Old 09-25-2015, 05:03 PM   #31
Dan Hamann's Avatar
Trader Rating: 14 (100%+)
Originally Posted by HappyHippo View Post
So will the motor mount fit then ? it looks like top rebel motor mount?
The new rear pod plates/brace assembly will bolt to the 2015 lower pod plate.
RCAmerica - Xray - Hudy - RC^2 - Motiv - Team EAM - Sanwa - Avid - Max.FX - Protoform - Pro-Line - Gravity R/C - Prolevel R/C - 2MM Designs
Dan Hamann is offline   Reply With Quote
Old 09-26-2015, 05:16 AM   #32
jason cheng's Avatar
Trader Rating: 42 (100%+)
Glued graphite and polished 2 complete cars last night dan
Xray X12 2017 x 3 / Ulti / Orca / Motiv / Team EAM / Futaba 4px / Stormer Hobbies/ Gravity Rc/ Dri-Fit Mafia/ menardsracing.com / Usinternet.com / Rc Painting By Mikey
jason cheng is offline   Reply With Quote
Old 09-28-2015, 03:57 PM   #33
pphaneuf's Avatar
Ah, that's excellent news for my X10, thanks for the info!
XRay X10'16, Roche Rapide P12-2017, Roche Rapide P10W, Carisma GT24R
pphaneuf is offline   Reply With Quote
Old 09-28-2015, 05:35 PM   #34
Skiddins's Avatar
The upper carbon servo mount part will also fit the 2015 car.
So the 2016 servo mounting can be used on the old car as well.
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 09-29-2015, 03:19 PM   #35
Trader Rating: 28 (100%+)
Can this be found in the States?
FlyByWire is offline   Reply With Quote
Old 09-29-2015, 03:26 PM   #36
Trader Rating: 108 (99%+)
Ya at discountrcstore.com
He can order it for you.
thecaptain is offline   Reply With Quote
Old 10-12-2015, 04:25 AM   #37
pphaneuf's Avatar
On http://teamxray.com/x12/, they say that "Excess play in the steering block was removed to improve steering response", but it's the same steering block in the X12'15 and X12'16?
For example, the left steering block is 372221 in both models?
There's another steering block, the 372220, that the X10'15 still uses, I'm wondering if this isn't something that they improved compared to the 2014 model (with the X10'15 trailing behind), and just kept the blurb in their page?
Old 10-12-2015, 05:53 AM   #38
Skiddins's Avatar
Could be a running change, so the moulds have changed, but the part number etc remains.
Haven't run my X12 in anger yet.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-12-2015, 05:54 AM   #39
Skiddins's Avatar
THough the fact that the links are in different positions on the '15 and '16 might cause an issue.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-12-2015, 06:56 AM   #40
pphaneuf's Avatar
Ah, that'd be annoying (making ordering new parts a lottery), if I'm trying to update my other car to have less play...
Old 10-12-2015, 07:55 AM   #41
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Dan means the Alumn bulkheads fit right on the 2015 lower pod plate. So it wouldnt be an issue at all. Just put the alumn pod plates on and new cross tube and your good to go.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 10-12-2015, 09:46 PM   #42
barg's Avatar
Send a message via Yahoo to barg
Hey guys.
My first new 1/12th build in almost 20 years. Have been playing nitro since then.
Anyway i started building last night and stuffed up one of the first steps by putting the steel pivot balls in the bottom arms instead of the carbon ones.
Is it possible to get them back out or would i do too much damage? Any tips would be great.
XRAY NT1-2015 Spec | Max Power Engines | KO KIY EX10 | Protoform | Matrix Tires | XRAY X12-16
HEI International | www.hobbyexpress.com.au
www.nswrcrcc.com
barg is offline   Reply With Quote
Old 10-12-2015, 11:30 PM   #43
Regional Moderator
disaster999's Avatar
Where can you find the left and right rear bulkhead and hub assembly and how much?
disaster999 is offline   Reply With Quote
Old 10-13-2015, 01:50 AM   #44
Skiddins's Avatar
Originally Posted by barg View Post
Hey guys.
If you use a pivot ball remover you should be fine, the alternative is to get another pair of steel balls to use in the upper arms.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 10-13-2015, 04:56 AM   #45
barg's Avatar
Thanks. I already ordered a 2nd set of steel pivot balls today. Should be here tomorrow. Will try a mates pivot ball remover on the lower arms when I see him
www.nswrcrcc.com
