ Paul Lemieux
Print Wikipost
Like Tree67Likes
Old 10-14-2016, 06:33 AM   #331
Trader Rating: 25 (100%+)
Originally Posted by Troy Carter View Post
I did not get the chance to run my motor at LHR, only a Trinity D41s because Cory drove Leon's car with my Motiv 17.5 motor for a few races. He either won or took second with that car on those days. The Motiv motor had plenty of power out there and I don't think anyone was outright faster down the straight. With the S-Mid rotor my motor was geared at 3.08 with 42° timing off the motor checker.
I do think the S-High rotor would have been better but I simply don't have one to try. I'm not sure I would have been able to gear up more but it may have picked up a little. Glad to hear that you're finding your way with that motor.
To that point, the last race we had at LHR the Goat won, Cory 2nd and me third. At a point in the race I was leading Cory and was able to confirm that my car was faster than before. Faster than him on the straight for sure but, as you know, Cory has phenomenal skill so he past me on the infield (a very tight pass well executed). So, if you ask me if the stronger rotor worked, I will have to say yes given the factors I mentioned before. The numbers on my motor checker reflects the change in output so I guess is an improvement. My S-High Motiv rotor is on the mail. I'll test it out when I get it.
madness is offline   Reply With Quote
Old 10-14-2016, 01:55 PM   #332
Dino_D's Avatar
Originally Posted by nexxus View Post
I appreciate all the attempts to justify the Motive, and yes track time shall be the ultimate test but the more I look at it the worse it seems, you simply can't make a silk purse from a sow's ear. Emails to Motive, unanswered. It's just not looking good!
Hey, I am not trying to justify or convince you. I am not a salesman, I am not sponsored by Motiv, nor do I have anything to gain from it.
I browse the forums to learn more and contribute when I can. Its about sharing information and assisting others. I am just trying to explain what I learned from testing many different motors. I am the guy at the track with 6 spec 24k motors, 2 maxzillas, 3 speedzones, 2 team powers, 4 motiv. I like to test motors, help other racers tune their motors and find a competitive advantage.
Currently, the motiv are the strongest motors I have even though on the dyno the numbers don't seem as impressive pulling lower amps and lower rpms than the other motors I own. But you can run a lower FDR with it.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 10-14-2016, 02:40 PM   #333
Originally Posted by antlockyer View Post
I'm running a national sized track on Sunday Will try going high on it and see if I can even get it warm
Report back on how you get on especially lap times 😀
I'll be doing 4 nationals this year looking forward to MB Models next month.
BKUK is offline   Reply With Quote
Old 10-14-2016, 05:32 PM   #334
Schwarta's Avatar
Timing the 13.5 I set to 50 endbell and geared at 4.2 thing is once it gets too hot the rotor weakens and no matter what you do from there will always run hot
The s-high is recently new, I haven't overheated it.
Schwarta is offline   Reply With Quote
Old 10-15-2016, 12:23 AM   #335
antlockyer's Avatar
Will do. I'm doing one day of Eastbourne next weekend. You've reminded me to book.my hotel for Leeds.
antlockyer is offline   Reply With Quote
Old 10-15-2016, 03:28 AM   #336
nexxus's Avatar
Trader Rating: 302 (100%+)
Well first day of States qualifying is down, I am sitting in 2nd, running the M Code 21.5 in my A800, set the FDR at 2.7 and even then it's a bloody slug. My best times on this track with my Fantom FR-1 21.5 geared at 2.8 are around 18.5/18.6 I'm down at a best of 18.9 and the laptimes are fading off to 19.6/19.7. This is with a brand new R1 Wurks 7600 90C Lipo (done 4 cycles) and a car weighing in at 1370 grams. My first qual I ran my A700 on a track that was barely dry (very slick with GRP 36 control tyres) and was at 18.8 with that using a Trinity 24K 21.5 FDR 3.1, but a hit in that dislodged the esc servo lead so ended the qual after 12 laps 3 minutes, motor was starting to fade slightly.
Person in P1 is running a Fantom FR-1 and a sponsored driver.
Person in P3 is a R1 Wurks
P4 is a Team POwers Plutonium
THinking back to the Fantom
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 10-15-2016, 06:47 AM   #337
You'll need to run the Faster setup to get that title... Good info...
bertrandsv87 is offline   Reply With Quote
Old 10-15-2016, 08:36 AM   #338
racer x 1's Avatar
Trader Rating: 27 (100%+)
I would try a higher Fdr before pulling the motor. Motiv suggested fdr for that wind was in the 3's.
Matt Bell
Mugen MRX5 • Ae R5.2 • X6^3 • M11x • All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 10-15-2016, 05:42 PM   #339
Need some help on which way to go with my Motiv 21.5 in my USGT touring car. The motor did not feel like it had much pull as my TSR motor did.
FDR 3.04 (same as I ran with my TSR motor)
Mid rotor
Timing on can around 50 (I have not put it on the motor analyzer to get true timing)
170 foot straight flowing outdoor asphalt track
Generally it is med to high bite
My question is should I lower my timing or go up on the FDR to try to get some better pull out of the corner.
Brandon Smith
fanfor18 is offline   Reply With Quote
Old 10-15-2016, 09:10 PM   #340
Trader Rating: 20 (100%+)
I would try the FR-1.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 10-15-2016, 09:24 PM   #341
One of the tricks I did to get back some pull out of the corners with Novak motor was to bring the throttle EXPO up to +30% or so on the radio, but that was only beneficial with very wide turn tracks, not good for the twisties....
Mid rotor
Old 10-16-2016, 06:52 AM   #342
antlockyer's Avatar
Never got a chance to play with the motor much as I had issues in heat 2 that needed rectifying. I did run at 86mmpr the motor was warm, I was fast down the straight and didn't seem to lose anything in the infield. Track was technical with a national length straight. Only 5 minutes runs though. I'll be starting at 86mm at the national next week and try increasing from there. Difficult when the grip is coming up to know how much is down to the motor.
Old 10-16-2016, 09:07 PM   #343
nexxus's Avatar
Well put the Fantom back in and got my times into the 18.6/18.7 area, a tad in consistant but enough to grab 2nd for the States in 21.5. Also found that my uber expensive R1 Wurks Lipo was a slug as well, looking back at the times I found:
18.6 - FR-1 and Nanotech 7500
18.8 - FR1 and R1 Wurks Lipo
18.9 - Motiv and Nanotech
19.3 - Motiv and R1 Wurks Lipo
To be fair, the Motiv had good punch and probably be a great motor for a tight carpet track, but for a large outdoor track, it's just not in the game. Biggest disappointment was the R1 Wurks 7600mah 90C Lipo by far. Ran better times with 3 month old Nanotechs.
So food for thought.
Old 10-16-2016, 09:39 PM   #344
Good info here.... I watched all of Nick Adams' videos on YouTube, and he reached the same conclusion on both the 7500 nanotech ultimate/graphene packs, and the fantom motors(although he tested the 17.5t motors)....
Old 10-16-2016, 10:36 PM   #345
Dino_D's Avatar
I agree on you with the nanotech ultimates. They are all I run. For some reason they put out good power against some of the name brands.
As for the motiv, its good for a tight to med carpet tracks.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
magstaff
