    Hide Wikipost
Old 03-17-2017, 02:10 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Xray T4 2016
Last edit by: R Dodge
Welcome to the XRAY T4'16 Thread & Wikipost! Here you will find some useful info, tips and tricks as well as setups that are used by several team drivers. This wikipost is a work in progress and should continue to develop over time.
Tips & Tricks:
Alex Hagberg's Tech Tip Tuesday articles
How to mount your Protoform LTC-R Body
Setting static camber
How to mount weight on your chassis Part1
How to mount the rear wing on Protoform bodies
Simple troubleshooting guide
How to mount the battery on your chassis
How to glue your front tires for CRC Black carpet with Eric Anderson
Utilizing Exponential and RMode on the M12S
How to mount weight on your chassis Part2
Team driver Tim Wahl posted some very useful tips on Facebook as he worked through building a new kit.
1- Carbon Parts
2-Suspension
3-Solid Axle and Differential
4-Bulkheads & Drivetrain
5-Driveshaft (ECS & CVD)
6-Front & Rear Suspension
7-Tweak
8-Anti-Roll Bar
9-Battery Fix (OPTIONAL)
10-Bumper & Body
11-Shocks
12-Steering
New Graphite Hubs:
Xray have recently released some additional Graphite hubs for the T4 lineup. The 4° Graphite C-Hub has been out for some time and is known to improve steering on entry, and in general makes the car turn better. This has been the go-to c-hub on asphalt for many on the Xray team, though it is not needed on high bite carpet. The Graphite rear hub tends to make the car more stable, especially on corner entry. We are still working on gathering input on the new Graphite steering block, but for the moment feel that it should improve steering response. All Graphite parts are approximately 1g lighter than the Hard or Medium options.
Option Parts to consider:
XRA301196 T4 Graphite Upper Deck 1.6mm V2
XRA301226 Foam Bumper – Hard - highly recommend
XRA302165 Composite Front Suspension Arm 2-Hole – Hard
XRA302169 Composite Front Suspension Arm 1-Hole – Graphite
XRA302803 1.3mm Front Anti-Roll Bar
XRA303169 Composite Rear Suspension Arm 1-Hole – Graphite
XRA303802 1.2mm Rear Anti-Roll Bar
XRA305137 Steel Solid Axle Driveshaft Adapters - HUDY Spring Steel - highly recommend
XRA305242 Composite Drive Shaft Replacement Cap 3.5mm – Orange – Strong (QTY 4)
XRA305351 Aluminum Wheel Hub – Offset “-0.75mm” – Black (QTY 2)
XRA306191 T4 Graphite + Aluminum Fully Adjustable Battery Holder
XRA308264 4S Spring-Set Progressive C=2.5-2.8 (QTY 2)
XRA308276 4S Spring-Set C=2.7 (QTY 2)
XRA308286 4S Spring-Set C=2.6 (QTY 2)
Specific to Asphalt:
XRA302383 Composite C-Hub Right – 4* - Graphite (ECS)
XRA302384 Composite C-Hub Left – 4* - Graphite (ECS)
XRA308039 Aluminum Progressive Shock System – Set (QTY 2)
Specific to Carpet:
XRA301141 T4 Aluminum Flex Chassis 2mm
XRA302375 Composite C-Hub Right – 6* - Hard ***Modification may be required if they don't have the "ECS" stamp.
XRA302376 Composite C-Hub Left – 6* - Hard ***Modification may be required if they don't have the "ECS" stamp.
XRA303711-O Aluminum Rear Lower Suspension Holder – Front – RF
Recent Setups:
3 July 2016 - Alex Hagberg - European Championship - Asphalt - Mod - 2nd
3 July 2016 - Bruno Coelho - European Championship - Asphalt - Mod - 4th
3 July 2016 - Jan Ratheisky - European Championship - Asphalt - 13.5 - TQ + Win
29 June 2016 - Max Kuenning - Reedy - Asphalt - Mod - 4th
29 June 2016 - Keith Yu - Reedy - Asphalt - 13.5 - TQ + 2nd
29 June 2016 - Eric Anderson - Reedy - Asphalt - 13.5 - 3rd
15 May 2016 - Bruno Coelho - ETS Rd 4 Riccione - Asphalt - Mod - TQ + Win
15 May 2016 - Mattia Collina - ETS Rd 4 Riccione - Asphalt - 13.5 - Win
17 April 2016 - Max Kuenning - MHIC - Carpet - Mod - 4th
10 April 2016 - Bruno Coelho - ETS Rd 3 Wels - Carpet - Mod - 2nd
10 April 2016 - Alex Hagberg - ETS Rd 3 Wels - Carpet - Mod - 4th
10 April 2016 - Jan Ratheisky - ETS Rd 3 Wels - Carpet - 13.5 - TQ + Win
22 March 2016 - Paul LeMieux - Canadian Nats - Carpet - Mod - TQ + Win
22 March 2016 - Luke Pittman - Canadian Nats - Carpet - Mod - 3rd
6 March 2016 - Chris Adams - ROAR Nats - Carpet - Mod - TQ + Win
6 March 2016 - Craig Xavier - ROAR Nats - Carpet - 17.5 - 4th
6 March 2016 - Eric Anderson - ROAR Nats - Carpet - 17.5 - 5th
6 February 2016 - Bruno Coelho - ETS Rd 2 Koblenz - Carpet - Mod - TQ + Win
6 February 2016 - Alex Hagberg - ETS Rd 2 Koblenz - Carpet - Mod - 2nd
31 January 2016 - Alex Hagberg - Snowbirds - Carpet - Mod - TQ + Win
31 January 2016 - Jan Ratheisky - Snowbirds - Carpet - All - See Comments
31 January 2016 - Drew Ellis - Snowbirds - Carpet - 13.5 - 4th
31 January 2016 - Robbie Dodge - Snowbirds - Carpet - 17.5 - Win
13 December 2015 - Bruno Coelho - ETS Rd 1 Hrotovice - Carpet - Mod - 3rd
13 December 2015 - Alex Hagberg - ETS Rd 1 Hrotovice - Carpet - Mod - 4th
13 December 2015 - Olly Jeffries - ETS Rd 1 Hrotovice - Carpet - Mod - 7th
13 December 2015 - Jan Ratheisky - ETS Rd 1 Hrotovice - Carpet - 13.5 - TQ + Win
29 November 2015 - Paul LeMieux - US Indoor Champs - Carpet - Mod - TQ + Win
25 October 2015 - Eric Anderson - Stock Wars - Carpet - 17.5 - 2nd
Print Wikipost
Like Tree2Likes
Old 02-17-2016, 01:11 PM   #511
Originally Posted by dr_hfuhuhurr View Post
Anywhere I can get an aluminum chassis for the 16 car? Have one showing up tomorrow (Thanks EA!) and would like to build it right in. Avid is out of stock and the Xray one isn't available yet.
I'm sure the 2015 aluminum chassis will work. All the relevent screw holes look to be in the same place.
DOTMAN is offline   Reply With Quote
Old 02-17-2016, 04:23 PM   #512
Korey Harbke's Avatar
I remember seeing some on Apex R/C's website.
Seido Speed Works - Apex RC - Prospec America - RC Mission America - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 02-17-2016, 09:23 PM   #513
valk's Avatar
Send a message via ICQ to valk Send a message via AIM to valk Send a message via MSN to valk
Finally caved to peer pressure and got a new t4. blake insists i build it bone stock so that is what im doing. $750 cdn lol. i had better gain a lap!
My stuff
| Team Associated - Reedy - Reflex Racing/RSD - ProAMPS RC |
My RC
www.irocc.ca - www.wcics.ca - www.vrcworld.com - http://proampsrc.com/ - www.teamassociated.com
valk is offline   Reply With Quote
Old 02-17-2016, 10:41 PM   #514
Lol, you will,
I think I gained 1.5s compared to my Tamiya 419 after using t4 for 2 days.
It is amazing that it made such huge difference.
yifuqiao is offline   Reply With Quote
Old 02-18-2016, 08:15 AM   #515
valk's Avatar
Im not expecting big changes in laptimes but maybe more consistant as the car wont fall apart all thetime heh. My r2 was matching fast guys at my track with awsomatix and t4 np. Just got sick of constantly working on it.
I just want to focus on my skills development. The chassis itself is merely a toolto that end but xray is widely accepted as the most reliable. So here i am =)
Old 02-18-2016, 08:18 AM   #516
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
Agreed...I would have gone with a different chassis but the support from the team guys, the durability/reliability/stability can't be beat. XRay is just so easy to run.
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 02-18-2016, 08:20 AM   #517
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
No the motor mount holes are different on the 16.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 02-18-2016, 08:22 AM   #518
EA
I'll wait till they are available..I'm not in a hurry.
Old 02-18-2016, 10:42 AM   #519
Totally agreed as well as with Xray I have more fun running the track then on the bench table tweaking and fixing on my previous 419 - now I can have more constant track time and ever slightly going faster by bit by bit every time I practiced... (Althought still much much slower than the fast guys in my tracks... )
otaku521 is offline   Reply With Quote
Old 02-18-2016, 11:03 AM   #520
valk's Avatar
Heh. The local team guys are pretty shocked and appaled by how i setup my cars ha. So team support can only take me so far.
Though i have made a real effort to learn how to drive a car that pushes. Usually i want all the steering i can tune in and just drive around it.
But there are advantages to having a more docile car i dont have to work so hard to wheel heh. I watch blake and luke and they are pretty relaxed most of the time.
I guess bottom line is i can make almost anything go fast. But i want something easy to drive. And consistant
Old 02-18-2016, 03:28 PM   #521
Wanted you guys opinions on this.
So I have been driving with t4 16 base carpet setup lately and I really liked it.
I was looking at setup sheet provided by X-ray drivers for inspirations. But they just look far different from mine, and I tried one of them , went back to base setup again.
I am just curious at witch point, do you think you need to modify the setup? I have been improved my lap time a lot with this base setup, but i always feel there is something left to be desired.
I guess this is also a skill development question. At which point do you think you need better setup?
Wanted to hear you guys opinions.
Old 02-18-2016, 05:24 PM   #522
ogreasurada's Avatar
Hi, just got back in to rc after 2 years of blank, just got the new t4, and noticed it comes with a spool at the front axle, the track i will be running will be low-med surface, only med-high during race days, so should i get a front diff for practice time or just stick to the stock setup to get some feel first. thx
ogreasurada is offline   Reply With Quote
Old 02-18-2016, 08:07 PM   #523
alecladanga's Avatar
My 2 cents (driving the t4 '15 for more than 11 months now), it all depends on you and how you are really connected and familiar with your car. As I started with my '15 last year, I was using a Futaba 4PK radio and doing fine. When I switched to the M12S, I got faster, more consistent and got more "connected to car" to the point I was confident and daring enough to make set up changes in the kit and test it out and see my performance.
Prior to the end of 2015, I tested the Hagberg set up but retained some set ups that I felt were more suited to my driving. I posted the fastest lap and most number of laps in a 5 min run for 17.5T blinky in our recent club race.
To each his own
alecladanga is offline   Reply With Quote
Old 02-18-2016, 08:10 PM   #524
i think the use of the diff at front is when you do carpet racing and if the traction is really high.
our local asphalt track was low/medium before and using the spool was really great for me, though I have never tested the diff at the front ever.
Let's wait for the others to chip in
Old 02-18-2016, 08:56 PM   #525
Never tried in on the xray but my previous cars it did make it easier to drive mid out. I will say to test without it. The car is very easy to drive all around. The track I race low to mid asphalt.
SDVern is offline   Reply With Quote
