Like Tree12Likes
Old 01-19-2017, 09:44 AM   #871
Cudacharger's Avatar
Nice story. Gotta give you credit for sticking with a vehicle most of us gave up on.
Thanks BK!
Cudacharger is offline   Reply With Quote
Old 02-04-2017, 04:46 AM   #872
Send a message via AIM to GuyIsDamGood
Setting the gear mesh on this chassis makes me angry.(I changed the gears to 64-pitch)
GuyIsDamGood is offline   Reply With Quote
Old 02-04-2017, 08:10 AM   #873
Any pic's....
Old 02-05-2017, 04:50 AM   #874
All of my pictures are on a cell phone. I don't know how to post pictures on this site(I've tried).
It's my son's HPI RS4 Sport 3 chassis.
I took old 64-pitch gears from my HPI Pro 4 and installed them on the RS4 Sport 3.
Old 02-05-2017, 07:55 AM   #875
Photobucket app. Took me 3 years to figure out how simple it was. Only bad part is getting around 15 emails a week from them. Not worst thing.
Billy Kelly is offline   Reply With Quote
Old 02-07-2017, 11:28 AM   #876
Thanks for the info Billy Kelly.
My daughter told me to keep the app downloads to a minimum.
But; I really want to show my R.C. Car pictures.
Old 02-14-2017, 02:44 PM   #877
Is there another company besides Tamiya that makes a 46mm outer-drive shaft that fit?
(The Hot Bodies 46mm outer-drive shaft pins can't fit in the Outdrives.)
Old 02-14-2017, 03:40 PM   #878
SpecR was what most owners used back when it was first released. I can't remember part number. You would have to check back to the early pages. Think it's was SpecR Tamiya cvds. 46mm. With them you can just skip the stock dog bones.
Old 02-17-2017, 04:43 AM   #879
Super Moderator
Marcos.J's Avatar
Trader Rating: 181 (100%+)
i have a new gear diff for the Sport 3 if anyone needs it
http://www.rctech.net/forum/r-c-item...l#post14840442
Old 02-18-2017, 04:23 AM   #880
I think item # 51092 - Tamiya 46mm Swing Shafts; will be a better fit in the Front. . .(how weird; Tamiya parts installed on an HPI chassis)
Old 02-18-2017, 05:54 AM   #881
Welcome. It's was on page 4
Sports Series Swing Shaft (For Tamiya 46mm) [SPR012-TM46B] - $16.60 : Spec-R, The Professional Accessories for R/C
These are what most of us early owners used.
Old 02-18-2017, 10:13 AM   #882
Yeah Racing has them as well.
Old 02-27-2017, 10:08 AM   #883
Thanks for the info Billy Kelly and Cudacharger.
I'll install the Tamiya Outer Drive Shafts on the RS4 Sport 3.
Old 02-28-2017, 03:18 PM   #884
@cudacharger what trailing arms are you using? Also are those Yeah racing springs?
At this point mine is stock and I have the SpecR shafts waiting to be installed and have been debating with where to go next, the car is sloppy so I just want to make her a little more stable. From my research it seems like the Yeah racing set up is the way to go.
slowprogress is offline   Reply With Quote
Old 02-28-2017, 04:27 PM   #885
Here's my parts list & build hope this helps.
http://www.competitionx.com/project-...project-build/
Parts List
Yeah Racing Option Parts
Yeah Racing Aluminum Front Lower Arm Set For HPI RS4 Sport 3 #RSS3-001OR
Yeah Racing Aluminum Rear Lower Arm Set For HPI RS4 Sport 3 #RSS3-002OR
Yeah Racing Ball Bearing Aluminum C-Hub Set For HPI RS4 Sport 3 #RSS3-003OR
Yeah Racing Aluminum Front Knuckle Arm Set For HPI RS4 Sport 3 #RSS3-004OR
Yeah Racing Aluminum Rear Hub/Knuckle For HPI RS4 Sport 3 #RSS3-005OR
Yeah Racing Universal Shaft Set For HPI RS4 Sport 3 #RSS3-006OR
Yeah Racing Aluminum Ball Bearing Steering Arm Set For HPI RS4 Sport 3 #RSS3-007OR
Exotek Option Parts
Exotek Turnbuckle Set #1569
Exotek Alloy Drive Shaft #1540
Exotek Alloy Front Diff Gear #1574
Exotek Alloy Rear Diff Gear #1574
Exotek Alloy Spur Gear Mount #1541
Exotek Pro5 12mm Clamping Hex #1551
HPI Racing Option Parts
HPI Racing Carbon Fiber Center Drive Shaft Cover Set #114432
HPI Racing Front Carbon Fiber Shock Towers #114433
HPI Racing Rear Carbon Fiber Shock Towers #114434
HPI Racing Aluminum Shock Set #114435
HPI Racing High Speed Gear Set #114569
HPI Racing 40T Spool Set #114436
HPI Racing Porsche RSR Alloy Wheel Nuts #109504
Other Accessories
Castle Creations 1/8th Brushless Motor Cooling Fan #011-0004-00
GPM Aluminium Motor Heat Sink Mount #SP3018
Hot Bodies Graphite Bumper Brace #68715
Kimbrough Racing Spur Gear 48P 66T #301
LED Lights front and rear
Tamiya Headlight Buckets GT3 Porsche
