    Hide Wikipost
Old 03-17-2017, 02:10 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Xray T4 2016
Last edit by: R Dodge
Welcome to the XRAY T4'16 Thread & Wikipost! Here you will find some useful info, tips and tricks as well as setups that are used by several team drivers. This wikipost is a work in progress and should continue to develop over time.
Tips & Tricks:
Alex Hagberg's Tech Tip Tuesday articles
How to mount your Protoform LTC-R Body
Setting static camber
How to mount weight on your chassis Part1
How to mount the rear wing on Protoform bodies
Simple troubleshooting guide
How to mount the battery on your chassis
How to glue your front tires for CRC Black carpet with Eric Anderson
Utilizing Exponential and RMode on the M12S
How to mount weight on your chassis Part2
Team driver Tim Wahl posted some very useful tips on Facebook as he worked through building a new kit.
1- Carbon Parts
2-Suspension
3-Solid Axle and Differential
4-Bulkheads & Drivetrain
5-Driveshaft (ECS & CVD)
6-Front & Rear Suspension
7-Tweak
8-Anti-Roll Bar
9-Battery Fix (OPTIONAL)
10-Bumper & Body
11-Shocks
12-Steering
New Graphite Hubs:
Xray have recently released some additional Graphite hubs for the T4 lineup. The 4° Graphite C-Hub has been out for some time and is known to improve steering on entry, and in general makes the car turn better. This has been the go-to c-hub on asphalt for many on the Xray team, though it is not needed on high bite carpet. The Graphite rear hub tends to make the car more stable, especially on corner entry. We are still working on gathering input on the new Graphite steering block, but for the moment feel that it should improve steering response. All Graphite parts are approximately 1g lighter than the Hard or Medium options.
Option Parts to consider:
XRA301196 T4 Graphite Upper Deck 1.6mm V2
XRA301226 Foam Bumper – Hard - highly recommend
XRA302165 Composite Front Suspension Arm 2-Hole – Hard
XRA302169 Composite Front Suspension Arm 1-Hole – Graphite
XRA302803 1.3mm Front Anti-Roll Bar
XRA303169 Composite Rear Suspension Arm 1-Hole – Graphite
XRA303802 1.2mm Rear Anti-Roll Bar
XRA305137 Steel Solid Axle Driveshaft Adapters - HUDY Spring Steel - highly recommend
XRA305242 Composite Drive Shaft Replacement Cap 3.5mm – Orange – Strong (QTY 4)
XRA305351 Aluminum Wheel Hub – Offset “-0.75mm” – Black (QTY 2)
XRA306191 T4 Graphite + Aluminum Fully Adjustable Battery Holder
XRA308264 4S Spring-Set Progressive C=2.5-2.8 (QTY 2)
XRA308276 4S Spring-Set C=2.7 (QTY 2)
XRA308286 4S Spring-Set C=2.6 (QTY 2)
Specific to Asphalt:
XRA302383 Composite C-Hub Right – 4* - Graphite (ECS)
XRA302384 Composite C-Hub Left – 4* - Graphite (ECS)
XRA308039 Aluminum Progressive Shock System – Set (QTY 2)
Specific to Carpet:
XRA301141 T4 Aluminum Flex Chassis 2mm
XRA302375 Composite C-Hub Right – 6* - Hard ***Modification may be required if they don't have the "ECS" stamp.
XRA302376 Composite C-Hub Left – 6* - Hard ***Modification may be required if they don't have the "ECS" stamp.
XRA303711-O Aluminum Rear Lower Suspension Holder – Front – RF
Recent Setups:
3 July 2016 - Alex Hagberg - European Championship - Asphalt - Mod - 2nd
3 July 2016 - Bruno Coelho - European Championship - Asphalt - Mod - 4th
3 July 2016 - Jan Ratheisky - European Championship - Asphalt - 13.5 - TQ + Win
29 June 2016 - Max Kuenning - Reedy - Asphalt - Mod - 4th
29 June 2016 - Keith Yu - Reedy - Asphalt - 13.5 - TQ + 2nd
29 June 2016 - Eric Anderson - Reedy - Asphalt - 13.5 - 3rd
15 May 2016 - Bruno Coelho - ETS Rd 4 Riccione - Asphalt - Mod - TQ + Win
15 May 2016 - Mattia Collina - ETS Rd 4 Riccione - Asphalt - 13.5 - Win
17 April 2016 - Max Kuenning - MHIC - Carpet - Mod - 4th
10 April 2016 - Bruno Coelho - ETS Rd 3 Wels - Carpet - Mod - 2nd
10 April 2016 - Alex Hagberg - ETS Rd 3 Wels - Carpet - Mod - 4th
10 April 2016 - Jan Ratheisky - ETS Rd 3 Wels - Carpet - 13.5 - TQ + Win
22 March 2016 - Paul LeMieux - Canadian Nats - Carpet - Mod - TQ + Win
22 March 2016 - Luke Pittman - Canadian Nats - Carpet - Mod - 3rd
6 March 2016 - Chris Adams - ROAR Nats - Carpet - Mod - TQ + Win
6 March 2016 - Craig Xavier - ROAR Nats - Carpet - 17.5 - 4th
6 March 2016 - Eric Anderson - ROAR Nats - Carpet - 17.5 - 5th
6 February 2016 - Bruno Coelho - ETS Rd 2 Koblenz - Carpet - Mod - TQ + Win
6 February 2016 - Alex Hagberg - ETS Rd 2 Koblenz - Carpet - Mod - 2nd
31 January 2016 - Alex Hagberg - Snowbirds - Carpet - Mod - TQ + Win
31 January 2016 - Jan Ratheisky - Snowbirds - Carpet - All - See Comments
31 January 2016 - Drew Ellis - Snowbirds - Carpet - 13.5 - 4th
31 January 2016 - Robbie Dodge - Snowbirds - Carpet - 17.5 - Win
13 December 2015 - Bruno Coelho - ETS Rd 1 Hrotovice - Carpet - Mod - 3rd
13 December 2015 - Alex Hagberg - ETS Rd 1 Hrotovice - Carpet - Mod - 4th
13 December 2015 - Olly Jeffries - ETS Rd 1 Hrotovice - Carpet - Mod - 7th
13 December 2015 - Jan Ratheisky - ETS Rd 1 Hrotovice - Carpet - 13.5 - TQ + Win
29 November 2015 - Paul LeMieux - US Indoor Champs - Carpet - Mod - TQ + Win
25 October 2015 - Eric Anderson - Stock Wars - Carpet - 17.5 - 2nd
Print Wikipost
Like Tree2Likes
Old 07-06-2016, 08:24 AM   #826
Dino_D's Avatar
Originally Posted by Kakaru View Post
Hi Guys,
I'm pretty new to RC and I just built a new XRay T4 2016 lately. Can you all please advise me on what are the significant or highly recommended XRay hop-up parts (must have item(s)), other than the following hop-up parts or important items that I already have.
1. All countersunk screws are titanium and others are orange aluminum screws;
2. Xray Spring Steel Solid Axle Driveshaft Adapter 2 pcs Black w/ Blades For T3 T4 (Front Solid Axles) #XR-305137;
3. T4 Carbon Fibre Graphite + Alu Fully Adjustable Battery Holder #306191;
4. Alu Dual Servo Saver Arm #302525
5. Hudy Alu Servo Horn (Sanwa, Airtronics, JR, KO Propo) - 23T #293501
6. XRay Alu XRay Shock Springs Retaining Collar - Orange # 308031-0
7. XRay T4 Foam Bumper (Hard) #301226
8. Countersunk orange alu washers (4 pieces) for servo float.
Thank you in advance.
What surface are you running? Carpet or outdoor asphalt.
Carpet: I would have picked up 2.6 and 2.7 springs and the progressive 2.4-2.7 and progressive 2.5-2.8 springs. One step stiffer sway bars and one step softer as well as tuning options.
Asphalt: Same springs and sway bars, but also the progressive pistons for the front.
You want to have tuning options to adjust the car.
* Team Great Hobbies * Team Powers * Exotek *
http://www.sidsraceway.com
Dino_D is offline   Reply With Quote
Old 07-07-2016, 05:11 AM   #827
R Dodge's Avatar
Myself and several other RCAmerica drivers have been working on a list of popular options for the T4'16. We've been taking our time with it because we want to provide the best & most accurate list possible. Our list will detail what options we think are important to have during the initial build. It will also indicate which tuning options we recommend specifically for Asphalt or Carpet applications.
Hopefully we can finish up our final review & share soon.
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is offline   Reply With Quote
Old 07-08-2016, 07:16 AM   #828
Bar
I see some people are shaving the layshaft down so it doesn't touch on the topdeck on the 16 car, I haven't tried this myself, I have only tried raising the top deck 1mm. I wasn't that keen on this, has anybody else experimented with it?
Luke Burr
Bar is offline   Reply With Quote
Old 07-09-2016, 04:15 AM   #829
TryHard's Avatar
Always run top deck raised tbh. More steering, IMO. I wouldn't even lower it to run the centre post, just add a 1mm shim. Only time I'd lower the top deck would be to put the screws in the layshafts mounts... which locks the car down too much in the rear, and takes away steering. And that's predominantly low to medium grip asphalt tracks.
| THard.co.uk | Xray | MuchMore |
Old 07-09-2016, 05:08 AM   #830
I also though it's best to always run with the top deck raised. Then I tried to lower it just to experiment and instantly got almost half a second faster laps. Now I even prefer to run with the layshaft screws in. Car is slightly slower, but much more consistent and easier to drive. It all depends on the track.
perzeus is offline   Reply With Quote
Old 07-09-2016, 08:43 AM   #831
Skiddins's Avatar
May help explain why the Yoke BD7'16's lower CoG hasn't improved it, certainly not in the eyes of almost everyone I know who's run it (and most of them have sold them on)
Xray T4'18, T4'14 (Wet Car)
Xray X12 2018
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is offline   Reply With Quote
Old 07-10-2016, 05:14 AM   #832
Trader Rating: 315 (100%+)
What would be a better fit for black carpet. Avid chassis or Xray standard aluminum?
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 07-10-2016, 10:21 AM   #833
pcar951's Avatar
Trader Rating: 19 (100%+)
I run the 301140 Xray aluminum chassis, IMO the best overall choice for carpet. Calms the car down and improves consistency for me.
Jim Chapman
PM Hobbycraft | RCAmerica | Xray | Hudy | Reds Racing
pcar951 is offline   Reply With Quote
Old 07-10-2016, 12:07 PM   #834
all i can say its a difficult car for low-med grip.
definitely hard to like of me and i see myself change next season to a different brand.
lot of ppl go back to theBD7 2014 ...
Peterke is offline   Reply With Quote
Old 07-10-2016, 09:40 PM   #835
CristianTabush's Avatar
Default New items for T4
RSD163 RSD 4mm Carbon Fiber Shock Towers for XRAY T4
RX4-16CF RX4 2016 2.0mm Quasi Carbon Fiber chassis for XRAY T4
REFLEX RACING/ RSD/ GIZMO RACING USA/ HOBBYWING/ AXON/ QTEQ/ TEAM PRIME
CristianTabush is offline   Reply With Quote
Old 07-11-2016, 08:31 AM   #836
Bar
Hi Cristian, been waiting for someone to do a 2mm chassis for the 16 car I take it this generates more traction in low grip conditions same as Yokomo's new one does?
Luke Burr
Old 07-11-2016, 01:03 PM   #837
The reports from our lead testing drivers was the the car made more grip and had better steering. Most of the testing was done on Parking lot tracks with medlium low to medium high grip. A lot of it has to do with the revised shape. We also have an alloy chassis with the same shape coming which was I think 3 tenths faster per lap at MHIC over our old design. Sounds crazy, but it has a lot to do with how we isolated the flex points to in front and behind the bulkheads. When used with top deck stiffeners and thicker towers, it seemed like the car carried more corner speed. When running softer chassis it seems like the cars are a little bit slower in transition and the extra deflection seems to reduce the amount of force the tire digs into the surface with.
Old 07-12-2016, 04:13 AM   #838
Bar
Thanks Cristian, will be interesting to here people's feedback
Luke Burr
Old 07-14-2016, 11:01 PM   #839
Shop Owner
rcmart's Avatar
Our friends over at RC-Xpress are looking for test drivers for their newly released DCJ's for Yokomo BD7! Head over to their page here to apply!
rcMart.com - We Help People Have Fun with RC
Fast worldwide delivery & low shipping rates
WebStore: www.rcMart.com
Blog: blog.rcmart.com
FB: www.facebook.com/rcmart
IG: www.instagram.com/rcmart2001
rcmart is offline   Reply With Quote
Old 07-15-2016, 10:13 AM   #840
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Where would your new alloy chassis fit into the stiffness curve CT? Id like something between full soft of the cf and xray hard aluminum. I like the hard chassis, but might want something a little softer for high traction sprayed ashphalt. But not full flex cf soft.
valk is offline   Reply With Quote
