    Hide Wikipost
Old 03-29-2017, 02:04 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Motiv RC
Last edit by: R Dodge
NEW FOR 2017 - MC2!
MOTIV M-Code motors, now MC2 for 2017, come pre-set to perform well in most applications. Each MOTIV M-Code motor comes with a specification check list specific to that individual motor. All MOTIV M-Code spec motors come standard with the new "S-HIGH" rotor. If you prefer a different rotor, please send an email via the "Contact Us" page on the Motiv site and reference your order.
Motiv dealers in the U.S. that have received MC2s are:
ProLevel RC
Fordham Hobbies
Lefthander RC
TQ RC Racing
Activ RC
Gripworks RC
Stormer Hobbies
AMain Hobbies
NorCal Hobbies
& More - Check your local hobby shop!
“Defy” Series Pro Li-Po battery weights
“Shorty” 2 Cell, 7.4v, 5000mah, 65c+ - 215 grams
“Thin Shorty” 2 Cell, 7.4v, 3900mah, 65c+ - 159 grams
2 Cell, 7.4v, 5000mah, 60c+ - 258 grams
2 Cell, 7.4v, 6000mah, 90c+ - 311 grams
Following are some suggested starting points for the MC2 line of motors for each class (we will update/add to this as often as possible). One key piece to pay attention to when adjusting your motor is Amp Draw. Try to keep spec motors around 3.0.
25.5 F1
FDR: 2.9-3.2
Timing: 42-45* measured on Motolyser
Rotor: 12.3mm standard
Fan: Yes
25.5 USVTA
FDR: 3.6-3.9
Timing: 44-46* measured on Motolyser
Fan: Yes
21.5 USGT
FDR: 3.9-4.1
Timing: 46-48* measured on Motolyser
Rotor: S-HIGH
Fan: Yes
17.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.1-4.4
Rotor: S-HIGH
Fan: Yes
17.5 TC (Outdoor/Larger Tracks)
FDR: 3.8-4.0
Rotor: S-HIGH
Fan: Yes
17.5 1/12
Rollout: 83-85mm
Rotor: S-MID
Fan: No
13.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.7-4.9
Rotor: S-HIGH
Fan: Yes
13.5 TC (Outdoor/Larger Tracks)
FDR: 4.4-4.6
Rotor: S-HIGH
Fan: Yes
13.5 1/12
Rollout: 78-80mm
Rotor: S-MID
Fan: No
WGTR
Rollout: 73mm
Timing: 46
Rotor: S-MID for larger tracks. S-HIGH for smaller tracks, or tracks with black carpet.
17.5 2WD Buggy
FDR: 5.85-6.0
Timing: 45-48*
Rotor: S-HIGH
Fan: Yes
17.5 2WD SC & Stadium Truck
FDR: 7.5-7.8
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
13.5 4WD Buggy
FDR: 7.0-7.2
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
Following are starting points for Mod motors in the MC1 line
7.5 2WD Buggy
FDR: 10.2
Timing: @ 28*
Rotor: M-MID
Fan: Optional
5.5 TC
FDR: 7.0-7.2
Timing: @ 30*
Rotor: M-HIGH
Fan: Optional
4.5 TC
FDR: 7.6-7.8
Timing: @ 20*
Rotor: M-HIGH
Fan: Optional
Every MOTIV Motor is hand checked, assembled and packaged by a professional in house at our WI, USA office. During this process every motor component must meet MOTIV requirements before assembly and packaging. Included is a specification check list which is filled out on a motor to motor basis all through the testing and assembly process to ensure the quality of our finished product
How its Made: Motiv RC Brushless Motor assembly w/ Paul Lemieux
Print Wikipost
Like Tree70Likes
Old 10-12-2016, 10:30 PM   #316
Trader Rating: 20 (100%+)
Generally I play with the motor timing on the dyno and find the sweet spot for power, then check the timing and amp draw to be sure it's okay. However, the number you have are not unreasonable and do look a bit low in comparison. I can't wait to hear how it does on track.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 10-12-2016, 10:32 PM   #317
nexxus's Avatar
Trader Rating: 302 (100%+)
Thanks I am pretty confident in the way I set timing now it's taken a bit of practice but you know you're doing it well when other racers are asking you to tweak their motor timing and more often than not you can show a tangible improvement on the dyno. But the real test is on the track, I will post the results.
A800 / A800X Awesomatix
Don't worry about what I'm doing.
Worry about why you're worried about what I'm doing.
"Ego is the anesthesia that deadens the pain of stupidity."
nexxus is offline   Reply With Quote
Old 10-13-2016, 04:16 AM   #318
Schwarta's Avatar
Just wondering what has a bigger effect on heat on a motor, timing or gearing?
I have a 13.5t for blinky tc and have struggled with it getting too hot trying to make good power.
Schwarta is offline   Reply With Quote
Old 10-13-2016, 04:47 AM   #319
nexxus's Avatar
Timing the 13.5 I set to 50 endbell and geared at 4.2 thing is once it gets too hot the rotor weakens and no matter what you do from there will always run hot
Old 10-13-2016, 01:28 PM   #320
edit
dayno is offline   Reply With Quote
Old 10-13-2016, 01:31 PM   #321
Originally Posted by nexxus View Post
That all said you can see on the test bench the M Code 21.5 is less powerful than the Fantom FR-1 and Trinity 24K but still above the LRP X20 21.5. These are all motors shimmed properly and set to the timing "sweet spot" as the above post. My next step is to put the motor in the car and compare my lap times.
But at the moment for the 21.5 I don't see it being as fast.
Have you track tested the FR-1 and 24k, if so what results did you get? Thanks for the great dyno info.
Old 10-13-2016, 04:46 PM   #322
Dino_D's Avatar
I don't think you can gear both motors the same to get a comparison Each motor is different.
This is my theory. On the bench, the motor that produces more KV or RPM will have a greater top speed. Max efficiency is around 6amps. You will notice that a motor that has a high torque rotor will always draw less amps and less RPM than a motor that uses a mid torque motor. A mild torque motor will produce the most RPM and amps under no load.
For example, If you swap to the optional super high torque rotor in your 24k trinity, it will pull about 2 to 2.5 amps and have a few hundred Ks less at no load. All these bench test are deceiving sometimes. Sure a flywheel can help give you somewhat of a bench mark but you can't alter the gearing of a flywheel or create progressive resistance as you can with gearing. A 24k may have enough torque to spin your flywheel just as easily as the motiv. You might need a bigger or heavier one to really see the difference under heavier loads. Actual track testing would be best.
I don't have a S-MID Motiv, I have a S-High which will produce under 2.3A at 48 timing, whereas the 24k with 49 timing has more KV (RPM) and pulls approx 6.3A. If I was to compare - I would calculate the 24k motors top RPM (KV) and rollout vs the other motors top RPM (KV) to obtain an accurate rollout and gearing for the reduction of KV but higher torque. (see chart)
This way, both motor will have the same top speed, and this is where you can tell which motor is stronger. From my testing the motiv was stronger in the low to mid range. While the trinity pulled a little harder mid to top, but was laggy on the bottom compared to the motiv. If the track was very technical, the motiv would gain a little bit out of every exit of the turn. Lowering the timing on the trinity to 40-43 degrees and altering the FDR to compensate, the trinity had a bit better punch in the technical sections and didn't lose by as much per lap.
(example) - These are not actual KV numbers - I used these numbers to demonstrate the calculation points.
Trinity Motiv
21.5 21..5
Motor KV 1900 1700
2S Lipo volts 8 8
IntDrv (Xray) 1.9 1.9
Pinon 42 45
Spur 96 92
FDR 4.34 3.88
Tire Dia (mm) 63 63
Rollout 45.57 50.95
No Load rpm 15,200 13,600
No Load kph 41.56 41.58
Attached is a video of my Car (yellow and blue) using a motiv vs Fantom in (Green and Black Car)
https://www.facebook.com/rc404/videos/1654109548212580/
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 10-13-2016, 06:25 PM   #323
nexxus's Avatar
I appreciate all the attempts to justify the Motive, and yes track time shall be the ultimate test but the more I look at it the worse it seems, you simply can't make a silk purse from a sow's ear. Emails to Motive, unanswered. It's just not looking good!
Old 10-13-2016, 07:55 PM   #324
Trader Rating: 25 (100%+)
Originally Posted by jake alton View Post
The 17.5 did it have the high tourque rotor? I've had similar experience with the medium rotor. I had 3.2 fdr and 49deg. Timing. On a very long straight. Still got passed.
On my last race I experimented using a Trinity Torquoise 12.5 rotor and the motor changed for the better. I also geared the car at 3.16 FDR with 35 degrees of timing. The car improved on the straight while running relatively warm (168-175 degrees average). There was no fading on power and I did not loose a lot of torque either. This motor likes to be geared low. At the end, the motor helped me secure the 4th place overall in the Summer Series at LHR. I guess is a keeper, lol. The high torque rotor is a must, at least on my particular track.
madness is offline   Reply With Quote
Old 10-13-2016, 10:40 PM   #325
I did not get the chance to run my motor at LHR, only a Trinity D41s because Cory drove Leon's car with my Motiv 17.5 motor for a few races. He either won or took second with that car on those days. The Motiv motor had plenty of power out there and I don't think anyone was outright faster down the straight. With the S-Mid rotor my motor was geared at 3.08 with 42° timing off the motor checker.
I do think the S-High rotor would have been better but I simply don't have one to try. I'm not sure I would have been able to gear up more but it may have picked up a little. Glad to hear that you're finding your way with that motor.
Old 10-14-2016, 01:41 AM   #326
antlockyer's Avatar
Originally Posted by BKUK View Post
Thanks for finding out the info much appreciated. It seems strange considering the Mid is recommended for 1/12 and Zen racing are primarily a 1/12 distributor. We don't race on the black carpet so from your comments I struggle to see why the High rotor is the only one to choose. Hmmmm
Where did you get to regarding rollout and timing? I've been swapping mine between LMP and GT12 and in the gt car last night I went 2 laps quicker with 66mm v 72mm rollout. The motor was not hot with either at 45 degrees timing. The fantom guys were at 66 and 24k at 72.
12th car I again left the timing and on a decent club size technical track it felt better with a lower rollout but still cold.
A bit lost now with what to do.
antlockyer is online now   Reply With Quote
Old 10-14-2016, 03:36 AM   #327
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
you wont know till you know.
try to be open minded and test motors on track.
load will be different and heat capacity is a big variable for stock motors.
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 10-14-2016, 06:09 AM   #328
It's sitting on the shelf as I've been doing really well with my previous motor a 24K. When I used it also on a medium technical track I was in the 60s rollout. The motor felt really smooth on power, probably too smooth and it didn't feel as punchy or as fast as my 24K. Running about 72 on the 24K. I should try it again with a higher rollout and see what happens.
BKUK is offline   Reply With Quote
Old 10-14-2016, 07:14 AM   #329
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
If you sent it last week Paul was out of the office attending the iic. If I see him tonight I will talk to him about it.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 10-14-2016, 07:24 AM   #330
antlockyer's Avatar
I'm running a national sized track on Sunday Will try going high on it and see if I can even get it warm
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
mariob62
