    Hide Wikipost
Old 03-17-2017, 02:10 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Xray T4 2016
Last edit by: R Dodge
Welcome to the XRAY T4'16 Thread & Wikipost! Here you will find some useful info, tips and tricks as well as setups that are used by several team drivers. This wikipost is a work in progress and should continue to develop over time.
Tips & Tricks:
Alex Hagberg's Tech Tip Tuesday articles
How to mount your Protoform LTC-R Body
Setting static camber
How to mount weight on your chassis Part1
How to mount the rear wing on Protoform bodies
Simple troubleshooting guide
How to mount the battery on your chassis
How to glue your front tires for CRC Black carpet with Eric Anderson
Utilizing Exponential and RMode on the M12S
How to mount weight on your chassis Part2
Team driver Tim Wahl posted some very useful tips on Facebook as he worked through building a new kit.
1- Carbon Parts
2-Suspension
3-Solid Axle and Differential
4-Bulkheads & Drivetrain
5-Driveshaft (ECS & CVD)
6-Front & Rear Suspension
7-Tweak
8-Anti-Roll Bar
9-Battery Fix (OPTIONAL)
10-Bumper & Body
11-Shocks
12-Steering
New Graphite Hubs:
Xray have recently released some additional Graphite hubs for the T4 lineup. The 4° Graphite C-Hub has been out for some time and is known to improve steering on entry, and in general makes the car turn better. This has been the go-to c-hub on asphalt for many on the Xray team, though it is not needed on high bite carpet. The Graphite rear hub tends to make the car more stable, especially on corner entry. We are still working on gathering input on the new Graphite steering block, but for the moment feel that it should improve steering response. All Graphite parts are approximately 1g lighter than the Hard or Medium options.
Option Parts to consider:
XRA301196 T4 Graphite Upper Deck 1.6mm V2
XRA301226 Foam Bumper – Hard - highly recommend
XRA302165 Composite Front Suspension Arm 2-Hole – Hard
XRA302169 Composite Front Suspension Arm 1-Hole – Graphite
XRA302803 1.3mm Front Anti-Roll Bar
XRA303169 Composite Rear Suspension Arm 1-Hole – Graphite
XRA303802 1.2mm Rear Anti-Roll Bar
XRA305137 Steel Solid Axle Driveshaft Adapters - HUDY Spring Steel - highly recommend
XRA305242 Composite Drive Shaft Replacement Cap 3.5mm – Orange – Strong (QTY 4)
XRA305351 Aluminum Wheel Hub – Offset “-0.75mm” – Black (QTY 2)
XRA306191 T4 Graphite + Aluminum Fully Adjustable Battery Holder
XRA308264 4S Spring-Set Progressive C=2.5-2.8 (QTY 2)
XRA308276 4S Spring-Set C=2.7 (QTY 2)
XRA308286 4S Spring-Set C=2.6 (QTY 2)
Specific to Asphalt:
XRA302383 Composite C-Hub Right – 4* - Graphite (ECS)
XRA302384 Composite C-Hub Left – 4* - Graphite (ECS)
XRA308039 Aluminum Progressive Shock System – Set (QTY 2)
Specific to Carpet:
XRA301141 T4 Aluminum Flex Chassis 2mm
XRA302375 Composite C-Hub Right – 6* - Hard ***Modification may be required if they don't have the "ECS" stamp.
XRA302376 Composite C-Hub Left – 6* - Hard ***Modification may be required if they don't have the "ECS" stamp.
XRA303711-O Aluminum Rear Lower Suspension Holder – Front – RF
Recent Setups:
3 July 2016 - Alex Hagberg - European Championship - Asphalt - Mod - 2nd
3 July 2016 - Bruno Coelho - European Championship - Asphalt - Mod - 4th
3 July 2016 - Jan Ratheisky - European Championship - Asphalt - 13.5 - TQ + Win
29 June 2016 - Max Kuenning - Reedy - Asphalt - Mod - 4th
29 June 2016 - Keith Yu - Reedy - Asphalt - 13.5 - TQ + 2nd
29 June 2016 - Eric Anderson - Reedy - Asphalt - 13.5 - 3rd
15 May 2016 - Bruno Coelho - ETS Rd 4 Riccione - Asphalt - Mod - TQ + Win
15 May 2016 - Mattia Collina - ETS Rd 4 Riccione - Asphalt - 13.5 - Win
17 April 2016 - Max Kuenning - MHIC - Carpet - Mod - 4th
10 April 2016 - Bruno Coelho - ETS Rd 3 Wels - Carpet - Mod - 2nd
10 April 2016 - Alex Hagberg - ETS Rd 3 Wels - Carpet - Mod - 4th
10 April 2016 - Jan Ratheisky - ETS Rd 3 Wels - Carpet - 13.5 - TQ + Win
22 March 2016 - Paul LeMieux - Canadian Nats - Carpet - Mod - TQ + Win
22 March 2016 - Luke Pittman - Canadian Nats - Carpet - Mod - 3rd
6 March 2016 - Chris Adams - ROAR Nats - Carpet - Mod - TQ + Win
6 March 2016 - Craig Xavier - ROAR Nats - Carpet - 17.5 - 4th
6 March 2016 - Eric Anderson - ROAR Nats - Carpet - 17.5 - 5th
6 February 2016 - Bruno Coelho - ETS Rd 2 Koblenz - Carpet - Mod - TQ + Win
6 February 2016 - Alex Hagberg - ETS Rd 2 Koblenz - Carpet - Mod - 2nd
31 January 2016 - Alex Hagberg - Snowbirds - Carpet - Mod - TQ + Win
31 January 2016 - Jan Ratheisky - Snowbirds - Carpet - All - See Comments
31 January 2016 - Drew Ellis - Snowbirds - Carpet - 13.5 - 4th
31 January 2016 - Robbie Dodge - Snowbirds - Carpet - 17.5 - Win
13 December 2015 - Bruno Coelho - ETS Rd 1 Hrotovice - Carpet - Mod - 3rd
13 December 2015 - Alex Hagberg - ETS Rd 1 Hrotovice - Carpet - Mod - 4th
13 December 2015 - Olly Jeffries - ETS Rd 1 Hrotovice - Carpet - Mod - 7th
13 December 2015 - Jan Ratheisky - ETS Rd 1 Hrotovice - Carpet - 13.5 - TQ + Win
29 November 2015 - Paul LeMieux - US Indoor Champs - Carpet - Mod - TQ + Win
25 October 2015 - Eric Anderson - Stock Wars - Carpet - 17.5 - 2nd
Print Wikipost
Like Tree2Likes
Old 09-29-2015, 11:31 AM   #106
Sebbo's Avatar
Mine has been shipped today and will arrive tomorrow!!
New features are a new chassis, new topdeck, new motormount, new rear suspension mount and maybe some gear diff modifications. DJS's are included now!!
Looking forward to tomorrow!!!
Awesomatix A800, Mugen MTC-1, Team Associated F6
www.mst-estenfeld.de
Sebbo is offline   Reply With Quote
Old 09-29-2015, 11:34 AM   #107
LeoChan's Avatar
Send a message via ICQ to LeoChan
maybe included PSS only !
LeoChan is offline   Reply With Quote
Old 09-29-2015, 09:10 PM   #108
Warren Weaver's Avatar
Trader Rating: 47 (100%+)
Originally Posted by Skiddins View Post
Several companies have designed floating steering.
Friend tried it on his Yokomo and took it straight off, killed all his corner speed.
Yes all it does is add weight and definitely kills corner speed
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 09-30-2015, 02:45 AM   #109
Can confirm;
NEW lower deck with new holes for motor mount plate
NEW upper deck for better pinion maintenance
NEW motor mount plate for more flex settings
NEW rear suspension mounts for ARS
NEW ECS ES double joint shafts in the front (52mm
Now for pictures of the motor mount in particular!
cplus is online now   Reply With Quote
Old 09-30-2015, 03:54 AM   #110
Dan
Dan's Avatar
About time ECS came standard.
Dan is offline   Reply With Quote
Old 09-30-2015, 06:32 AM   #111
XRAY Website Update
http://www.teamxray.com/t4/
and new manual
http://www.teamxray.com/t4/downloads...4_e-manual.pdf
Adelaide RC Team Driver - www.adelaiderc.com.au
Support the Shops that Support the Racers
Old 09-30-2015, 07:58 AM   #112
SpidarX's Avatar
Appears to be fairly minor updates.
RC America - XRAY USA - Hudy
Maclan Racing
Alamo City Racing Club - San Antonio, TX
SpidarX is offline   Reply With Quote
Old 09-30-2015, 04:52 PM   #113
Definitely minor. Anyone who got a '15 recently at a good price would be pretty happy. Add some aftermarket DCJs and you're set.
The motor mount is a pretty simply change (only the lower extension) so if it works effectively it might be a nice upgrade for some.
The integrated ARS mounts are neat when using ARS but look a little clumsy when not. Would have been nice to see a three screw or keyed mount to prevent tweak instead.
The upper and lower deck changes can be achieved with a dremel and a steady hand most likely
Old 09-30-2015, 06:01 PM   #114
mbykerman's Avatar
Trader Rating: 45 (100%+)
Only so much you can do to a already great car.
mbykerman is offline   Reply With Quote
Old 10-01-2015, 01:35 AM   #115
heretic's Avatar
http://www.redrc.net/2015/09/xray-t4...t/#more-102304
I love wedge bodies. I love dish wheels.
heretic is offline   Reply With Quote
Old 10-01-2015, 01:45 AM   #116
heretic's Avatar
Those wheels... EW. What a massive blunder from Xray, image-wise. Makes the whole car look like a cheap-o chinese drift car. Reminds me of the release pictures for the Corally Phi. They had put on huge, uncut foam tires and the car had like a 9mm ride height. It was painful to even look at it.
A competition TC post-2008 is white (dish) rims and shiny rubber, period. You should know the codes, guys... [rant over]
Old 10-01-2015, 03:09 AM   #117
Same wheels as last year but grey not white.
I actually think it is cool to see non dish wheels!
Not orange, but check out Rod Canare's car below - looks tops.
Old 10-01-2015, 05:11 AM   #118
Anyone has a good description of how the new additional motor mount holes influence flex (when to use)?
rafyel is offline   Reply With Quote
Old 10-01-2015, 05:19 AM   #119
4 steps of stiffness?
And/or more flex front to rear as the screw fix point moves back/forward of centre.
Old 10-01-2015, 05:19 AM   #120
Black Edition to boost interest???
