Like Tree8Likes
Old 06-21-2017, 02:24 AM   #916
Send a message via AIM to GuyIsDamGood
Did I read it correctly?. . .You're running a RS4 Sport 3 against some pro chassis?
Tell me how well the race goes for you. . .Good luck.
GuyIsDamGood is offline   Reply With Quote
Old 06-21-2017, 03:07 AM   #917
We had one try to set one up to run a USGT class last year. It didn't work
Billy Kelly is offline   Reply With Quote
Old 06-21-2017, 10:24 AM   #918
Why didn't it work(you couldn't get the right Set-Up)?
Old 06-21-2017, 01:23 PM   #919
Lone Drifter's Avatar
Probably cause It'sTooDamOld ( sorry could not resist )
USVTA , USGT and Wheeler
TC7, TC6, T3 11 & 12, and TLR 22-4
Lone Drifter is offline   Reply With Quote
Old 06-21-2017, 03:35 PM   #920
Wasn't me. Same problem that almost all RTR have. Internal gearing is wrong. Could not get it geared right to work within USGT rules. I gave it a try but then bought a SpecR.
Old 06-21-2017, 03:39 PM   #921
RS4 Sport3 was released in July of 2015. Its been confused with the older RS4 a number of times. Just used the old RS4 name.
Old 06-22-2017, 11:15 PM   #922
SuperFastSnail's Avatar
Trader Rating: 77 (100%+)
Default RS4 Sport 3 vrs Traxxas 4-Tec 2.0
Picked up the 4-Tec 2.0 today and I must say, it looks almost identical to the RS4 Sport 3. Major difference is that the 4-Tec has Traxxas stability built in, plastic motor mount and a 3 piece chassis design, nice body mount system.
JU KE
Sponsor by Makita Li-Ion Brushless Power Tools. Eat the power!
Selling something but no pictures, goodbye.
SuperFastSnail is offline   Reply With Quote
Old 06-24-2017, 03:11 AM   #923
Hey Billy Kelly. Sorry to hear it couldn't work-out for you with the RS4 Sport 3 at the race.
You say it was a gearing issue (problem with the ratio)?
I installed 64-pitch gears on my RS4 Sport 3. (would that make a difference?. . .I don't know about USGT rules)
Old 06-24-2017, 03:25 AM   #924
It wasn't me that tried. I sold mine after 3 months. USGT uses 21.5 motors. 64p gearing might have helped. But even then not sure if he could have gotten it geared right.
Old 07-18-2017, 03:07 AM   #925
Default Wider Front...?
I measured the Rear and Front Track-Width of the RS4 Sport 3 chassis (with 6mm Off-Set Wheels mounted).
-the Front Track-Width is wider than the rear
-The Wider Front Track-Width is for More Steering Leverage.
Or; it's only my chassis. . .?(my RS4 Sport 3 chassis had a weird set-up straight out of the box). . .I changed it. Now it runs like a normal chassis.
Old 07-18-2017, 12:39 PM   #926
What do you mean by a weird setup? I've just ordered one of these, what do you recommend I do for general street bashing, anything?
lifeofbrian is offline   Reply With Quote
Old 07-18-2017, 02:30 PM   #927
Cudacharger's Avatar
Make sure to check your gear mesh before running first time other then that plug the lipo in and let her rip.
If your going to upgrade the car here's a good baseline that will direct you to the part list of hop-ups available.
Project: HPI Desert Land Shark - RS4 Sport 3 FLUX Build
lifeofbrian likes this.
Cudacharger is offline   Reply With Quote
Old 07-19-2017, 02:10 AM   #928
Hey lifeofbrian;
I purchased the RS4 Sport 3 with the Brushed Motor (Orange BMW).
-the Caster was off Rear and Front.
-the Inside Suspension Mounts were set with 2mm too much. . .The chassis couldn't run straight.
I fixed it.
The Brushless Motor version might not have those build mistakes...?
Old 07-19-2017, 02:36 PM   #929
Airwave's Avatar
As this car has an very low internal ration (about 3.07), blinky ratios are very hard to reach. To reach 1:5.0 you have to mount a 80T spur gear in 64DP and mount a 50T pinion...
By the way I'm quite afraid that this car is too heavy for stock classes.... :-(
Airwave is offline   Reply With Quote
Old 07-19-2017, 02:54 PM   #930
September issue RC Car Magazine...
Drift_Buggy and Billy Kelly like this.
