need a new charger
need a new charger
looking to get a new charger since my charger took a crap on me. looking for something with a built in power supply and preferably a motor run feature. i was looking at these two chargers:
http://integy.automated-shops.com/cg...58105142242.7b
both priced the same. any other chargers out there you guys like? i like the first one cuz its a lot smaller. i dont want a turbo cuz they are huge. something 250 or less. i also heard novak was coming out with a new charger similar to the 1st integy charger. does anybody have any info on it?
anybody else have an opinion? some help would be greatly appreciacted
Any resason why you want the built-in power supply? Otherwise, for $250 budget, you can have a lot more possibilities (even with the extra cost of an external power supply). Otherwise, I'm not sure you can beat the Integy chargers when it comes to chargers with built-in power supplies.
Of the two, the 16X8v6 looks to be the better value (with Li-Po charging, a built-in dyno, and 30 amp discharge).
Between the 2 the 16x8 is the new kid. It can do Li-Po and has the dyno features built in. It also has a higher discharge rate than the 16x9 and th X8 is smaller. But the 16x9 has a built in 14 amp power supply that can be used to power other devices.The 16X9 also has the ability for U to store upto 10 different charge/discharge profiles. I'm not sure if the 16x8 can or not. I have a 16X9 and have had no probelm's with it, but I'm also planning on buying the 16x8 because I need another charger and I like the higher discharge rate it has and the motor run function. j/m .02
Bob
Bob
i want a built in power supply cuz of the size convenience. the 16x8 is relatively small as compared to a lot of other chargers, and the power supply is built in. sure the turbo does everything, but that thing is big. ive had one and its a pain carrying that and a power supply around. i also like the pulsar competition cuz it does a lot. if i can find one of those cheap and a power supply, i might just do that. what other chargers were u guys thinking of? give me a good combo of charger, p/s.
Location: A step closer to where I need to be a step further from where I was
What about the Duratrax Intellipeak ICE like 129.00 from Tower then you can get the Power Supply and all the features you want.
I highly recommend investing in a good power supply. The newest power supply from Pyramid is the PSV-200. It is a 20A switching power supply, and it's only $55. I use this power supply and all I can say is that it is plain awesome.
You can get it here: http://www.buyreliant.com/psupplies/psv200.htm
Buyer Beware
get a PITBULL X3 CHARGER
I would look into the APS Dyno Charge S3. They improved on the older version with added step charging features. This also has a motor checker built in and a temperature probe. For the money, its an awesome charger. The Much More Racing Cell master is also an awesome charger. The only thing that I don't like about it is it doesnt have the motor run in feature like the Dyno charge.
-Korey
-Korey
