    Hide Wikipost
Old 03-17-2017, 02:10 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Xray T4 2016
Last edit by: R Dodge
Welcome to the XRAY T4'16 Thread & Wikipost! Here you will find some useful info, tips and tricks as well as setups that are used by several team drivers. This wikipost is a work in progress and should continue to develop over time.
Tips & Tricks:
Alex Hagberg's Tech Tip Tuesday articles
How to mount your Protoform LTC-R Body
Setting static camber
How to mount weight on your chassis Part1
How to mount the rear wing on Protoform bodies
Simple troubleshooting guide
How to mount the battery on your chassis
How to glue your front tires for CRC Black carpet with Eric Anderson
Utilizing Exponential and RMode on the M12S
How to mount weight on your chassis Part2
Team driver Tim Wahl posted some very useful tips on Facebook as he worked through building a new kit.
1- Carbon Parts
2-Suspension
3-Solid Axle and Differential
4-Bulkheads & Drivetrain
5-Driveshaft (ECS & CVD)
6-Front & Rear Suspension
7-Tweak
8-Anti-Roll Bar
9-Battery Fix (OPTIONAL)
10-Bumper & Body
11-Shocks
12-Steering
New Graphite Hubs:
Xray have recently released some additional Graphite hubs for the T4 lineup. The 4° Graphite C-Hub has been out for some time and is known to improve steering on entry, and in general makes the car turn better. This has been the go-to c-hub on asphalt for many on the Xray team, though it is not needed on high bite carpet. The Graphite rear hub tends to make the car more stable, especially on corner entry. We are still working on gathering input on the new Graphite steering block, but for the moment feel that it should improve steering response. All Graphite parts are approximately 1g lighter than the Hard or Medium options.
Option Parts to consider:
XRA301196 T4 Graphite Upper Deck 1.6mm V2
XRA301226 Foam Bumper – Hard - highly recommend
XRA302165 Composite Front Suspension Arm 2-Hole – Hard
XRA302169 Composite Front Suspension Arm 1-Hole – Graphite
XRA302803 1.3mm Front Anti-Roll Bar
XRA303169 Composite Rear Suspension Arm 1-Hole – Graphite
XRA303802 1.2mm Rear Anti-Roll Bar
XRA305137 Steel Solid Axle Driveshaft Adapters - HUDY Spring Steel - highly recommend
XRA305242 Composite Drive Shaft Replacement Cap 3.5mm – Orange – Strong (QTY 4)
XRA305351 Aluminum Wheel Hub – Offset “-0.75mm” – Black (QTY 2)
XRA306191 T4 Graphite + Aluminum Fully Adjustable Battery Holder
XRA308264 4S Spring-Set Progressive C=2.5-2.8 (QTY 2)
XRA308276 4S Spring-Set C=2.7 (QTY 2)
XRA308286 4S Spring-Set C=2.6 (QTY 2)
Specific to Asphalt:
XRA302383 Composite C-Hub Right – 4* - Graphite (ECS)
XRA302384 Composite C-Hub Left – 4* - Graphite (ECS)
XRA308039 Aluminum Progressive Shock System – Set (QTY 2)
Specific to Carpet:
XRA301141 T4 Aluminum Flex Chassis 2mm
XRA302375 Composite C-Hub Right – 6* - Hard ***Modification may be required if they don't have the "ECS" stamp.
XRA302376 Composite C-Hub Left – 6* - Hard ***Modification may be required if they don't have the "ECS" stamp.
XRA303711-O Aluminum Rear Lower Suspension Holder – Front – RF
Recent Setups:
3 July 2016 - Alex Hagberg - European Championship - Asphalt - Mod - 2nd
3 July 2016 - Bruno Coelho - European Championship - Asphalt - Mod - 4th
3 July 2016 - Jan Ratheisky - European Championship - Asphalt - 13.5 - TQ + Win
29 June 2016 - Max Kuenning - Reedy - Asphalt - Mod - 4th
29 June 2016 - Keith Yu - Reedy - Asphalt - 13.5 - TQ + 2nd
29 June 2016 - Eric Anderson - Reedy - Asphalt - 13.5 - 3rd
15 May 2016 - Bruno Coelho - ETS Rd 4 Riccione - Asphalt - Mod - TQ + Win
15 May 2016 - Mattia Collina - ETS Rd 4 Riccione - Asphalt - 13.5 - Win
17 April 2016 - Max Kuenning - MHIC - Carpet - Mod - 4th
10 April 2016 - Bruno Coelho - ETS Rd 3 Wels - Carpet - Mod - 2nd
10 April 2016 - Alex Hagberg - ETS Rd 3 Wels - Carpet - Mod - 4th
10 April 2016 - Jan Ratheisky - ETS Rd 3 Wels - Carpet - 13.5 - TQ + Win
22 March 2016 - Paul LeMieux - Canadian Nats - Carpet - Mod - TQ + Win
22 March 2016 - Luke Pittman - Canadian Nats - Carpet - Mod - 3rd
6 March 2016 - Chris Adams - ROAR Nats - Carpet - Mod - TQ + Win
6 March 2016 - Craig Xavier - ROAR Nats - Carpet - 17.5 - 4th
6 March 2016 - Eric Anderson - ROAR Nats - Carpet - 17.5 - 5th
6 February 2016 - Bruno Coelho - ETS Rd 2 Koblenz - Carpet - Mod - TQ + Win
6 February 2016 - Alex Hagberg - ETS Rd 2 Koblenz - Carpet - Mod - 2nd
31 January 2016 - Alex Hagberg - Snowbirds - Carpet - Mod - TQ + Win
31 January 2016 - Jan Ratheisky - Snowbirds - Carpet - All - See Comments
31 January 2016 - Drew Ellis - Snowbirds - Carpet - 13.5 - 4th
31 January 2016 - Robbie Dodge - Snowbirds - Carpet - 17.5 - Win
13 December 2015 - Bruno Coelho - ETS Rd 1 Hrotovice - Carpet - Mod - 3rd
13 December 2015 - Alex Hagberg - ETS Rd 1 Hrotovice - Carpet - Mod - 4th
13 December 2015 - Olly Jeffries - ETS Rd 1 Hrotovice - Carpet - Mod - 7th
13 December 2015 - Jan Ratheisky - ETS Rd 1 Hrotovice - Carpet - 13.5 - TQ + Win
29 November 2015 - Paul LeMieux - US Indoor Champs - Carpet - Mod - TQ + Win
25 October 2015 - Eric Anderson - Stock Wars - Carpet - 17.5 - 2nd
Print Wikipost
Like Tree2Likes
Old 08-30-2016, 03:48 AM   #931
Skiddins's Avatar
Originally Posted by Troy Carter View Post
I've only ran a 4.5t but I would start a 5.5t at 7.6fdr and adjust as needed based on your motor. This assumes you will be running boost/turbo.
That's more like 4.5t gearing
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 08-30-2016, 04:21 AM   #932
Les
Les's Avatar
Default Bars
Do Xray T4 range have bearing type anti roll bars (like VBC) or sleeve type.
Cheers
Serpent S411 4.0 13.5T D4
Kyosho V-ONE S3, RB Rota-Start
Sanwa MT4S
Les is offline   Reply With Quote
Old 08-30-2016, 04:39 AM   #933
Bearing type was introduced on the 2015 version if I'm not mistaken.
rcdreamer is offline   Reply With Quote
Old 08-30-2016, 05:23 AM   #934
Trader Rating: 20 (100%+)
It is my 4.5t gearing but it's also where I would start a 5.5 and adjust from there.
Is there a better starting point for him?
www.teamgravityrc.com
Leisure Hours Raceway
Troy Carter is offline   Reply With Quote
Old 08-30-2016, 05:29 AM   #935
Skiddins's Avatar
Perhaps go up one pinion. This is based on boosted Mod as well.
More like 7.0 if running it in blinky.
Xray X12 2017
Xray X1'16
RCDisco.co.uk
Old 09-04-2016, 06:24 PM   #936
I believe Xray makes a wide bumper. If so, how much wider is the bumper and what is the part number?
SouthFloridaApp is offline   Reply With Quote
Old 09-04-2016, 06:46 PM   #937
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
They make a plastic lower bumper that is the same size as the foam bumper and goes under it. Its really large. You'll have to search it on their site to find the part number.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 09-04-2016, 06:47 PM   #938
tbrymer's Avatar
Hmm... I have't seen that, only the impact resistant and the graphite one. Interesting to see if anyone else has seen a wider bumper.
CRC - C&C Motorsports - SpeedZone
tbrymer is offline   Reply With Quote
Old 09-04-2016, 07:59 PM   #939
This is the part EA is talking about.
https://www.amainhobbies.com/xray-im...a301203/p22618
malkiy is offline   Reply With Quote
Old 09-05-2016, 06:54 AM   #940
I was referring to a wider foam bumper... Any thoughts?
Old 09-05-2016, 07:26 AM   #941
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
Do you mean wider from side to side, or wider meaning actually going further from the car ?
You don't want a wide (side to side bumper ) cause if you hit a board they bend down and scrub ground In the corners .
I really like the EAM bumpers cause they brace the body in a farward mounted body . and don't add much weight to the car vs stock one .
You need to keep in mind the heavier the front bumper the less potential steering you have ... On a proven setup anyone has add a heavier bumper and it will reduce steering to some degree depending on weight . I've always made my own bumpers to make contact with body properly @ about 8g stock was about 5g . the bsr is about 12g.
I've ran 3g bumpers and could feel the difference between them . 5-7g is my compromise between durability and performance.
jlfx car audio is offline   Reply With Quote
Old 09-05-2016, 07:31 AM   #942
tbrymer's Avatar
OK, you mean the foam, sorry about that. I have been using the EA bumper since Reedy and it is great.
Old 09-05-2016, 07:44 AM   #943
What about using a wide foam bumper and dremeling the bottom edges in a contoured manner for more protection? I would rather have increased durability and find a way to get more steering via set-up. Hence, where can I find a wide foam bumper that will be a direct fit that I can experiment with?
Old 09-05-2016, 07:56 AM   #944
The widest foam bumper I've seen is the heavy BSR bumper sold by Awesomatix usa.com you could drill it to cut down On some weight it's really hard so you probably would have the best luck with one of these
Old 09-05-2016, 08:21 AM   #945
Do you know if this is the same thickness?
