    Hide Wikipost
Old 03-17-2017, 02:10 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Xray T4 2016
Last edit by: R Dodge
Welcome to the XRAY T4'16 Thread & Wikipost! Here you will find some useful info, tips and tricks as well as setups that are used by several team drivers. This wikipost is a work in progress and should continue to develop over time.
Tips & Tricks:
Alex Hagberg's Tech Tip Tuesday articles
How to mount your Protoform LTC-R Body
Setting static camber
How to mount weight on your chassis Part1
How to mount the rear wing on Protoform bodies
Simple troubleshooting guide
How to mount the battery on your chassis
How to glue your front tires for CRC Black carpet with Eric Anderson
Utilizing Exponential and RMode on the M12S
How to mount weight on your chassis Part2
Team driver Tim Wahl posted some very useful tips on Facebook as he worked through building a new kit.
1- Carbon Parts
2-Suspension
3-Solid Axle and Differential
4-Bulkheads & Drivetrain
5-Driveshaft (ECS & CVD)
6-Front & Rear Suspension
7-Tweak
8-Anti-Roll Bar
9-Battery Fix (OPTIONAL)
10-Bumper & Body
11-Shocks
12-Steering
New Graphite Hubs:
Xray have recently released some additional Graphite hubs for the T4 lineup. The 4° Graphite C-Hub has been out for some time and is known to improve steering on entry, and in general makes the car turn better. This has been the go-to c-hub on asphalt for many on the Xray team, though it is not needed on high bite carpet. The Graphite rear hub tends to make the car more stable, especially on corner entry. We are still working on gathering input on the new Graphite steering block, but for the moment feel that it should improve steering response. All Graphite parts are approximately 1g lighter than the Hard or Medium options.
Option Parts to consider:
XRA301196 T4 Graphite Upper Deck 1.6mm V2
XRA301226 Foam Bumper – Hard - highly recommend
XRA302165 Composite Front Suspension Arm 2-Hole – Hard
XRA302169 Composite Front Suspension Arm 1-Hole – Graphite
XRA302803 1.3mm Front Anti-Roll Bar
XRA303169 Composite Rear Suspension Arm 1-Hole – Graphite
XRA303802 1.2mm Rear Anti-Roll Bar
XRA305137 Steel Solid Axle Driveshaft Adapters - HUDY Spring Steel - highly recommend
XRA305242 Composite Drive Shaft Replacement Cap 3.5mm – Orange – Strong (QTY 4)
XRA305351 Aluminum Wheel Hub – Offset “-0.75mm” – Black (QTY 2)
XRA306191 T4 Graphite + Aluminum Fully Adjustable Battery Holder
XRA308264 4S Spring-Set Progressive C=2.5-2.8 (QTY 2)
XRA308276 4S Spring-Set C=2.7 (QTY 2)
XRA308286 4S Spring-Set C=2.6 (QTY 2)
Specific to Asphalt:
XRA302383 Composite C-Hub Right – 4* - Graphite (ECS)
XRA302384 Composite C-Hub Left – 4* - Graphite (ECS)
XRA308039 Aluminum Progressive Shock System – Set (QTY 2)
Specific to Carpet:
XRA301141 T4 Aluminum Flex Chassis 2mm
XRA302375 Composite C-Hub Right – 6* - Hard ***Modification may be required if they don't have the "ECS" stamp.
XRA302376 Composite C-Hub Left – 6* - Hard ***Modification may be required if they don't have the "ECS" stamp.
XRA303711-O Aluminum Rear Lower Suspension Holder – Front – RF
Recent Setups:
3 July 2016 - Alex Hagberg - European Championship - Asphalt - Mod - 2nd
3 July 2016 - Bruno Coelho - European Championship - Asphalt - Mod - 4th
3 July 2016 - Jan Ratheisky - European Championship - Asphalt - 13.5 - TQ + Win
29 June 2016 - Max Kuenning - Reedy - Asphalt - Mod - 4th
29 June 2016 - Keith Yu - Reedy - Asphalt - 13.5 - TQ + 2nd
29 June 2016 - Eric Anderson - Reedy - Asphalt - 13.5 - 3rd
15 May 2016 - Bruno Coelho - ETS Rd 4 Riccione - Asphalt - Mod - TQ + Win
15 May 2016 - Mattia Collina - ETS Rd 4 Riccione - Asphalt - 13.5 - Win
17 April 2016 - Max Kuenning - MHIC - Carpet - Mod - 4th
10 April 2016 - Bruno Coelho - ETS Rd 3 Wels - Carpet - Mod - 2nd
10 April 2016 - Alex Hagberg - ETS Rd 3 Wels - Carpet - Mod - 4th
10 April 2016 - Jan Ratheisky - ETS Rd 3 Wels - Carpet - 13.5 - TQ + Win
22 March 2016 - Paul LeMieux - Canadian Nats - Carpet - Mod - TQ + Win
22 March 2016 - Luke Pittman - Canadian Nats - Carpet - Mod - 3rd
6 March 2016 - Chris Adams - ROAR Nats - Carpet - Mod - TQ + Win
6 March 2016 - Craig Xavier - ROAR Nats - Carpet - 17.5 - 4th
6 March 2016 - Eric Anderson - ROAR Nats - Carpet - 17.5 - 5th
6 February 2016 - Bruno Coelho - ETS Rd 2 Koblenz - Carpet - Mod - TQ + Win
6 February 2016 - Alex Hagberg - ETS Rd 2 Koblenz - Carpet - Mod - 2nd
31 January 2016 - Alex Hagberg - Snowbirds - Carpet - Mod - TQ + Win
31 January 2016 - Jan Ratheisky - Snowbirds - Carpet - All - See Comments
31 January 2016 - Drew Ellis - Snowbirds - Carpet - 13.5 - 4th
31 January 2016 - Robbie Dodge - Snowbirds - Carpet - 17.5 - Win
13 December 2015 - Bruno Coelho - ETS Rd 1 Hrotovice - Carpet - Mod - 3rd
13 December 2015 - Alex Hagberg - ETS Rd 1 Hrotovice - Carpet - Mod - 4th
13 December 2015 - Olly Jeffries - ETS Rd 1 Hrotovice - Carpet - Mod - 7th
13 December 2015 - Jan Ratheisky - ETS Rd 1 Hrotovice - Carpet - 13.5 - TQ + Win
29 November 2015 - Paul LeMieux - US Indoor Champs - Carpet - Mod - TQ + Win
25 October 2015 - Eric Anderson - Stock Wars - Carpet - 17.5 - 2nd
Print Wikipost
Like Tree2Likes
Old 10-03-2015, 12:17 AM   #121
millbank's Avatar
Recieved mine yesterday,
As per usual the kitis beautiful to build.
I'll post some pics later today when i finish the build
millbank is offline   Reply With Quote
Old 10-03-2015, 08:16 AM   #122
Originally Posted by rafyel View Post
Black Edition to boost interest???
+1
Remember Koen
pajenova is offline   Reply With Quote
Old 10-03-2015, 08:19 AM   #123
Originally Posted by pajenova View Post
+1
My 2016 kit will be delivered on Monday, can hardly wait, although I have two 2015's (one of which is a new build never driven). I would immediately buy a Black Edition kit if one was ever released.
Xray T4 2015 /Team Orion R10.1/Scorpion RS-3420 4.5T/RSxone10/Sanwa M12:rx-471
Xray T4 2014 /LRP Flow Worksteam/LRP X20 4.5T/RSxone10/Sanwa M12:rx-472
Xray XB4 /LRP Flow/LRP X20 6.5T/Savox 1251MG/Sanwa M12:rx-471
Durango DEX410v4 /Tekin RSX/Tekin RL 6.5/Savox 1251MG /Sanwa M12:rx-471
rafyel is offline   Reply With Quote
Old 10-03-2015, 05:15 PM   #124
You could easily send off the alloy parts to be re-anodised if you really want a black edition. Cheaper than a whole new kit.
Adelaide RC Team Driver - www.adelaiderc.com.au
Support the Shops that Support the Racers
cplus is offline   Reply With Quote
Old 10-03-2015, 05:36 PM   #125
vabroom's Avatar
You could that, but are you going sent 1 or 2 parts to be anodized that come out during the year? I'm so used to seeing the orange that it doesn't bother me anymore.
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 10-06-2015, 08:28 AM   #126
spencehotbodies's Avatar
Default Purple t415
Destiny RX-10s - Xray X1- Spec-r- nosram -Trinity-Wild turbo fans
West London Race Club
spencehotbodies is offline   Reply With Quote
Old 10-06-2015, 08:33 AM   #127
Old 10-06-2015, 08:35 AM   #128
Default T416 to follow
Old 10-06-2015, 12:33 PM   #129
car looks good
biscuit581 is offline   Reply With Quote
Old 10-07-2015, 01:45 AM   #130
Which are the options you consider a must have?
Lawson1307 is offline   Reply With Quote
Old 10-07-2015, 01:56 AM   #131
DCJs! Oh wait... They're in the box now!
-Mike
Old 10-07-2015, 02:09 AM   #132
-Mike
That's why it costs more
Qatmix is offline   Reply With Quote
Old 10-07-2015, 02:13 AM   #133
Yep I did actually notice that Mike ;-)
Old 10-07-2015, 03:29 AM   #134
daleburr's Avatar
The new car should be great out of the box. The only real options you need are for tuning the handling to different tracks. For tarmac/asphalt I'd recommend:
2.7 springs (2 pairs) - the kit 2.5s are a bit soft for outdoor tracks
1.2 rear rollbar - more turn-in and more traction
1.3 front rollbar - more mid-corner steering
Carbon steering brace (302570) - nice option for tuning steering via flex
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
Old 10-07-2015, 03:31 AM   #135
2.5, 2.6, 2.7 springs. and the progressive springs 2.5-2.8
Also, I do prefer steel outdrives (without using a blade) on the front. More reactive car and more consistent.
Outdoors: 1.3mm front stabilizer and 1.2mm rear.
I also use graphite arms and c-hubs.
www.rcpit.nl , RC dealer
www.machheemstede.nl
..................................Youtube: https://www.youtube.com/watch?v=_-Gkh2xZcQU
Modified 4 life
Govert is offline   Reply With Quote
