Old 10-29-2015, 08:13 AM   #76
Originally Posted by SagadSetup View Post
Hi. I don't know anything about this car but it sure does look nice.
Regarding the upgrade, I'll go for the pink one but that's just me.
Just wondering, can this chassis be configured as a grip car?
It can be but on top of the cost of the kit, you'd have to switch out more parts to do so. Why not just get the Sakura Zero S. The kit is cheaper and with the extra money you save, you can upgrade.
Seanzky is offline   Reply With Quote
Old 10-29-2015, 07:04 PM   #77
Matty J's Avatar
http://os.3racing.hk/products.php?products_key=7315
Steering racks!
Matty J is offline   Reply With Quote
Old 10-29-2015, 08:17 PM   #78
vlozity's Avatar
Originally Posted by Seanzky View Post
i would get the slide track steering (black)
3Racing Sakura D4 RWD & AWD converted to RWD
Tekin RS ESC Tekin Redline 13.5T BL Sensored Savox 1257TG Sanwa MT4
vlozity is offline   Reply With Quote
Old 10-29-2015, 09:21 PM   #79
I have the AWD. Would the slide still be better than the other steering system?
Old 10-30-2015, 07:51 AM   #80
Matty J's Avatar
Slide racks have less overall friction and smoother transition from side to side. Definitely looking forward to picking one up. You can't beat the price either! FXX slideracks hover around $100.
Old 10-31-2015, 06:47 AM   #81
Makes sense! I wish they'd hurry up. I'm really tempted to buy the knock-off CNC steering system on eBay. The stock plastics for the steering are terrible.
Old 11-02-2015, 05:38 AM   #82
Matty J's Avatar
I took some time, drilled some holes and made my D3 into a rear motor setup similar to the D4 AWD. Now I am stuck on the front one way issue. I have the same question as JatotheRipper. What front one way are you drivers using in your D4 AWD?
Old 11-02-2015, 08:49 PM   #83
I'm using the 3Racing fixed one way.
Old 11-03-2015, 08:16 AM   #84
The steering just has so much slop that even though I have my front end dialed in pretty well, the trailing wheel at full lock has enough slop to allow it to rub causing a spin out.
I wish they would hurry up and release the slide rack, body mounts and the aluminum spool diff.
Derigor is offline   Reply With Quote
Old 11-03-2015, 03:04 PM   #85
You said it, buddy. Steering should have never been designed this way.
Old 11-03-2015, 04:44 PM   #86
Matty J's Avatar
The mods keep coming...
http://www.usukani.com
Old 11-03-2015, 04:44 PM   #87
What do you guys recommend as far as a motor for this car?
TRoy9696 is offline   Reply With Quote
Old 11-03-2015, 06:55 PM   #88
I'm very happy with my sensored brushless TrackStar 10.5T /w 120A Turbo ESC. Very programmable, smooth, and easy to drift with (if it wasn't for the steering locking up).
Old 11-04-2015, 10:53 AM   #89
vlozity's Avatar
just took the D4 for a spin around the track... darn steering arm broke argh!
good thing i had a spare donor D4 and swapped the parts and made changes to the setup.
here is a new pic i took today...
Old 11-04-2015, 01:52 PM   #90
How bad is the steering issue with this chassis, I'm looking to get into drifting and really love the look of rwd drifting.
Tags
3racing, d4 awd, d4 rwd, drift, sakura
