    Hide Wikipost
Old 03-29-2017, 02:04 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Motiv RC
Last edit by: R Dodge
NEW FOR 2017 - MC2!
MOTIV M-Code motors, now MC2 for 2017, come pre-set to perform well in most applications. Each MOTIV M-Code motor comes with a specification check list specific to that individual motor. All MOTIV M-Code spec motors come standard with the new "S-HIGH" rotor. If you prefer a different rotor, please send an email via the "Contact Us" page on the Motiv site and reference your order.
Motiv dealers in the U.S. that have received MC2s are:
ProLevel RC
Fordham Hobbies
Lefthander RC
TQ RC Racing
Activ RC
Gripworks RC
Stormer Hobbies
AMain Hobbies
NorCal Hobbies
& More - Check your local hobby shop!
“Defy” Series Pro Li-Po battery weights
“Shorty” 2 Cell, 7.4v, 5000mah, 65c+ - 215 grams
“Thin Shorty” 2 Cell, 7.4v, 3900mah, 65c+ - 159 grams
2 Cell, 7.4v, 5000mah, 60c+ - 258 grams
2 Cell, 7.4v, 6000mah, 90c+ - 311 grams
Following are some suggested starting points for the MC2 line of motors for each class (we will update/add to this as often as possible). One key piece to pay attention to when adjusting your motor is Amp Draw. Try to keep spec motors around 3.0.
25.5 F1
FDR: 2.9-3.2
Timing: 42-45* measured on Motolyser
Rotor: 12.3mm standard
Fan: Yes
25.5 USVTA
FDR: 3.6-3.9
Timing: 44-46* measured on Motolyser
Fan: Yes
21.5 USGT
FDR: 3.9-4.1
Timing: 46-48* measured on Motolyser
Rotor: S-HIGH
Fan: Yes
17.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.1-4.4
Rotor: S-HIGH
Fan: Yes
17.5 TC (Outdoor/Larger Tracks)
FDR: 3.8-4.0
Rotor: S-HIGH
Fan: Yes
17.5 1/12
Rollout: 83-85mm
Rotor: S-MID
Fan: No
13.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.7-4.9
Rotor: S-HIGH
Fan: Yes
13.5 TC (Outdoor/Larger Tracks)
FDR: 4.4-4.6
Rotor: S-HIGH
Fan: Yes
13.5 1/12
Rollout: 78-80mm
Rotor: S-MID
Fan: No
WGTR
Rollout: 73mm
Timing: 46
Rotor: S-MID for larger tracks. S-HIGH for smaller tracks, or tracks with black carpet.
17.5 2WD Buggy
FDR: 5.85-6.0
Timing: 45-48*
Rotor: S-HIGH
Fan: Yes
17.5 2WD SC & Stadium Truck
FDR: 7.5-7.8
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
13.5 4WD Buggy
FDR: 7.0-7.2
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
Following are starting points for Mod motors in the MC1 line
7.5 2WD Buggy
FDR: 10.2
Timing: @ 28*
Rotor: M-MID
Fan: Optional
5.5 TC
FDR: 7.0-7.2
Timing: @ 30*
Rotor: M-HIGH
Fan: Optional
4.5 TC
FDR: 7.6-7.8
Timing: @ 20*
Rotor: M-HIGH
Fan: Optional
Every MOTIV Motor is hand checked, assembled and packaged by a professional in house at our WI, USA office. During this process every motor component must meet MOTIV requirements before assembly and packaging. Included is a specification check list which is filled out on a motor to motor basis all through the testing and assembly process to ensure the quality of our finished product
How its Made: Motiv RC Brushless Motor assembly w/ Paul Lemieux
Print Wikipost
Like Tree59Likes
Old 07-07-2016, 02:41 AM   #226
R Dodge's Avatar
Originally Posted by madness View Post
I have read the above Wiki guide for gearing. I do have a question, my car has a 1.83 final drive ratio which is very different of what most of the cars in the marketplace are using (mostly 1.9 to 2.0). Should I gear the motor to get less RPM and more torque to offset the rather high FDR of my car? I feel the car lacking punch with the current gearing I'm using for a 21.5 motor on a big track (leisure hours). Using a final drive of 3.7.
Originally Posted by RC Professor View Post
Not sure how gearing influences motor characteristics from one car's internal ratio to another, but a few weeks ago I ran a Motiv 21.5 in touring with a 3.88 final drive and 48* timing with good results. My car has a 1.9 internal gear ratio. This was for a smaller track, and torque seemed fine. So, try getting closer to the high 3.8's in FDR and see how that works.
Agree w/ Professor. I would start out with his suggestion of gearing lower, in the 3.85-3.89 range if possible.
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is offline   Reply With Quote
Old 07-07-2016, 05:08 AM   #227
how good is your battery if your battery is old you will lack punch get a new battery with 100c and try it again
ScottZ is offline   Reply With Quote
Old 07-07-2016, 04:59 PM   #228
i was reading the wiki above it is says the 17.5 is for a tc or 1/12. is there one that could/should be used for 1/10 2wd buggy?
rekim is offline   Reply With Quote
Old 07-07-2016, 06:10 PM   #229
Dan Hamann's Avatar
Trader Rating: 14 (100%+)
Motiv doesn't have "class" specific motors listed, but utilizing the Contact Us page on the site will allow you to purchase a motor purpose built for what class you desire. In this case, I'd denote the class you plan on running, and ask for an S-High rotor. The timing will then be preset where it would be recommended to run at.
RCAmerica - Xray - Hudy - RC^2 - Motiv - Team EAM - Sanwa - Avid - Max.FX - Protoform - Pro-Line - Gravity R/C - Prolevel R/C - 2MM Designs
Dan Hamann is offline   Reply With Quote
Old 07-08-2016, 02:36 AM   #230
R Dodge's Avatar
Thanks Dan!
The wiki is just a suggested starting point for the classes that are listed. If a class is not listed, it's just because I don't have info for that class. I'll work on getting that from Paul and others who have run them. Didn't intentionally skip any classes, sorry.
Old 07-08-2016, 07:39 AM   #231
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
The motors work very well in 2wd off-road. I only have a S-mid rotor in mine with timing set around 45 degrees. I can't imagine how much faster I could crash my car, my reflexes are getting slower, if I had a S-high rotor.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 07-08-2016, 07:48 AM   #232
R Dodge's Avatar
Thanks for the feedback Kraig! We can add this info to the Wikipost. Was this 17.5? What FDR were you running? Did you use a fan?
Old 07-08-2016, 09:52 AM   #233
Super Moderator
Kraig's Avatar
I will let you post it in the wiki where you would like it to show up.
17.5 2wd
FDR: 6.06
Timing: ~45 on the can
Rotor: S-MID
Fan: No
Old 07-22-2016, 03:10 AM   #234
R Dodge's Avatar
Wikipost updated
Paul and team have been working hard... The Motiv shop is fully stocked! Check out http://motivrc.com/store/ for all the latest Motiv products
Old 07-24-2016, 07:14 PM   #235
rcaddict13's Avatar
Trader Rating: 67 (100%+)
Default motiv battery weight
does anybody know what the battery weight is the motiv 5000mah compaired to the 7200mah ?
Xray t4 17 >< xray nt1 >< top sabre s4 >< ripon r/c raceway >< Gensace >< Hobbywing
rcaddict13 is offline   Reply With Quote
Old 07-24-2016, 09:31 PM   #236
tbrymer's Avatar
Do the Motiv motors come with the high strength rotor, or the medium strength?
CRC - C&C Motorsports - SpeedZone
tbrymer is offline   Reply With Quote
Old 07-24-2016, 09:47 PM   #237
Schwarta's Avatar
Medium is stock.
Schwarta is offline   Reply With Quote
Old 07-25-2016, 05:29 AM   #238
Super Moderator
Kraig's Avatar
If you look in the Wiki it explains how you can get the high strength rotor.
Old 07-25-2016, 06:53 AM   #239
Trader Rating: 20 (100%+)
5000 Motiv lipo's are 258g.
The 7800 Motiv's are 321g.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 07-25-2016, 09:18 AM   #240
tbrymer's Avatar
I would guess you just purchase it
