Like Tree12Likes
Old 08-19-2016, 09:42 AM   #826
Send a message via AIM to GuyIsDamGood
Default Hot Bodies and HPI stuff
I use HPI Pro 4 ball cups and ball studs.
And HPI Pro 5 turnbuckles.
-Ball Cups
Item # 73510
-Ball Studs
Item # 75115 - 4.3 x 10.3mm
Item # 75116 - 4.3 x 13mm
-Turnbuckles
Item # 61246 - 3 x 24mm
Item # 112960 - 3 x 34mm
Take Care
GuyIsDamGood is offline   Reply With Quote
Old 09-25-2016, 11:32 AM   #827
Hello guys,
we´re you guys able to fix the steering problem with the rs4 sport 3? I used a realy strong servo (Savox) but the steering is still bad. It doesn´t return to center. I really don´t know why and how to fix this.
Do you have any tips for me?
I´m thinking about buying the yeah aluminium steering parts. Do they help ?
Many thanks in advance.
Mario084 is offline   Reply With Quote
Old 09-29-2016, 09:53 AM   #828
The problem is with the stock Tie-Rods. - Or - there's binding in the C-Block / Steering Knuckle area. Or - the Shock Shaft is binding against the O-Rings (1or more shock shafts).
Old 09-29-2016, 05:57 PM   #829
Ghos7's Avatar
Originally Posted by Mario084 View Post
Hello guys,
Yes, aluminum parts helped but I also replaced the servo with a 20kg Power HD. Also I tightened the large 10mm nut down on the servo arm/horn. My Sport 3 steering completely returns back to 0/center without hesitation. However if you do not wish to replace the servo and suspension yet, I suggest tightening that horn bolt down first. Unfortunately I'm not able to post pics on the forums yet
I will post pics with the complete YR suspension/steering kit installed on my build log soon: tackk.com/rennen-rc
Ghos7 is offline   Reply With Quote
Old 10-02-2016, 05:11 AM   #830
Tightening the Servo Saver will mess-up your servo in a crash. Drive carefully.
Old 10-05-2016, 06:11 PM   #831
Ghos7's Avatar
To give an update on this issue, I still found slop in the steering after a couple session. There is to much play in the Sport3's oem servo saver, this was the issue in my case at least. With the servo centered I can move it left to right, in each direction before feel resistance from the servo. I just replaced it completely with one of the Horizon billet aluminum servo horns ($7), and the steering is now rock solid. @GuyIsDamGood", most definitely. Fortunately this car is being built for a local flat rally course so I shouldn't have to worry about kissing any curbs or doing any jumps.
Old 10-09-2016, 05:44 AM   #832
Default Too Much Steering Play
I checked out the Servo-Saver on my RS4 Sport 3. I didn't see any normal operating play on/with the Servo-Saver. But there is a good amount of play at the the Bell Cranks and Steering Bridge(mostly).
You'll have to apply some force to the Servo-Saver to create a Servo-Saver gap.
Old 10-27-2016, 06:48 AM   #833
Page after page of steering problems with this car. This morning I shot some video of my buddy's Sport 3 BMW going around in circles because a tiny rock had jammed up the steering after less than a minute of running. He'd go dig the rock out and less than a minute later, it would be jammed up again. Exact same problem I had with my flux Porsche. Not fun.
My hovercraft is full of eels.
Metal One is offline   Reply With Quote
Old 10-29-2016, 05:13 AM   #834
To keep pebbels off your chassis; sweep the track before you run your car.
Old 10-29-2016, 05:28 AM   #835
Works for track surface. But most run parking lots. And can try to clear things out but epically this thine of year, with leaves falling off trees constantly, normal parking lot traffic, even condition of surface.
Billy Kelly is offline   Reply With Quote
Old 10-29-2016, 09:06 AM   #836
Cudacharger's Avatar
I agree a blower works well also. This car loves a good surface.
Cudacharger is offline   Reply With Quote
Old 10-29-2016, 12:26 PM   #837
They used a blower to clear parking lot for TC racing at hobby store over summer. Even then still had few cars still get rocks or sticks caught up.
I'm speaking for touring cars in general. Not the Sport3.
Old 10-31-2016, 01:59 AM   #838
Default Crazy-Weird Pinion and Pinion Spur Gear Mesh
Setting the Gear Mesh on the Pinion and Spur Gear on this chassis is a pain.
-the Motor-Mount or the Spur-Gear is crooked. . .(only on my chassis?)
-2-ply sheets of paper is needed to set the Gear-Mesh properly. . .(only on my chassis?)
-I don't get the Motor-Mount design
Old 11-03-2016, 07:34 PM   #839
The pebble in the steering issue is solved by putting a piece of Velcro ( furry side) under the steering rack.
As for the gear mesh try just one ply, it seems ok on mine.and yeah the spur seems to be really close the the rear of the cover.
Anyone have a setup sheet for carpet racing their rs4 3?
I started with the Subaru fatlace, so I'm set up all wrong for a carpet short track 45'x 25,-30'
I've got the yeahracing set minus the arms installed, Exotek shaft and spur, gpm motor mount, and some Lunsford turnbuckles. Also a savox servo, I'm waiting on a new horn before I install it.
We're running 21.5 and my spurs 66 pinion 27(biggest I got for now)
Beef is offline   Reply With Quote
Old 11-22-2016, 01:25 PM   #840
Originally Posted by mpike24 View Post
Hey guys I am new the rc world. My father in law just got me into it. Any ways I was wondering if anyone has new updates on hpi I want one of these cars... Oh and I have read all 55 pages of this post and it was hard the pages keeps crashing lol.
Any way thanks in advance.
I'm in the same boat coming back to RC. Was wondering if an RS sport3 would cut in in a sportsman(run what you brung) class? Don't care on winning, just finishing and having a good time. Or should I just build up a TT02 with silver can motor?
quinto73 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
