Old 07-23-2016, 03:12 AM   #61
1spunspur's Avatar
Good post G-rem. Looks like Roche is not afraid to step out of the norm.
P./
1spunspur is offline   Reply With Quote
Old 07-23-2016, 04:46 AM   #62
hanulec's Avatar
Trader Rating: 27 (100%+)
New thread for 235mm car
Roche Rapide P10W 1/10 235mm Competition Pan Car Kit
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 07-24-2016, 09:32 PM   #63
Hey folks
Had one of these lying around on my shelf for ages. I want to try this out on asphalt and don't want to put it on the track with my Montech m10 body so I bought a Blitz 200mm nitro VDS style body for it and noticed it's much narrower. Measured things up and seems the outer edges of my wheels actually 190mm not 200mm. Have I missed something here? Thought the car was 200mm
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P10 & P12 & F1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
ST - Losi 22T 2.0
WagwanBumba is offline   Reply With Quote
Old 07-25-2016, 04:15 AM   #64
hanulec's Avatar
The car is 200mm. Setup and axle shims used to adjust it..
Front end is usually a bit narrower.
Old 08-23-2016, 03:21 AM   #65
pphaneuf's Avatar
This car will take a "normal size" 2S battery pack (similar to those used in touring cars)? I'm sure the 235mm version will, but the 200mm as well?
Also, do you have to unscrew the front shock brace to get the battery out? Not sure about that, but might be better than tape, in some ways...
Is there a 2016 (2017?) version coming? I'm kind of interested, but Zen-Racing, the UK distributor, is out of stock, which at this time of year sometimes means there might be a new version...
XRay X10'16, Roche Rapide P12-2017, Roche Rapide P10W, Carisma GT24R
pphaneuf is offline   Reply With Quote
Old 08-23-2016, 03:34 AM   #66
pphaneuf's Avatar
Oh, another question: the pod bulkheads, are they common parts with the P12? This is a problem with my Xray X10'16, it's very hard to get the ride height to be low enough without truing the tires to death. 54mm is the biggest possible tire diameter, and only gets me down to 5mm (I'd prefer 4mm!). I see other racers with old Associated 10R5.1 cars running 56mm tires and 4mm ride height...
I'm being a bit let down by the second-rate support the X10 is getting from Xray. Tt's not a bad car, but it mainly gets components from the X12 part bins, like those bulkheads, and it has some weaknesses that just don't get much attention from the Xray folks (sloppy front end, which has a non-standard hole distance, so it cannot be replaced with a Xenon one, for example), it seems. The specially designed steering rack, and a 235mm car being worked on seems to indicate that these are getting the attention they deserve! So, it's interesting...
Thanks in advance!
Old 08-23-2016, 03:51 AM   #67
hanulec's Avatar
Stick pack fits
Must need to unscrew
Don't know about a new version... I think the p10w must release first
Old 08-23-2016, 03:52 AM   #68
hanulec's Avatar
Thanks in advance!
Bulkheads are different but 1/12 drill pattern first. P10 are higher so shims aren't needed below the axle holders
Old 08-28-2016, 04:23 PM   #69
pphaneuf's Avatar
Is there a foam bumper that fits the P10 well? Not sure if I'm confident enough in my driving to go without...
Old 08-28-2016, 05:29 PM   #70
hanulec's Avatar
Negative
Old 10-27-2016, 05:59 AM   #71
pphaneuf's Avatar
I'm still having trouble getting a P10, and now they've actually hinted that there might be a new model coming...
They're not going to let me run a P10W at the BRCA Nationals!
Old 02-13-2017, 06:52 AM   #72
What is needed to convert this to rubber WGT-R tires?
tim_s is offline   Reply With Quote
Old 02-16-2017, 01:59 PM   #73
hanulec's Avatar
hi tim - i havent tried this myself -- but u suspect you really just need a bunch of shims. 1) for the front end plate to raise it up 2) for the rear end axle carriers + some long screws
Old 06-17-2017, 04:39 PM   #74
Ruber tyre version (F1 tyres) on Facebook - https://www.facebook.com/photo.php?f...type=3&theater
Some updates to the general car, looks good! I like the look of the Volante F1 wheels, very nice.
Scott Tapsall
Queensland Radio Circuit Car Racing Association
Pine Rivers Model Powerboat Club
Scott_T is offline   Reply With Quote
