    Hide Wikipost
Old 03-17-2017, 02:10 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Xray T4 2016
Last edit by: R Dodge
Welcome to the XRAY T4'16 Thread & Wikipost! Here you will find some useful info, tips and tricks as well as setups that are used by several team drivers. This wikipost is a work in progress and should continue to develop over time.
Tips & Tricks:
Alex Hagberg's Tech Tip Tuesday articles
How to mount your Protoform LTC-R Body
Setting static camber
How to mount weight on your chassis Part1
How to mount the rear wing on Protoform bodies
Simple troubleshooting guide
How to mount the battery on your chassis
How to glue your front tires for CRC Black carpet with Eric Anderson
Utilizing Exponential and RMode on the M12S
How to mount weight on your chassis Part2
Team driver Tim Wahl posted some very useful tips on Facebook as he worked through building a new kit.
1- Carbon Parts
2-Suspension
3-Solid Axle and Differential
4-Bulkheads & Drivetrain
5-Driveshaft (ECS & CVD)
6-Front & Rear Suspension
7-Tweak
8-Anti-Roll Bar
9-Battery Fix (OPTIONAL)
10-Bumper & Body
11-Shocks
12-Steering
New Graphite Hubs:
Xray have recently released some additional Graphite hubs for the T4 lineup. The 4° Graphite C-Hub has been out for some time and is known to improve steering on entry, and in general makes the car turn better. This has been the go-to c-hub on asphalt for many on the Xray team, though it is not needed on high bite carpet. The Graphite rear hub tends to make the car more stable, especially on corner entry. We are still working on gathering input on the new Graphite steering block, but for the moment feel that it should improve steering response. All Graphite parts are approximately 1g lighter than the Hard or Medium options.
Option Parts to consider:
XRA301196 T4 Graphite Upper Deck 1.6mm V2
XRA301226 Foam Bumper – Hard - highly recommend
XRA302165 Composite Front Suspension Arm 2-Hole – Hard
XRA302169 Composite Front Suspension Arm 1-Hole – Graphite
XRA302803 1.3mm Front Anti-Roll Bar
XRA303169 Composite Rear Suspension Arm 1-Hole – Graphite
XRA303802 1.2mm Rear Anti-Roll Bar
XRA305137 Steel Solid Axle Driveshaft Adapters - HUDY Spring Steel - highly recommend
XRA305242 Composite Drive Shaft Replacement Cap 3.5mm – Orange – Strong (QTY 4)
XRA305351 Aluminum Wheel Hub – Offset “-0.75mm” – Black (QTY 2)
XRA306191 T4 Graphite + Aluminum Fully Adjustable Battery Holder
XRA308264 4S Spring-Set Progressive C=2.5-2.8 (QTY 2)
XRA308276 4S Spring-Set C=2.7 (QTY 2)
XRA308286 4S Spring-Set C=2.6 (QTY 2)
Specific to Asphalt:
XRA302383 Composite C-Hub Right – 4* - Graphite (ECS)
XRA302384 Composite C-Hub Left – 4* - Graphite (ECS)
XRA308039 Aluminum Progressive Shock System – Set (QTY 2)
Specific to Carpet:
XRA301141 T4 Aluminum Flex Chassis 2mm
XRA302375 Composite C-Hub Right – 6* - Hard ***Modification may be required if they don't have the "ECS" stamp.
XRA302376 Composite C-Hub Left – 6* - Hard ***Modification may be required if they don't have the "ECS" stamp.
XRA303711-O Aluminum Rear Lower Suspension Holder – Front – RF
Recent Setups:
3 July 2016 - Alex Hagberg - European Championship - Asphalt - Mod - 2nd
3 July 2016 - Bruno Coelho - European Championship - Asphalt - Mod - 4th
3 July 2016 - Jan Ratheisky - European Championship - Asphalt - 13.5 - TQ + Win
29 June 2016 - Max Kuenning - Reedy - Asphalt - Mod - 4th
29 June 2016 - Keith Yu - Reedy - Asphalt - 13.5 - TQ + 2nd
29 June 2016 - Eric Anderson - Reedy - Asphalt - 13.5 - 3rd
15 May 2016 - Bruno Coelho - ETS Rd 4 Riccione - Asphalt - Mod - TQ + Win
15 May 2016 - Mattia Collina - ETS Rd 4 Riccione - Asphalt - 13.5 - Win
17 April 2016 - Max Kuenning - MHIC - Carpet - Mod - 4th
10 April 2016 - Bruno Coelho - ETS Rd 3 Wels - Carpet - Mod - 2nd
10 April 2016 - Alex Hagberg - ETS Rd 3 Wels - Carpet - Mod - 4th
10 April 2016 - Jan Ratheisky - ETS Rd 3 Wels - Carpet - 13.5 - TQ + Win
22 March 2016 - Paul LeMieux - Canadian Nats - Carpet - Mod - TQ + Win
22 March 2016 - Luke Pittman - Canadian Nats - Carpet - Mod - 3rd
6 March 2016 - Chris Adams - ROAR Nats - Carpet - Mod - TQ + Win
6 March 2016 - Craig Xavier - ROAR Nats - Carpet - 17.5 - 4th
6 March 2016 - Eric Anderson - ROAR Nats - Carpet - 17.5 - 5th
6 February 2016 - Bruno Coelho - ETS Rd 2 Koblenz - Carpet - Mod - TQ + Win
6 February 2016 - Alex Hagberg - ETS Rd 2 Koblenz - Carpet - Mod - 2nd
31 January 2016 - Alex Hagberg - Snowbirds - Carpet - Mod - TQ + Win
31 January 2016 - Jan Ratheisky - Snowbirds - Carpet - All - See Comments
31 January 2016 - Drew Ellis - Snowbirds - Carpet - 13.5 - 4th
31 January 2016 - Robbie Dodge - Snowbirds - Carpet - 17.5 - Win
13 December 2015 - Bruno Coelho - ETS Rd 1 Hrotovice - Carpet - Mod - 3rd
13 December 2015 - Alex Hagberg - ETS Rd 1 Hrotovice - Carpet - Mod - 4th
13 December 2015 - Olly Jeffries - ETS Rd 1 Hrotovice - Carpet - Mod - 7th
13 December 2015 - Jan Ratheisky - ETS Rd 1 Hrotovice - Carpet - 13.5 - TQ + Win
29 November 2015 - Paul LeMieux - US Indoor Champs - Carpet - Mod - TQ + Win
25 October 2015 - Eric Anderson - Stock Wars - Carpet - 17.5 - 2nd
Print Wikipost
Old 09-17-2015, 12:10 AM   #61
getting close now surely.
anyone seen any more snippets, images or rumors? or notice any prototype parts out there?
Adelaide RC Team Driver - www.adelaiderc.com.au
Support the Shops that Support the Racers
cplus is offline   Reply With Quote
Old 09-17-2015, 06:33 AM   #62
rasta_man's Avatar
https://www.facebook.com/TeamXray/ph...type=1&theater
rasta_man is offline   Reply With Quote
Old 09-17-2015, 08:51 AM   #63
bmxcrx's Avatar
Can't wait to trade in my 13 for a 16!
Current cars: TA07 / FF04 |
For Sale (thread coming soon):
M05v2 / FF03R / Exotek TB04 / F104v2 / F1R3 / RC10R5
RC Car World - Willingboro, NJ.
bmxcrx is offline   Reply With Quote
Old 09-17-2015, 04:18 PM   #64
wwddww34's Avatar
Trader Rating: 9 (91%+)
Here's a sneak peak (over Martin Hudy's shoulder) of the T4'16.
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is online now   Reply With Quote
Old 09-18-2015, 04:24 AM   #65
Trader Rating: 54 (100%+)
We're still trying to figure out the 15!
cnoble64 is offline   Reply With Quote
Old 09-18-2015, 11:33 AM   #66
Expect an increase in price.... Just pre-ordered mine and in Sweden its up about 70usd compared to the '15.
Lawson1307 is offline   Reply With Quote
Old 09-18-2015, 12:58 PM   #67
vabroom's Avatar
I predicted a 10% increase in price but it looks like it's closer to 15%!
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 09-18-2015, 01:20 PM   #68
Somewhere between 10-15% as its also how strong each countries currencies are right now. I hope its one hell of a car.... :-)
Old 09-18-2015, 03:40 PM   #69
carrotcake's Avatar
omg, I just bought a T4 2015
carrotcake is offline   Reply With Quote
Old 09-18-2015, 04:03 PM   #70
vabroom's Avatar
You should be okay. As far I know there were no prototype part being tested. Probably just optimized parts.
Old 09-19-2015, 12:49 AM   #71
daveaustin5's Avatar
£380 in the UK.
That's too much money. The previous kit was very expensive at £340 but £380 is getting silly.
With the current pound-euro exchange rate I'd have expected the kit to be cheaper, not more expensive.
daveaustin5 is offline   Reply With Quote
Old 09-19-2015, 04:53 AM   #72
niznai's Avatar
Originally Posted by daveaustin5 View Post
£380 in the UK.
Why don't you buy it online from the continent if the exchange rate is to your advantage?
Team Greasy Weasel
The best upgrade to any car is some driver skill.
niznai is offline   Reply With Quote
Old 09-19-2015, 05:55 AM   #73
theproffesor's Avatar
Trader Rating: 53 (100%+)
It's no surprise its more expensive. Whole sellers and manufacture's see the writing on the wall. Between people willing to pay massive amounts of money for the awesomatix, and try extreme popularity / market share of X-ray, combine those two factors together and X-ray can charge almost anything they want.
They make a great product, and know it. They also know they have a loyal following that wil drink the X-ray cool aid no matter what. They could release an x1 with a lipo chassis and orange anodizing, call it the t5 and the RC world would call in innovative.
Associated - Fantom - Savox - Hobbywing - Spectrum.
The brighter the picture, the darker the negative. USVTA member #112
theproffesor is online now   Reply With Quote
Old 09-19-2015, 07:09 AM   #74
Well, the quite massive increase in price MUST mean some sweet things in the kit. I mean the '15 came with both standard and ARS(e) rear end.
Old 09-19-2015, 07:11 AM   #75
niznai's Avatar
I was thinking along the same lines. My money says it's DCJ's.
Team Greasy Weasel
