HPI RS4 Sport 3
#856
#857
hello from greece. Im about getting either sport 3 or xv01 under the xmas tree and i must say that your research on the car helped me alot to get started properly. I need some help with a couple of things though. Does anyone ran this car off road? What is the max ground clearance you can get without any mods? What about a rally body? Can i get this body fit http://www.rcmart.com/lancia-delta-i...?cPath=438_875? I believe tamiya's xv-01 bodies are 190 so won't fit am i right? What shocks do you think i should get? Do you think that optional hpi alum. shocks are up to the task?
Thanks in advance,
yannis
Thanks in advance,
yannis
#858
I run 190mm they fit ok..
#859
Thanks in advance,
yannis
Thanks in advance,
yannis
You can fit 190mm bodies on this chassis.
The HPI aluminum shocks are decent shocks, but again, if you're thinking of doing rally style off-roading, they won't be the game changer you're looking for to make this capable of doing that, at least reliably and predictably.
#860
I'm looking at having some foams made for the factory BBS wheels...the stock tires are ballooning too much.
Call 911
Call 911
#861
The crazy steering problem is now fixed.
#862
US Postal Service MESSED-UP
The USPS had my package in another post office(the next zip code over) since December 19th. I haven't received it yet. We couldn't wrap the parts for my son's RS4 Sport 3 for the holiday.
#863
#864
I haven't received it yet. USPS lost or stolen the package.
#865
Thanks in advance,
yannis
Thanks in advance,
yannis
Read through this thread to see what mods you could do to make it run better/smoother.
#866
Detailed review of the car on CompetitionX.com
http://www.competitionx.com/project-...project-build/
#867
#868
No Land Shark...
I stayed with the chassis because it's my son's car. I fixed the steering problem, installed a better steering servo and added a radio (with EPA) now the chassis runs well.
The article listed alot of aftermarket parts. That's tell'n us something(good and bad).
Take Care
Take Care
#869
It depends on the usage you will have...
I suppose that you can update the shocks tower, buy spring steel CVD and the arms axle support from GPM. It will make the car more reliable. You can also buy a second front bumper to mount it on the rear.
The aluminum steering could be more precise but I'm not even sure. The turnbuckle set would be nice if you are racing on asphalt or carpet.
Yeah racing aluminum is not very resistant and arms or CVD will break on crashes...
#870
I agree. . . . .(But; the PRO 4 has a 3/4 plastic steering and it's steering is good)
But HPI only made a few upgrades.(I gave up on the turnbuckles. They never came-out. I installed PRO 5 turnbuckles instead)
I also slowed-down the front differential.
