Old 10-13-2015, 05:03 AM   #46
Dan Hamann's Avatar
Trader Rating: 14 (100%+)
Originally Posted by disaster999 View Post
Where can you find the left and right rear bulkhead and hub assembly and how much?
Mine came out of a new 2016 kit, they should be shipping from RCAmerica today.
RCAmerica - Xray - Hudy - RC^2 - Motiv - Team EAM - Sanwa - Avid - Max.FX - Protoform - Pro-Line - Gravity R/C - Prolevel R/C - 2MM Designs
Dan Hamann is offline   Reply With Quote
Old 10-18-2015, 04:51 PM   #47
jedx's Avatar
Did anyone find the image in the middle of page 14, where you see the orientation of the left rear wheel hub, is the wrong way around?
(In the Detail box explaining leaving a small amount of side play)
If you install this part as pictured, the wheels do not firmly grip the hub before you screw them on, if you put the larger rib to the outside, then the rear wheels fit how they should..
Also, I ran this car for the first time on Sunday, was a weapon, Ulti XM front, Ulti XSS rear on low grip large asphalt track with a 4.0T. It was on rails with pretty much kit setup, cross-chassis config.
XRAY T4'17 x2 | X1 | X12'16 | XB4 '16 | XB2 CE
Xray | MuchMore | Nosram | PROTOform | Hudy | Proline
jedx is offline   Reply With Quote
Old 11-05-2015, 06:47 PM   #48
Trader Rating: 15 (100%+)
Which servos work without modding or shoe gooing? I see a lot of old threads about hacking servos in and I'm hoping to order a servo that natively fits. Thanks!
Arboleda is offline   Reply With Quote
Old 11-05-2015, 10:06 PM   #49
Car Breaker's Avatar
X12 2016 has universal mount that you slide the servo fir best centering. Therefore any servo that is designed for 1/12 will work
Car Breaker is offline   Reply With Quote
Old 11-13-2015, 06:59 PM   #50
Michael_T's Avatar
Trader Rating: 48 (100%+)
Send a message via MSN to Michael_T
What foam bumper best suits the X12?
I heard CRC and Serpent ones may fit?
I like the look of Hagberg's bumper in the photo below.
Shepherd RC | Brilliant RC | Arrowmax | Xtreme Aerodynamics | Matrix | Tectrade TTB
BlueRC | www.bluerc.net
Michael_T is offline   Reply With Quote
Old 11-13-2015, 07:31 PM   #51
pphaneuf's Avatar
That looks very similar to the Associated 12R5 bumper that I use on mine, which does fit very well:
https://www.teamassociated.com/parts...3-foam_bumper/
pphaneuf is offline   Reply With Quote
Old 11-13-2015, 07:51 PM   #52
Trader Rating: 24 (100%+)
The Associated bumper looks identical to Hagberg's, and is what I have on mine.
fenton06 is offline   Reply With Quote
Old 12-30-2015, 12:15 AM   #53
Any pics of how you mounted futaba bls671 ?
Atownbobby is offline   Reply With Quote
Old 01-22-2017, 03:58 PM   #54
Does anyone have a good method for rebuilding the rear pod with zero tweak , the rear pod is a very awkward shape and I haven't yet found a perfect method for rebuilding it yet , any step by step process would be appreciated , when the track surface is right and the tyres hook up 1/12 is the most fun I've had so far...
BPR Racing is offline   Reply With Quote
