    Hide Wikipost
Old 03-29-2017, 02:04 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Motiv RC
Last edit by: R Dodge
NEW FOR 2017 - MC2!
MOTIV M-Code motors, now MC2 for 2017, come pre-set to perform well in most applications. Each MOTIV M-Code motor comes with a specification check list specific to that individual motor. All MOTIV M-Code spec motors come standard with the new "S-HIGH" rotor. If you prefer a different rotor, please send an email via the "Contact Us" page on the Motiv site and reference your order.
Motiv dealers in the U.S. that have received MC2s are:
ProLevel RC
Fordham Hobbies
Lefthander RC
TQ RC Racing
Activ RC
Gripworks RC
Stormer Hobbies
AMain Hobbies
NorCal Hobbies
& More - Check your local hobby shop!
“Defy” Series Pro Li-Po battery weights
“Shorty” 2 Cell, 7.4v, 5000mah, 65c+ - 215 grams
“Thin Shorty” 2 Cell, 7.4v, 3900mah, 65c+ - 159 grams
2 Cell, 7.4v, 5000mah, 60c+ - 258 grams
2 Cell, 7.4v, 6000mah, 90c+ - 311 grams
Following are some suggested starting points for the MC2 line of motors for each class (we will update/add to this as often as possible). One key piece to pay attention to when adjusting your motor is Amp Draw. Try to keep spec motors around 3.0.
25.5 F1
FDR: 2.9-3.2
Timing: 42-45* measured on Motolyser
Rotor: 12.3mm standard
Fan: Yes
25.5 USVTA
FDR: 3.6-3.9
Timing: 44-46* measured on Motolyser
Fan: Yes
21.5 USGT
FDR: 3.9-4.1
Timing: 46-48* measured on Motolyser
Rotor: S-HIGH
Fan: Yes
17.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.1-4.4
Rotor: S-HIGH
Fan: Yes
17.5 TC (Outdoor/Larger Tracks)
FDR: 3.8-4.0
Rotor: S-HIGH
Fan: Yes
17.5 1/12
Rollout: 83-85mm
Rotor: S-MID
Fan: No
13.5 TC (Indoor/Small-Std. size Tracks)
FDR: 4.7-4.9
Rotor: S-HIGH
Fan: Yes
13.5 TC (Outdoor/Larger Tracks)
FDR: 4.4-4.6
Rotor: S-HIGH
Fan: Yes
13.5 1/12
Rollout: 78-80mm
Rotor: S-MID
Fan: No
WGTR
Rollout: 73mm
Timing: 46
Rotor: S-MID for larger tracks. S-HIGH for smaller tracks, or tracks with black carpet.
17.5 2WD Buggy
FDR: 5.85-6.0
Timing: 45-48*
Rotor: S-HIGH
Fan: Yes
17.5 2WD SC & Stadium Truck
FDR: 7.5-7.8
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
13.5 4WD Buggy
FDR: 7.0-7.2
Timing: 45-47*
Rotor: S-HIGH
Fan: Yes
Following are starting points for Mod motors in the MC1 line
7.5 2WD Buggy
FDR: 10.2
Timing: @ 28*
Rotor: M-MID
Fan: Optional
5.5 TC
FDR: 7.0-7.2
Timing: @ 30*
Rotor: M-HIGH
Fan: Optional
4.5 TC
FDR: 7.6-7.8
Timing: @ 20*
Rotor: M-HIGH
Fan: Optional
Every MOTIV Motor is hand checked, assembled and packaged by a professional in house at our WI, USA office. During this process every motor component must meet MOTIV requirements before assembly and packaging. Included is a specification check list which is filled out on a motor to motor basis all through the testing and assembly process to ensure the quality of our finished product
How its Made: Motiv RC Brushless Motor assembly w/ Paul Lemieux
Print Wikipost
Like Tree67Likes
Old 02-23-2016, 10:20 AM   #151
Originally Posted by R Dodge View Post
Sorry I didn't get back sooner, I messaged Paul this morning and he responded with the following,
"If this a blinky class he will want the mid or high rotor with 40 to 45 deg timing, gear accordingly as we do not know. if this is for boosted the 12.3mm rotor would likely work best but this is totally un tested to us."
What rotor comes in the motors stock? Are they all 12.5 rotors? Thanks
JIJ5 is offline   Reply With Quote
Old 02-23-2016, 10:45 AM   #152
Trader Rating: 15 (100%+)
Yes, other than motors for classes that only allow 12.3 rotors, all motors come with a 12.5 rotor.
Chris Hillier | 5280 Raceway | www.5280raceway.com | Racing. Elevated.
Destiny | LRP America | Protoform | Xenon/JFT | Gravity RC | Motiv | Sanwa | Max.FX
LloydLoar is offline   Reply With Quote
Old 02-26-2016, 01:56 PM   #153
RoyB's Avatar
Trader Rating: 16 (100%+)
Put a 21.5 Motiv motor in my USGT car. Took it to practice on a carpet track with 80' straight and a pretty technical layout. Endbell timing 44* like it came. Gearing at 3.7. Motor was coming off track at 100 to 105 degrees after 6 minutes. Gear up to 3.6 and temp stayed the same. Is that normal for Motiv motors?
RoyB is offline   Reply With Quote
Old 02-26-2016, 03:17 PM   #154
Sam Isaacs's Avatar
Trader Rating: 20 (100%+)
Hello. I would suggest turning the timing up 3-4 degrees and checking the temp and going from there. 3.6-3.7 should be right around where you need to be for gearing. The timing will probably increase as the timing is turned up. Try setting to 47 degrees to see how it runs for you.
Sam
Awesomatix USA, Roche RC USA, Sanwa, Avid, TQ Wire, PCR, Team EAM, 2mm Designs, Timmy, CR Graphics MRH, JMR
Sam Isaacs is offline   Reply With Quote
Old 02-26-2016, 03:57 PM   #155
R Dodge's Avatar
Yea 44* sounds low. The gear sounds right, maybe actually a little overgeared. Timing should be around 49 or 50 really. I'd try timing in steps tho, don't just jump right to 49, start at 47 like Sam suggested and check temps.
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is online now   Reply With Quote
Old 02-26-2016, 07:17 PM   #156
RoyB's Avatar
Could someone tell me what size the flathead screws in the endbell are. Just went to adjust my timing and noticed the screw heads are messed up. Want to get new screws before i take them out.
Old 02-27-2016, 03:03 AM   #157
R Dodge's Avatar
I don't know the size but Paul sells them in a kit (link below). I'll try to get a measurement for you today though.
http://motivrc.com/#!/M-CODE-Hardwar...egory=15409191
Old 02-28-2016, 05:51 AM   #158
Sam Isaacs's Avatar
25.5, 17.5 and some modified winds should be instock towards the end of this week, with more spec winds coming in the following week. Look for the site to be updated and reflect this by the end of the week if everything works out.
Thanks!
Sam
Old 02-28-2016, 04:56 PM   #159
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
How are your lap times?
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 02-28-2016, 05:29 PM   #160
RoyB's Avatar
I put the timing at 47*, gearing to 3.8. My fast lap times were within .4 seconds of the fast guys. I only got to run 2 1/2 heats, so not much track time. Thats good for me I am a b main driver.
Old 03-23-2016, 08:49 PM   #161
Ok guys maybe I'm just stupid but should I be able to adjust timing by loosening the three screws above th sensor board?
Ol_GT is offline   Reply With Quote
Old 03-23-2016, 08:56 PM   #162
AlexPate's Avatar
Trader Rating: 19 (100%+)
Yes. The timing adjustment tends to be stiff.
Alex Pate. www.gripworksrc.com
Motiv Rc, Hobbywing, ORCA, Protoform,
VBC RACING, XRAY, ROCHE, AWESOMATIX, TEAM ASSOCIATED,
ARC,CRC,AVID,MCKUNE DESIGN, PROLINE, JCONCEPTS, GFORCE, MACLAN, R1WURKS
AlexPate is offline   Reply With Quote
Old 03-24-2016, 07:47 AM   #163
Loosen/remove those three screws and then pop the timing endplate off a mm or two and rotate. Way easier.
Old 03-24-2016, 08:13 AM   #164
R Dodge's Avatar
I saw somewhere, maybe FB or something, that someone is making a tool to help adjust the timing. It's basically an open-end wrench that you can use to fine-tune the timing a little easier. Think it was 3D printed. Of course, I cannot find anything on it now.
Old 03-24-2016, 02:45 PM   #165
big_ads's Avatar
Trader Rating: 79 (100%+)
Send a message via MSN to big_ads
https://www.facebook.com/photo.php?f...type=3&theater
Vex Vegaz had it posted on his facebook page.
Adam Balk
Northern Mini Racers (www.facebook.com/groups/northernminiracers/)
Team CRC - Protoform/Pro-line - Big Head Racing - Dumpers Speed Shop
big_ads is offline   Reply With Quote
