Old 10-25-2005, 02:55 PM   #1
thecrow2k's Avatar
Default GP3300 Cutoff
What mv for a pack does everyone set the cutoff at, ive heard 30mv/pack but also 15mv/pack, I was sure 30 was about right, what is the opinion.
thecrow2k is offline   Reply With Quote
Old 10-25-2005, 03:42 PM   #2
Send a message via AIM to rcguy2477
What charger are you using? Cutoff often depends on the charger, as some use 2mv up to 6mv.
1989 Mazda Rx7
greddy t04b, megasquirt ecu, PlX wideband, 12x28x3 fmic, 50mm hks clone wg, ssqv bov, Safc, ss oil lines, walbro fuel pump, tubo intake manifolds, ssac exhaust manifold, 3" dp, 550cc primary/720cc secondary injectors, etc.
rcguy2477 is offline   Reply With Quote
Old 10-25-2005, 10:56 PM   #3
Sushi Man's Avatar
Send a message via AIM to Sushi Man
Hey crow for a pulsar comp two right? i think10mv will work.!
Sushi Man is offline   Reply With Quote
Old 10-25-2005, 11:15 PM   #4
Hyperform Racing's Avatar
I usually don't get involved in these discussions because people tend to want a cold hard "0.02 volt peak detect" type answer but I always set peak detect based on temperature of the pack. I always want my cells to peak at 135 degrees whether they are GP3300s, GP3700s or IB3800s. This means my peak detect will vary from say 0.01-0.05 depending on the ambient temperature of the room I'm charging in and the rate Iím charging at. In other words, in the summer, my peak detect may be 0.01 but in the winter, I'm up around 0.05. It's almost a necessity to have a temp gauge on hand for electric racing these days. You can get decent infrared ones for around $30. I may catch flack from other battery companies, but that's what I do and recommend to all my customers...
Hyperform Racing
(978) 416-2572
Hyperform Racing is offline   Reply With Quote
Old 10-26-2005, 05:04 AM   #5
Revs's Avatar
Id suggest a starting cut off of 15,
Revs is offline   Reply With Quote
NIB GTB W/ Lipo Cutoff kartermdb R/C Items: For Sale/Trade 0 07-31-2008 02:08 PM
Looking for GTB w/LiPo cutoff Scottrik R/C Items: Wanted to Buy 3 04-16-2008 05:54 AM
GTB w/ lipo cutoff convikt R/C Items: For Sale/Trade 0 02-17-2008 10:04 PM
LED cutoff voltage? joe of loath Chat Lounge 13 12-07-2007 04:02 AM
GTB Lipo cutoff _pilot_ Electric On-Road 15 10-14-2007 08:30 PM
SEO by vBSEO 3.5.0
