    Hide Wikipost
Old 03-29-2017, 02:04 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Motiv RC
Last edit by: R Dodge
NEW FOR 2017 - MC2!
MOTIV M-Code motors, now MC2 for 2017, come pre-set to perform well in most applications. Each MOTIV M-Code motor comes with a specification check list specific to that individual motor. All MOTIV M-Code spec motors come standard with the new "S-HIGH" rotor. If you prefer a different rotor, please send an email via the "Contact Us" page on the Motiv site and reference your order.
Motiv dealers in the U.S. that have received MC2s are:
ProLevel RC
Fordham Hobbies
Lefthander RC
TQ RC Racing
Activ RC
Gripworks RC
Stormer Hobbies
AMain Hobbies
NorCal Hobbies
& More - Check your local hobby shop!
“Defy” Series Pro Li-Po battery weights
“Shorty” 2 Cell, 7.4v, 5000mah, 65c+ - 215 grams
“Thin Shorty” 2 Cell, 7.4v, 3900mah, 65c+ - 159 grams
2 Cell, 7.4v, 5000mah, 60c+ - 258 grams
2 Cell, 7.4v, 6000mah, 90c+ - 311 grams
Following are some suggested starting points for the MC2 line of motors for each class (we will update/add to this as often as possible). One key piece to pay attention to when adjusting your motor is Amp Draw. Try to keep spec motors around 3.0.
25.5 F1
FDR: 2.9-3.2
Timing: 42-45* measured on Motolyser
Rotor: 12.3mm standard
Fan: Yes
25.5 USVTA
FDR: 3.6-3.9
Timing: 44-46* measured on Motolyser
Fan: Yes
21.5 USGT
FDR: 3.9-4.1
Timing: 46-48* measured on Motolyser
Rotor: S-HIGH
Fan: Yes
17.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.1-4.4
Rotor: S-HIGH
Fan: Yes
17.5 TC (Outdoor/Larger Tracks)
FDR: 3.8-4.0
Rotor: S-HIGH
Fan: Yes
17.5 1/12
Rollout: 83-85mm
Rotor: S-MID
Fan: No
13.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.7-4.9
Rotor: S-HIGH
Fan: Yes
13.5 TC (Outdoor/Larger Tracks)
FDR: 4.4-4.6
Rotor: S-HIGH
Fan: Yes
13.5 1/12
Rollout: 78-80mm
Rotor: S-MID
Fan: No
WGTR
Rollout: 73mm
Timing: 46
Rotor: S-MID for larger tracks. S-HIGH for smaller tracks, or tracks with black carpet.
17.5 2WD Buggy
FDR: 5.85-6.0
Timing: 45-48*
Rotor: S-HIGH
Fan: Yes
17.5 2WD SC & Stadium Truck
FDR: 7.5-7.8
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
13.5 4WD Buggy
FDR: 7.0-7.2
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
Following are starting points for Mod motors in the MC1 line
7.5 2WD Buggy
FDR: 10.2
Timing: @ 28*
Rotor: M-MID
Fan: Optional
5.5 TC
FDR: 7.0-7.2
Timing: @ 30*
Rotor: M-HIGH
Fan: Optional
4.5 TC
FDR: 7.6-7.8
Timing: @ 20*
Rotor: M-HIGH
Fan: Optional
Every MOTIV Motor is hand checked, assembled and packaged by a professional in house at our WI, USA office. During this process every motor component must meet MOTIV requirements before assembly and packaging. Included is a specification check list which is filled out on a motor to motor basis all through the testing and assembly process to ensure the quality of our finished product
How its Made: Motiv RC Brushless Motor assembly w/ Paul Lemieux
Print Wikipost
Like Tree68Likes
Old 05-09-2016, 03:56 PM   #196
R Dodge's Avatar
Originally Posted by MikeR View Post
Hi All,
I'm shopping for a 25.5 motor and noticed your descriptions says it's 'short stacked'. It's not actually short stack is it? Apparently SS is not allowed in ROAR 25.5 but I wouldn't mind getting one if the Motiv description was true
M-CODE
FEATURES
STATOR
- Short stack design for low resistance
http://motivrc.com/store/#!/M-CODE-2...540/p/56906821
Hey Mike,
The stator is at the ROAR minimum so it is within spec.
Thanks!
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is offline   Reply With Quote
Old 05-17-2016, 02:42 PM   #197
RotorTruck's Avatar
How many grams does the 17.5 weigh?
-Brad
RotorTruck is offline   Reply With Quote
Old 05-17-2016, 02:43 PM   #198
AlexPate's Avatar
Trader Rating: 19 (100%+)
157-159 can't remember exact
AlexPate is offline   Reply With Quote
Old 05-19-2016, 02:26 PM   #199
I'm a newbie to motor timing and I just picked up a Motiv 17.5. I noticed the end bell was set to almost the max timing setting. The included build/setup sheet says it was at 49 degrees.
Does this mean I will not have any room to adjust to add?
Thank you in advance for your help
rcfan3 is offline   Reply With Quote
Old 05-19-2016, 04:00 PM   #200
R Dodge's Avatar
Hey rcfan3,
The timing can go past the 50 line, so there is still room. Mine at 53 on the motolyser is a little past that last line. 49 is a safe starting point for most applications.
Old 05-19-2016, 04:49 PM   #201
Originally Posted by R Dodge View Post
Hey rcfan3,
Awesome! Appreciate the help.
Old 05-25-2016, 06:02 AM   #202
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
This video explains a little bit about what goes into a Motiv motor.
+ YouTube Video
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 05-25-2016, 10:32 AM   #203
Skiddins's Avatar
Why do I get sound for every other Youtube video, but not this one?
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 05-26-2016, 08:38 AM   #204
DBM
I've been running my 17.5 m-code with h rotor for a couple of weeks now. Fantastic motor. Much smoother and easier to drive than my D4ss that I was previously using. Very broad power band....it pulls good everywhere. Now I know why m-code powered cars were faster than me at the end of the straight when I was running the D4ss.
DBM is offline   Reply With Quote
Old 05-27-2016, 07:54 AM   #205
Dino_D's Avatar
+1 thats why I switched too.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 05-28-2016, 09:01 PM   #206
Trader Rating: 20 (100%+)
Did y'all watch that video? I think Paul nailed it there.
In my big box-O-spec-motors I have three Motiv spec motors, three generations of Trinity/Revtech motors, ORCA motors, R1 motors, LRP motors, Reedy, and Tekin's represented. The Motiv motors are the only ones that are dead on when I check them and need no adjustment to run their best out of the box. I'm really impressed with how good the sensor boards are matched and how close the out of the box timing is set to perfection with these motors. Together these things mean that anyone can put a Motiv in and have confidence that that motor is truly race ready.
Don't bother with the fancy checking tools, dyno's, etc.. Just buy a Motiv, bolt it in and have fun.
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 06-07-2016, 05:33 AM   #207
How good is the motor to the other ones like D4 and R1
21.5 or 13.5
B.cassidy is online now   Reply With Quote
Old 06-07-2016, 05:40 AM   #208
R Dodge's Avatar
21.5 or 13.5
I've run both the 21.5 and 13.5 Motiv motors & both were very fast. I haven't run an R1 before, but I ran the D4 1s plenty before switching to Motiv. I've never felt that any of my Motiv motors have been at a disadvantage to any other brand.
Old 06-07-2016, 08:00 AM   #209
AlexPate's Avatar
21.5 or 13.5
I never used a d4 1s but I have run r1. Power is very comparable between the two. R1 feels like it has more rpm power band and motiv feels more like amid power band. That being said the motiv is the smoothest motor I have run.
13.5 worked very well all season in stk 1/12
21.5 is perfect for f1. The smoothness of the motor adds loads of drivability to the car.
Old 06-07-2016, 07:50 PM   #210
Schwarta's Avatar
Bought a high strength rotor for my blinky 13.5t (touring), what type of gearing change should I start with going from the stock rotor?
Schwarta is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
