    Hide Wikipost
Old 03-29-2017, 02:04 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Motiv RC
Last edit by: R Dodge
NEW FOR 2017 - MC2!
MOTIV M-Code motors, now MC2 for 2017, come pre-set to perform well in most applications. Each MOTIV M-Code motor comes with a specification check list specific to that individual motor. All MOTIV M-Code spec motors come standard with the new "S-HIGH" rotor. If you prefer a different rotor, please send an email via the "Contact Us" page on the Motiv site and reference your order.
Motiv dealers in the U.S. that have received MC2s are:
ProLevel RC
Fordham Hobbies
Lefthander RC
TQ RC Racing
Activ RC
Gripworks RC
Stormer Hobbies
AMain Hobbies
NorCal Hobbies
& More - Check your local hobby shop!
“Defy” Series Pro Li-Po battery weights
“Shorty” 2 Cell, 7.4v, 5000mah, 65c+ - 215 grams
“Thin Shorty” 2 Cell, 7.4v, 3900mah, 65c+ - 159 grams
2 Cell, 7.4v, 5000mah, 60c+ - 258 grams
2 Cell, 7.4v, 6000mah, 90c+ - 311 grams
Following are some suggested starting points for the MC2 line of motors for each class (we will update/add to this as often as possible). One key piece to pay attention to when adjusting your motor is Amp Draw. Try to keep spec motors around 3.0.
25.5 F1
FDR: 2.9-3.2
Timing: 42-45* measured on Motolyser
Rotor: 12.3mm standard
Fan: Yes
25.5 USVTA
FDR: 3.6-3.9
Timing: 44-46* measured on Motolyser
Fan: Yes
21.5 USGT
FDR: 3.9-4.1
Timing: 46-48* measured on Motolyser
Rotor: S-HIGH
Fan: Yes
17.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.1-4.4
Rotor: S-HIGH
Fan: Yes
17.5 TC (Outdoor/Larger Tracks)
FDR: 3.8-4.0
Rotor: S-HIGH
Fan: Yes
17.5 1/12
Rollout: 83-85mm
Rotor: S-MID
Fan: No
13.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.7-4.9
Rotor: S-HIGH
Fan: Yes
13.5 TC (Outdoor/Larger Tracks)
FDR: 4.4-4.6
Rotor: S-HIGH
Fan: Yes
13.5 1/12
Rollout: 78-80mm
Rotor: S-MID
Fan: No
WGTR
Rollout: 73mm
Timing: 46
Rotor: S-MID for larger tracks. S-HIGH for smaller tracks, or tracks with black carpet.
17.5 2WD Buggy
FDR: 5.85-6.0
Timing: 45-48*
Rotor: S-HIGH
Fan: Yes
17.5 2WD SC & Stadium Truck
FDR: 7.5-7.8
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
13.5 4WD Buggy
FDR: 7.0-7.2
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
Following are starting points for Mod motors in the MC1 line
7.5 2WD Buggy
FDR: 10.2
Timing: @ 28*
Rotor: M-MID
Fan: Optional
5.5 TC
FDR: 7.0-7.2
Timing: @ 30*
Rotor: M-HIGH
Fan: Optional
4.5 TC
FDR: 7.6-7.8
Timing: @ 20*
Rotor: M-HIGH
Fan: Optional
Every MOTIV Motor is hand checked, assembled and packaged by a professional in house at our WI, USA office. During this process every motor component must meet MOTIV requirements before assembly and packaging. Included is a specification check list which is filled out on a motor to motor basis all through the testing and assembly process to ensure the quality of our finished product
How its Made: Motiv RC Brushless Motor assembly w/ Paul Lemieux
Print Wikipost
Like Tree67Likes
Old 07-25-2016, 09:21 AM   #241
R Dodge's Avatar
Originally Posted by tbrymer View Post
I would guess you just purchase it
You can buy them separate if you already have the motor. If you want to order a motor with the high rotor already installed you'll need to email them and specify that.
Hope that helps clarify.
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is offline   Reply With Quote
Old 07-26-2016, 11:20 AM   #242
Dan
Dan's Avatar
Trader Rating: 46 (100%+)
Are there future plans to release a battery in the 6000-6300mah range? Seems like a large gap between mah and weight. It is one of the reasons I decided to go with another brand battery.
Dan is offline   Reply With Quote
Old 07-26-2016, 12:30 PM   #243
Trader Rating: 15 (100%+)
What is the application?
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 07-26-2016, 05:40 PM   #244
Dan
Dan's Avatar
6 minute stock or mod touring car on a large track.
Old 07-29-2016, 11:00 PM   #245
Tandum4056's Avatar
Trader Rating: 110 (100%+)
What rotor comes stock on the 5.5T, mid or high?
Tandum4056 is offline   Reply With Quote
Old 07-30-2016, 07:07 AM   #246
R Dodge's Avatar
Hi Tandum,
The 5.5 should come standard with the "M-Mid" rotor. If you want the High rotor, you'll need to send an email after you place the order & they will build one per your request.
Old 08-01-2016, 01:08 PM   #247
Default Shocked
Just got a m code17.5t to replace my 24k and it so down on power on the motor checker
24k at 6 amps is about 3200kv at 25000rmp
M Code at 7.1 amp only make 2900 at 22500rpm
For the price £85 let's say I am disappointed my £60 team wave that's had a hard life gets into 3-3100 Kv at 6 amps 22000rpm so m code is over price for the performance
tcboy1983 is offline   Reply With Quote
Old 08-01-2016, 01:54 PM   #248
Dan
Dan's Avatar
You cannot compare it like that and say it is a bad motor based on that. I'm willing to bet the Motiv has boat loads more torque.
Old 08-01-2016, 02:36 PM   #249
24 k has the most torque I have felt plus rpm
So to get the speed I need to match 24 k at 3.7-3.5 fdr would be 2.8 or lower
Guess if that is all torque it only good for indoors town hall ,big tracks it's going to be creamed down the straight
Old 08-01-2016, 02:40 PM   #250
howardcano's Avatar
Trader Rating: 35 (100%+)
That's why we change gear ratios to match the motor to the car and track.
Howard Cano
When race results are re-calculated using the IOF (Index Of Fun), I always win.
1993 ROAR 1/8 Pan National Champion
howardcano is offline   Reply With Quote
Old 08-01-2016, 07:00 PM   #251
R Dodge's Avatar
tcboy,
What are your track dimensions? I doubt you will need to change gearing that much, you will probably be fine around the 3.5 range you currently run. Please run the motor, play with the gearing a little bit and if you are displeased with the performance, please send me a pm.
Thanks,
Robbie
Old 08-01-2016, 09:00 PM   #252
Smile
That's a little harsh... You also need to consider that stronger magnets will decrease the rpms a bit, while the 24k rpm under load will be very different from the bench test...Please try 3.2fdr to 3.35fdr with low timing(35 degrees) if your track is very large....
bertrandsv87 is offline   Reply With Quote
Old 08-01-2016, 09:53 PM   #253
Phil Trotta's Avatar
You cannot just set any motor at 6 amps and expect the most out of it
Some motors yield great results at 4-5 amps with less rpm
Excessive amp and rpm only leads to a fade in power ... From my testing along with guys I'm running with
Each motor has a sweet spot of rpm . Kv and amp draw when combined with gearing to the track can lead to a motor that pulls off the corner and has excellent straitaway speed
I've ran motiv 17.5 with fantastic results in short course . Buggy. Tc. And 1/12
PHIL TROTTA
Phil Trotta is offline   Reply With Quote
Old 08-02-2016, 09:00 AM   #254
I would have to drop the gearing to 2.85 I worked out to get same speed with the Rpm I am getting at 6 amps so if I go 4-5 amps gods knows how low I need to go and I tune around 6amps that's as we find at our track nearly every motor stays about 40-50drg c, more amps just makes heat less amps u see ppl fly past u on the straights think this motor would be suited to off road
Old 08-02-2016, 10:30 AM   #255
Not familiar with the 24K motor but if its similar to the D4, the comparison on the track between the 2 motors we have found that, although the test numbers don't dictate it, but the D4 was more of a torque motor and the Motiv has a much smoother driveable power delivery. Don't get fooled by FDR comparisons, but determine what the track is actually looking for for a FDR and tune your current draw to that. At a 2.85 you'll run out of track before the motor gets up there, but how does it perform in the infield? Where do you spend the most time on the track, the infield or the straight? Thats what your really tuning for.
Rodney Racer is offline   Reply With Quote
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
syllag1969
