    Hide Wikipost
Old 03-17-2017, 02:10 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Xray T4 2016
Last edit by: R Dodge
Welcome to the XRAY T4'16 Thread & Wikipost! Here you will find some useful info, tips and tricks as well as setups that are used by several team drivers. This wikipost is a work in progress and should continue to develop over time.
Tips & Tricks:
Alex Hagberg's Tech Tip Tuesday articles
How to mount your Protoform LTC-R Body
Setting static camber
How to mount weight on your chassis Part1
How to mount the rear wing on Protoform bodies
Simple troubleshooting guide
How to mount the battery on your chassis
How to glue your front tires for CRC Black carpet with Eric Anderson
Utilizing Exponential and RMode on the M12S
How to mount weight on your chassis Part2
Team driver Tim Wahl posted some very useful tips on Facebook as he worked through building a new kit.
1- Carbon Parts
2-Suspension
3-Solid Axle and Differential
4-Bulkheads & Drivetrain
5-Driveshaft (ECS & CVD)
6-Front & Rear Suspension
7-Tweak
8-Anti-Roll Bar
9-Battery Fix (OPTIONAL)
10-Bumper & Body
11-Shocks
12-Steering
New Graphite Hubs:
Xray have recently released some additional Graphite hubs for the T4 lineup. The 4° Graphite C-Hub has been out for some time and is known to improve steering on entry, and in general makes the car turn better. This has been the go-to c-hub on asphalt for many on the Xray team, though it is not needed on high bite carpet. The Graphite rear hub tends to make the car more stable, especially on corner entry. We are still working on gathering input on the new Graphite steering block, but for the moment feel that it should improve steering response. All Graphite parts are approximately 1g lighter than the Hard or Medium options.
Option Parts to consider:
XRA301196 T4 Graphite Upper Deck 1.6mm V2
XRA301226 Foam Bumper – Hard - highly recommend
XRA302165 Composite Front Suspension Arm 2-Hole – Hard
XRA302169 Composite Front Suspension Arm 1-Hole – Graphite
XRA302803 1.3mm Front Anti-Roll Bar
XRA303169 Composite Rear Suspension Arm 1-Hole – Graphite
XRA303802 1.2mm Rear Anti-Roll Bar
XRA305137 Steel Solid Axle Driveshaft Adapters - HUDY Spring Steel - highly recommend
XRA305242 Composite Drive Shaft Replacement Cap 3.5mm – Orange – Strong (QTY 4)
XRA305351 Aluminum Wheel Hub – Offset “-0.75mm” – Black (QTY 2)
XRA306191 T4 Graphite + Aluminum Fully Adjustable Battery Holder
XRA308264 4S Spring-Set Progressive C=2.5-2.8 (QTY 2)
XRA308276 4S Spring-Set C=2.7 (QTY 2)
XRA308286 4S Spring-Set C=2.6 (QTY 2)
Specific to Asphalt:
XRA302383 Composite C-Hub Right – 4* - Graphite (ECS)
XRA302384 Composite C-Hub Left – 4* - Graphite (ECS)
XRA308039 Aluminum Progressive Shock System – Set (QTY 2)
Specific to Carpet:
XRA301141 T4 Aluminum Flex Chassis 2mm
XRA302375 Composite C-Hub Right – 6* - Hard ***Modification may be required if they don't have the "ECS" stamp.
XRA302376 Composite C-Hub Left – 6* - Hard ***Modification may be required if they don't have the "ECS" stamp.
XRA303711-O Aluminum Rear Lower Suspension Holder – Front – RF
Recent Setups:
3 July 2016 - Alex Hagberg - European Championship - Asphalt - Mod - 2nd
3 July 2016 - Bruno Coelho - European Championship - Asphalt - Mod - 4th
3 July 2016 - Jan Ratheisky - European Championship - Asphalt - 13.5 - TQ + Win
29 June 2016 - Max Kuenning - Reedy - Asphalt - Mod - 4th
29 June 2016 - Keith Yu - Reedy - Asphalt - 13.5 - TQ + 2nd
29 June 2016 - Eric Anderson - Reedy - Asphalt - 13.5 - 3rd
15 May 2016 - Bruno Coelho - ETS Rd 4 Riccione - Asphalt - Mod - TQ + Win
15 May 2016 - Mattia Collina - ETS Rd 4 Riccione - Asphalt - 13.5 - Win
17 April 2016 - Max Kuenning - MHIC - Carpet - Mod - 4th
10 April 2016 - Bruno Coelho - ETS Rd 3 Wels - Carpet - Mod - 2nd
10 April 2016 - Alex Hagberg - ETS Rd 3 Wels - Carpet - Mod - 4th
10 April 2016 - Jan Ratheisky - ETS Rd 3 Wels - Carpet - 13.5 - TQ + Win
22 March 2016 - Paul LeMieux - Canadian Nats - Carpet - Mod - TQ + Win
22 March 2016 - Luke Pittman - Canadian Nats - Carpet - Mod - 3rd
6 March 2016 - Chris Adams - ROAR Nats - Carpet - Mod - TQ + Win
6 March 2016 - Craig Xavier - ROAR Nats - Carpet - 17.5 - 4th
6 March 2016 - Eric Anderson - ROAR Nats - Carpet - 17.5 - 5th
6 February 2016 - Bruno Coelho - ETS Rd 2 Koblenz - Carpet - Mod - TQ + Win
6 February 2016 - Alex Hagberg - ETS Rd 2 Koblenz - Carpet - Mod - 2nd
31 January 2016 - Alex Hagberg - Snowbirds - Carpet - Mod - TQ + Win
31 January 2016 - Jan Ratheisky - Snowbirds - Carpet - All - See Comments
31 January 2016 - Drew Ellis - Snowbirds - Carpet - 13.5 - 4th
31 January 2016 - Robbie Dodge - Snowbirds - Carpet - 17.5 - Win
13 December 2015 - Bruno Coelho - ETS Rd 1 Hrotovice - Carpet - Mod - 3rd
13 December 2015 - Alex Hagberg - ETS Rd 1 Hrotovice - Carpet - Mod - 4th
13 December 2015 - Olly Jeffries - ETS Rd 1 Hrotovice - Carpet - Mod - 7th
13 December 2015 - Jan Ratheisky - ETS Rd 1 Hrotovice - Carpet - 13.5 - TQ + Win
29 November 2015 - Paul LeMieux - US Indoor Champs - Carpet - Mod - TQ + Win
25 October 2015 - Eric Anderson - Stock Wars - Carpet - 17.5 - 2nd
Print Wikipost
Like Tree2Likes
Old 02-10-2016, 12:14 PM   #466
RobS's Avatar
Does anybody know anywhere that has (preferably Xray brand) aluminum non flex chassis in stock? I've looked everywhere but can't find anybody that has one.
Rob Say
Action Hobbies Kingsville
"In racing you never really lose. You either win, or learn."
RobS is offline   Reply With Quote
Old 02-10-2016, 12:47 PM   #467
Can someone please explain the reasoning why none of the drivers in the MOD class do not use a motor fan in their ETS cars?
astgerma52sp is offline   Reply With Quote
Old 02-10-2016, 12:59 PM   #468
dcarroll's Avatar
Trader Rating: 35 (100%+)
more than likely because they aren't using any mechanical timing on the end bell like in spec classes.
____________________
***Fastlane Raceway***
"If it's fast and runs on flammable liquid then count me IN!!"
dcarroll is offline   Reply With Quote
Old 02-10-2016, 01:19 PM   #469
erchn's Avatar
Probably because they are indoors right now. When temperatures rise and they are outdoors it will be more necessary.
Serpent ; Desoto Racing ; Team Powers USA ; Reflex Racing ; Bezerk RC
erchn is offline   Reply With Quote
Old 02-10-2016, 01:26 PM   #470
Danny-b23's Avatar
Not terribly necessary on carpet.
I usually have one in my car, but it's more just for weight. I figure I may as well make the weight useful rather than just stick on another 1 or 2 chunks of tungsten.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 02-10-2016, 01:27 PM   #471
Danny-b23's Avatar
You and a whole lot of others. They've been backordered for a while now.
Danny Buck
Old 02-10-2016, 09:15 PM   #472
303slowdown's Avatar
Trader Rating: 24 (100%+)
What body is the go to for running on the new crc carpet? Mazda 6 or ltc-r ?
Ryan Borgheiinck
303slowdown is offline   Reply With Quote
Old 02-10-2016, 09:37 PM   #473
hey, guys, I am putting the my t4 on the setup station right now.
I found that the servo mount carbon fiber piece is slightly bent.
I tried to loose everything and re-tight the servo, it still looks slightly bent, is this normal?
I think my servo(protea 160ss) is perfectly fine, it works well on both trf 419 and spec r r1.
also, this results the servo outer side slightly touching the chassis, is this also normal?
I think they might have designed it to be this way...
I guess I am just not a fan of this servo mount.
yifuqiao is offline   Reply With Quote
Old 02-10-2016, 09:42 PM   #474
Have you taken it off and checked to see if it is truly bent? There is enough room for adjusting my servo up and down or crooked in the servo mount especially if the screws come loose.
SDVern is offline   Reply With Quote
Old 02-10-2016, 10:01 PM   #475
I am not lying man, if I see my servo from the front of the car,
it looks like this:
I think in my case, the carbon fiber piece is a little too long.
Old 02-10-2016, 10:04 PM   #476
erchn's Avatar
it looks like this:
Take an actual picture, it could just be a defective piece.
Old 02-11-2016, 12:43 AM   #477
Barry_Hughes's Avatar
http://www.rcdisco.com/part-info.php?partNo=XR301140
http://www.rccarshop.co.uk/spares/te...wiss-7075-t6-p
http://www.wheelspinmodels.co.uk/i/240513/
http://www.ebay.co.uk/itm/XRay-T416-...-/272080272114
all will ship worldwide
Built it !
Raced it !
Wrecked it !
Barry_Hughes is offline   Reply With Quote
Old 02-11-2016, 02:37 AM   #478
R Dodge's Avatar
That's kind of hard to say right now. I ran the MazdaSpeed6 at Snowbirds, which is the only time I've been on the new carpet, and it went pretty well however most of the Xray guys there were using the LTC-R, including EA, Drew, Xavier, Ralph and Alex. Sam Isaacs has been doing really well on the new carpet with the MS6 & Nazda2 - He won US Indoor Champs with the MS6 and just recently won the Hudy Race with the N2, both events were on the new carpet.
★RCAmerica •Xray •Hudy •Motiv •PROTOform •Gravity •Avid •TQ Wire •Sanwa •BSR •ProLevelRC •2mmDesigns •Timmy •5Nines★
R Dodge is offline   Reply With Quote
Old 02-11-2016, 02:42 AM   #479
Mr. MR4's Avatar
Default Asphalt Setup help
Im using asphalt stock setup on t4'16, but need more steering in 180deg hairpins and have slight oversteer in High speed sweepers.
Any ideas?
Xray T4'16 HobbyWing Xerun 120A V3.1
Xray X1'16 HobbyWing Justock
Yokomo R12C3 HobbyWing Xerun V3.1
Mr. MR4 is offline   Reply With Quote
Old 02-11-2016, 05:44 AM   #480
daleburr's Avatar
Any ideas?
The first thing to change are the springs; 2.5 are too soft for asphalt unless you're running in a very slow class. 2.7 are the standard outside. That will liven it up in the slow corners and should make it more stable through the fast stuff by reducing roll/grounding.
You can also drop to a 1.3 front roll bar, that normally gives more low-speed steering without increasing the high-speed steering.
If traction is good you can fit the layshaft/topdeck screws, which I see are removed on the kit setup. This normally takes off some high-speed steering and improves direction change through tight corners. But does cost some overall grip and makes it a little edgier.
Team Xray
RC-Timing Software - http://www.rc-timing.com
Mercedes AMG F1 - http://www.mercedes-amg-f1.com/
daleburr is offline   Reply With Quote
