    Hide Wikipost
Old 03-17-2017, 02:10 AM   -   Wikipost
R/C Tech Forums Thread Wiki: Xray T4 2016
Last edit by: R Dodge
Welcome to the XRAY T4'16 Thread & Wikipost! Here you will find some useful info, tips and tricks as well as setups that are used by several team drivers. This wikipost is a work in progress and should continue to develop over time.
Tips & Tricks:
Alex Hagberg's Tech Tip Tuesday articles
How to mount your Protoform LTC-R Body
Setting static camber
How to mount weight on your chassis Part1
How to mount the rear wing on Protoform bodies
Simple troubleshooting guide
How to mount the battery on your chassis
How to glue your front tires for CRC Black carpet with Eric Anderson
Utilizing Exponential and RMode on the M12S
How to mount weight on your chassis Part2
Team driver Tim Wahl posted some very useful tips on Facebook as he worked through building a new kit.
1- Carbon Parts
2-Suspension
3-Solid Axle and Differential
4-Bulkheads & Drivetrain
5-Driveshaft (ECS & CVD)
6-Front & Rear Suspension
7-Tweak
8-Anti-Roll Bar
9-Battery Fix (OPTIONAL)
10-Bumper & Body
11-Shocks
12-Steering
New Graphite Hubs:
Xray have recently released some additional Graphite hubs for the T4 lineup. The 4° Graphite C-Hub has been out for some time and is known to improve steering on entry, and in general makes the car turn better. This has been the go-to c-hub on asphalt for many on the Xray team, though it is not needed on high bite carpet. The Graphite rear hub tends to make the car more stable, especially on corner entry. We are still working on gathering input on the new Graphite steering block, but for the moment feel that it should improve steering response. All Graphite parts are approximately 1g lighter than the Hard or Medium options.
Option Parts to consider:
XRA301196 T4 Graphite Upper Deck 1.6mm V2
XRA301226 Foam Bumper – Hard - highly recommend
XRA302165 Composite Front Suspension Arm 2-Hole – Hard
XRA302169 Composite Front Suspension Arm 1-Hole – Graphite
XRA302803 1.3mm Front Anti-Roll Bar
XRA303169 Composite Rear Suspension Arm 1-Hole – Graphite
XRA303802 1.2mm Rear Anti-Roll Bar
XRA305137 Steel Solid Axle Driveshaft Adapters - HUDY Spring Steel - highly recommend
XRA305242 Composite Drive Shaft Replacement Cap 3.5mm – Orange – Strong (QTY 4)
XRA305351 Aluminum Wheel Hub – Offset “-0.75mm” – Black (QTY 2)
XRA306191 T4 Graphite + Aluminum Fully Adjustable Battery Holder
XRA308264 4S Spring-Set Progressive C=2.5-2.8 (QTY 2)
XRA308276 4S Spring-Set C=2.7 (QTY 2)
XRA308286 4S Spring-Set C=2.6 (QTY 2)
Specific to Asphalt:
XRA302383 Composite C-Hub Right – 4* - Graphite (ECS)
XRA302384 Composite C-Hub Left – 4* - Graphite (ECS)
XRA308039 Aluminum Progressive Shock System – Set (QTY 2)
Specific to Carpet:
XRA301141 T4 Aluminum Flex Chassis 2mm
XRA302375 Composite C-Hub Right – 6* - Hard ***Modification may be required if they don't have the "ECS" stamp.
XRA302376 Composite C-Hub Left – 6* - Hard ***Modification may be required if they don't have the "ECS" stamp.
XRA303711-O Aluminum Rear Lower Suspension Holder – Front – RF
Recent Setups:
3 July 2016 - Alex Hagberg - European Championship - Asphalt - Mod - 2nd
3 July 2016 - Bruno Coelho - European Championship - Asphalt - Mod - 4th
3 July 2016 - Jan Ratheisky - European Championship - Asphalt - 13.5 - TQ + Win
29 June 2016 - Max Kuenning - Reedy - Asphalt - Mod - 4th
29 June 2016 - Keith Yu - Reedy - Asphalt - 13.5 - TQ + 2nd
29 June 2016 - Eric Anderson - Reedy - Asphalt - 13.5 - 3rd
15 May 2016 - Bruno Coelho - ETS Rd 4 Riccione - Asphalt - Mod - TQ + Win
15 May 2016 - Mattia Collina - ETS Rd 4 Riccione - Asphalt - 13.5 - Win
17 April 2016 - Max Kuenning - MHIC - Carpet - Mod - 4th
10 April 2016 - Bruno Coelho - ETS Rd 3 Wels - Carpet - Mod - 2nd
10 April 2016 - Alex Hagberg - ETS Rd 3 Wels - Carpet - Mod - 4th
10 April 2016 - Jan Ratheisky - ETS Rd 3 Wels - Carpet - 13.5 - TQ + Win
22 March 2016 - Paul LeMieux - Canadian Nats - Carpet - Mod - TQ + Win
22 March 2016 - Luke Pittman - Canadian Nats - Carpet - Mod - 3rd
6 March 2016 - Chris Adams - ROAR Nats - Carpet - Mod - TQ + Win
6 March 2016 - Craig Xavier - ROAR Nats - Carpet - 17.5 - 4th
6 March 2016 - Eric Anderson - ROAR Nats - Carpet - 17.5 - 5th
6 February 2016 - Bruno Coelho - ETS Rd 2 Koblenz - Carpet - Mod - TQ + Win
6 February 2016 - Alex Hagberg - ETS Rd 2 Koblenz - Carpet - Mod - 2nd
31 January 2016 - Alex Hagberg - Snowbirds - Carpet - Mod - TQ + Win
31 January 2016 - Jan Ratheisky - Snowbirds - Carpet - All - See Comments
31 January 2016 - Drew Ellis - Snowbirds - Carpet - 13.5 - 4th
31 January 2016 - Robbie Dodge - Snowbirds - Carpet - 17.5 - Win
13 December 2015 - Bruno Coelho - ETS Rd 1 Hrotovice - Carpet - Mod - 3rd
13 December 2015 - Alex Hagberg - ETS Rd 1 Hrotovice - Carpet - Mod - 4th
13 December 2015 - Olly Jeffries - ETS Rd 1 Hrotovice - Carpet - Mod - 7th
13 December 2015 - Jan Ratheisky - ETS Rd 1 Hrotovice - Carpet - 13.5 - TQ + Win
29 November 2015 - Paul LeMieux - US Indoor Champs - Carpet - Mod - TQ + Win
25 October 2015 - Eric Anderson - Stock Wars - Carpet - 17.5 - 2nd
Print Wikipost
Like Tree2Likes
Old 10-12-2015, 12:58 AM   #136
Just received my kit and good portion of options I ordered (some on back order!)
Looking forward to the build. Even the plastic bags feel higher quality (lols!) than what I'm used to 😀
For the seasoned T4 builders - anything to watch out for ??
cplus is offline   Reply With Quote
Old 10-12-2015, 01:51 AM   #137
Skiddins's Avatar
Only thing that springs to mind is not to bother with the thin O-ring in the diff.
It's very difficult not to accidentaly pinch it while assembling and then it leaks.
The team drivers don't bother either. Once the paper gasket has soaked some oil into it etc it seals fine on its own.
Skiddins
Xray T4'17, T4'14 (Wet Car)
Xray X12 2017
Xray X1'16
wlrc.co.uk (West London Racing Centre)
RCDisco.co.uk
Skiddins is online now   Reply With Quote
Old 10-12-2015, 05:52 AM   #138
3D-Seth's Avatar
Trader Rating: 21 (100%+)
Is this car available in the states yet? I see amain has it on preorder...
3D-Seth is offline   Reply With Quote
Old 10-12-2015, 06:21 AM   #139
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
They should arrive any day now. I'll have them up on my site before weeks end as well.
EA
Contact Us
Team EAM, Our Facebook
Xray | RCAmerica | Hudy | Apex RC | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 10-12-2015, 10:35 AM   #140
Trader Rating: 5 (86%+)
Reflex racing will be the first ones to have them as they are based in Houston and rcamerica is in Dallas.
Smithracer11 is offline   Reply With Quote
Old 10-12-2015, 10:51 AM   #141
jlfx car audio's Avatar
Trader Rating: 36 (100%+)
Was told this am that shippments will be going out tomorrow
jlfx car audio is offline   Reply With Quote
Old 10-12-2015, 12:29 PM   #142
Does anyone know what alu. servoarm fits Savox? Hudy does not fit according to the site (25t like Futaba). Radtec maybe?
Also how long should it be, C-C.
Lawson1307 is offline   Reply With Quote
Old 10-12-2015, 01:04 PM   #143
Trader Rating: 27 (100%+)
Savox is 25t like Futaba.
Length? No clue!
Xray | Airtronics | R1Wurks LiPo | Hobbywing
hyujmn is offline   Reply With Quote
Old 10-12-2015, 01:19 PM   #144
Length? No clue!
Yeah I know, don't understand why it says "does not fit Savox" on the Hudy site?? Seems like 16mm C-C is good.
Old 10-13-2015, 07:45 AM   #145
millbank's Avatar
Just some shots of the new car 😃
millbank is offline   Reply With Quote
Old 10-13-2015, 11:01 AM   #146
Brokin Racing's Avatar
Trader Rating: 68 (100%+)
Skiddins
2nd that!
You'll find it a pleasure to build, enjoy. ....
Xray - LRP - PF - Futaba -
Brokin Racing is offline   Reply With Quote
Old 10-13-2015, 12:28 PM   #147
Last photo: Rear body posts are mounted the wrong way. Now your rear upper links will rub against the body posts
www.rcpit.nl , RC dealer
www.machheemstede.nl
..................................Youtube: https://www.youtube.com/watch?v=_-Gkh2xZcQU
Modified 4 life
Govert is offline   Reply With Quote
Old 10-14-2015, 12:03 AM   #148
millbank's Avatar
No they're not as i shamfer the bottoms so the links don't catch. Its because i run a hpi scooby type c shell and with the body posts mounted the other way they come up in the rear wing mounts.
Old 10-14-2015, 12:47 AM   #149
wwddww34's Avatar
Trader Rating: 9 (91%+)
Got one of these delivered today. I can't wait to start the build!
https://www.facebook.com/groups/BananaRaceway/
wwddww34 is offline   Reply With Quote
Old 10-14-2015, 11:51 AM   #150
3D-Seth's Avatar
It appears that this kit comes with 48p spur gear? My VBC was 64p... Is that correct? I have both 48p and 64p pinions, so don't really care, just want to confirm. Either really matter? Will be running asphalt most of the time more than likely.
Will be running 13.5 blinky, should I get a 92/96T 64p (or 78T 48P) spur up front?
Sorry, new to the XRay gang...
Seth
