Old 10-08-2015, 06:44 PM   #31
hanulec's Avatar
Trader Rating: 27 (100%+)
First P10 setup sheet posted to http://www.rochercusa.com/p/set-up-sheets.html
The WGT class unfortunately had the smallest turn out, so the least amount of time was spent on this car setup. Round 2 the car was super fast, but picking up tires. Post qualifier caster and sauce changes robbed the car from steering. The Q2 setup is what was posted.
http://www.rc50.com/results/2015hall...GT%2013.5.html
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / Shop@ Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 10-08-2015, 09:07 PM   #32
Thanks!!!
RJMcIntyre is offline   Reply With Quote
Old 12-20-2015, 05:33 AM   #33
G-rem's Avatar
Hi everyone,
I've just seen Roche released some inline steering knuckle set for its P10, and I was wondering if it can fit on a AE 10R5.1 or VBC Lightning 200/235mm? I mean: is the outer diameter of the Roche kingpin (330019) the same as others for pan car style front suspension (AE, VBC, Xenon,...)?
Thanks for answering,
Regards,
G-rem
G-rem is offline   Reply With Quote
Old 12-20-2015, 08:10 AM   #34
hanulec's Avatar
These inline wgt steering blocks are for the Xenon front end included within the Rapide P10. Uses a 1/8" kingpin.
Old 12-20-2015, 08:26 AM   #35
G-rem's Avatar
Thanks Mike, I believe it could fit my IRS king pin on my Pro10 car
Old 12-20-2015, 11:07 AM   #36
JRnotEwing's Avatar
I happen to be running this car in the new WGTR class and was breaking front axles consistently. I have since switched to steel front axles from an AE 12R5.2 and haven't broken one since. I think that big rubber was just to much for the al ones
Sponsored by the lack of a bar tab
USVTA T4 15
USGT T4 17
Sedan T4 15
"Two wrongs don't make a right, but three lefts do"
JRnotEwing is offline   Reply With Quote
Old 12-30-2015, 01:51 PM   #37
pullstarter's Avatar
Trader Rating: 14 (100%+)
Has anyone figured out a 235mm conversion for this car yet? I'd like to get the P10 as I have a P12 and that car is awesome! But if I can't do a 235mm conversion I'd have to look elsewhere
Maybe other manufacturers 235mm bits would work?
pullstarter is offline   Reply With Quote
Old 12-31-2015, 08:40 AM   #38
hairymuffin's Avatar
Trader Rating: 93 (100%+)
235mm car is coming soon,check site
hairymuffin is offline   Reply With Quote
Old 12-31-2015, 09:20 AM   #39
1spunspur's Avatar
Which sites? Been looking.
P./
1spunspur is offline   Reply With Quote
Old 12-31-2015, 10:30 AM   #40
Cosmo's Avatar
They mention it on their site, but no info yet:
http://www.rocherc.com/index.php?rou...tegory&path=67
They also have a category for touring cars that wasn't there a few months ago. Maybe hinting at something else?
www.MBRSpeedShop.com - indoor carpet onroad and offroad racing in Roanoke, VA
Cosmo is offline   Reply With Quote
Old 12-31-2015, 11:30 AM   #41
hanulec's Avatar
235mm project delayed until at least Feb 2016 "start"
Old 12-31-2015, 01:00 PM   #42
Thanks guys Can't wait for the 235mm!!
Old 02-15-2016, 07:36 AM   #43
Ph3nyx's Avatar
+ YouTube Video
the first F1 RC resource in french : www.rcf1.fr
Ph3nyx is offline   Reply With Quote
Old 03-22-2016, 03:18 AM   #44
G-rem's Avatar
Hi there,
can someone please tell me if the inline steering axles (#ROC-340062) use metric or imperial nut to secure the wheel? Same question for the little set srew that secure the mount of the knuckle set on the king pin, is that metric or imperial?
Thanks a lot for your help,
Regards,
G-rem
Old 03-22-2016, 03:19 AM   #45
hanulec's Avatar
All metric
