Like Tree8Likes
Old 07-19-2017, 07:08 PM   #931
Originally Posted by Cudacharger View Post
September issue RC Car Magazine...
Ooooo, it's now a magazine car. Very cool. Wasn't sure there were any RC magazines left.
Cudacharger likes this.
Billy Kelly is offline   Reply With Quote
Old 07-20-2017, 09:44 AM   #932
Send a message via AIM to GuyIsDamGood
Originally Posted by Airwave View Post
As this car has an very low internal ration (about 3.07), blinky ratios are very hard to reach. To reach 1:5.0 you have to mount a 80T spur gear in 64DP and mount a 50T pinion...
By the way I'm quite afraid that this car is too heavy for stock classes.... :-(
Install the 64-Pitch Gear Set-Up. It can get you the gearing you need. . .?
GuyIsDamGood is offline   Reply With Quote
Old 07-21-2017, 06:19 AM   #933
Airwave's Avatar
Not sure of what is the meaning of your question...
Airwave is offline   Reply With Quote
Old 07-22-2017, 02:55 AM   #934
I believe you mentioned 64-pitch gearing("64DP").
my bad.
I'll try something out with the gearing. . .(I'm off work for the next 3-days).
And; I don't get this Blinky stuff. . .?
Old 07-22-2017, 04:24 AM   #935
Airwave's Avatar
No no you're right I was talking about 64-pitch... But it was just my choice because I used to use it and as the primary transmission is protected you are taking no risk...
Old 07-22-2017, 11:08 AM   #936
Hey,
I'm new here. Glad to find an active forum on RC Cars. I have a question, I'm looking for sway bars for my RS4 Sport 3 Flux, what you guys recommend?
aviannaracing is offline   Reply With Quote
Old 07-22-2017, 12:20 PM   #937
I'm sure the stock class rules would allow you to install the carbon fiber and aluminum parts from hpi, since some AE cars run aluminum parts as stock.
My rs4 3 was the Subaru phatlace drift version, so the suspension is set up different, I picked up a used flux version, (minus the motor/esc) and its set up different. Could be whoever owned it fixed it or they change them at the factory.
Sway bars, try the Hotbodies set or some have suggested the AE sway bars.
Beef is offline   Reply With Quote
Old 07-25-2017, 02:18 AM   #938
Hey Airwave.
The RS4 Sport 3 chassis is heavy because of the Steel Center Shaft, those HEAVY Diffs(Diecast Ring Gear) and the Diecast Bevel Gears.
The Blinky Ratio you want is scary. (you have money to burn. . .Ha Ha!. . . Have fun!)
Tell me how well you do.
Old 07-25-2017, 04:56 AM   #939
Airwave's Avatar
I was talking about blinky-0-timing, meaning the modifying the timing on the motor can is forbidden...
With that kind of setup, 1:5 is quite the optimal...
About the weight I will try to run a shory... Initially I bought this chassis for Rally, so...
Old 07-25-2017, 08:08 AM   #940
Cudacharger's Avatar
[QUOTE=GuyIsDamGood;14984586]Hey Airwave.
You can reduce major weight on this car with the Exotek drive shaft and alloy diff gears, spur mount & hpi spool set.
• Exotek Alloy Drive Shaft – #1540
• Exotek Alloy Front Diff Gear – #1574
• Exotek Alloy Rear Diff Gear – #1574
• Exotek Alloy Spur Gear Mount – #1541
• HPI Racing 40T Spool Set – #114436
aracefan and lifeofbrian like this.
Cudacharger is offline   Reply With Quote
Old 07-26-2017, 02:08 AM   #941
I looked-up Blinky Ratio. It said you can over-gear the motor while trying to achieve a faster top speed on the straight.
-The Blinky set-up sounds like more work (on-top of a lot of hard work).
Tell me how you got it done.
Old 07-28-2017, 03:23 AM   #942
Airwave's Avatar
to find the proper ratio? start with something sure, like 1:6.0 and add teeth to the pinion. run for 2 minutes, check with a temp gun and compare the time.
That's why I hate blinky lol
Old 07-29-2017, 01:58 AM   #943
Thanks for the info Cudacharger.
I only install factory parts on my chassis. But; those aftermarket parts look nice.
I installed the Spool.(it might be the last upgrade I install on the chassis)
Old 07-29-2017, 07:08 AM   #944
I also try and stay with factory parts myself when possible. Here's some others from Hpi I have on my car.
HPI Racing Option Parts
HPI Racing Carbon Fiber Center Drive Shaft Cover Set #114432
HPI Racing Front Carbon Fiber Shock Towers #114433
HPI Racing Rear Carbon Fiber Shock Towers #114434
HPI Racing Aluminum Shock Set #114435
HPI Racing High Speed Gear Set #114569
HPI Racing 40T Spool Set #114436
HPI Racing Porsche RSR Alloy Wheel Nuts #109504
Old 08-01-2017, 01:51 AM   #945
Hey Cudacharger;
I thought about buying those Upgrades you listed for my RS4 Sport 3 chassis. But they're too pricey for this HPI chassis.
Tell me how well you do at the races with those Upgrades installed on the chassis.
