Like Tree8Likes
Old 03-25-2016, 04:15 PM   #676
Mr Wood's Avatar
The velcro idea can't work. It's too simple. I'm totally trying this out as soon as I get off work. 👍
Mr Wood is offline   Reply With Quote
Old 03-26-2016, 09:31 AM   #677
Cudacharger's Avatar
Great idea thanks for sharing. Car looks very stout blitteer nice job.
Cudacharger is offline   Reply With Quote
Old 03-27-2016, 01:40 PM   #678
Mr Wood's Avatar
Default Bent lower arm.
I bent my front lower Yeh Racing arm on its first run. I also tried the velcro under the steering but it doesnt seem to be working for me. But man am i bummed about bending that arm.
Old 03-27-2016, 02:58 PM   #679
Airwave's Avatar
Man, you should know that Yeah Racing parst are made for shelf queens... You cannot really use them...
Airwave is offline   Reply With Quote
Old 03-27-2016, 03:20 PM   #680
Mr Wood's Avatar
Lol. Yeah I didn't know that. Live and learn I guess. I have bent it back in to shape, mostly. Worst case I can rock out my old plastic lower arm. Sure looked good though.
Old 03-27-2016, 04:27 PM   #681
LOL I've been using the full YR aluminum kit on my Sprint 2 for years now and have had no issues with any of their parts. I use their aluminum adjustable dampers also. In fact, my ONLY problem with them is that 2 of the set screws for the lower arms in the RS4 kit weren't tapped to accept a hex driver.
wareagle84 is offline   Reply With Quote
Old 03-27-2016, 04:31 PM   #682
I'm guessing you hit something pretty hard/fast? By the looks of it, I doubt anything other than maybe steel would have held up in that situation.
Old 03-27-2016, 06:43 PM   #683
Mr Wood's Avatar
Ok I can see how you would think I hit somthing hard and fast and if you saw my awesome driving skills you would normally be right. However this time I flipped in to a ditch after catching my left tire on the grass. Landing on my lid in water. Must be some out side forces at play here. I wasn't very nice to guy last night maybe karma kicked me. Lol.
Old 03-28-2016, 09:36 PM   #684
I was wondering about that. Their fans seem to do OK though.
drivejumpfly is offline   Reply With Quote
Old 03-30-2016, 10:16 AM   #685
Put the rear spool in last night and switched out the 40t hpi bevel gears to the Ultra lightweight machined alloy Exotek diff gears there so much lighter and well constructed over then the stock hpi bevel gears. Going to run just one spool and go from there.
Remaining mods this week the hpi aluminum shock upgrade build, 70t Robinson Race Spur, hpi carbon towers / bumper brace, carbon center drive shaft cover/chassis stiffer.
HPI RS4 Sport 3-20160329_162935_resized_1.jpg   HPI RS4 Sport 3-20160329_160054_resized_1.jpg
Old 03-30-2016, 08:45 PM   #686
GPM has just released their aluminum lower arms. They appear a little more bulky (as usual) than the Yeah Racing.
Old 03-31-2016, 11:56 AM   #687
I've ran a list out of modifications below for those that might be interested. Every part is finally installed on the car. The mods went on super smooth with the Rs4 Sport 3 Flux.
Here's a breakdown with pricing..
Yeah Racing Kit: $85.49
•Yeah Racing Aluminum Front Lower Arm Set For HPI RS4 Sport 3 Orange #RSS3-001OR
•Yeah Racing Aluminum Rear Lower Arm Set For HPI RS4 Sport 3 Orange #RSS3-002OR
•Yeah Racing Ball Bearing Aluminum C-Hub Set For HPI RS4 Sport 3 Orange #RSS3-003OR
•Yeah Racing Aluminum Front Knuckle Arm Set For HPI RS4 Sport 3 Orange #RSS3-004OR
•Yeah Racing Aluminum Rear Hub/Knuckle For HPI RS4 Sport 3 Orange #RSS3-005OR
•Yeah Racing Universal Shaft Set For HPI RS4 Sport 3 Orange #RSS3-006OR
•Yeah Racing Aluminum Ball Bearing Steering Arm Set For HPI RS4 Sport 3 Orange #RSS3-007OR
Exotek:
Exotek Turnbuckle Set #1569 $21.95
Exotek Alloy Drive Shaft # 1540 $16.95
Exotek Alloy Dif Gear Frt 7075 #1574 $9.95
Exotek Alloy Diff Gear Rear 7075 #1574 $9.95
Exotek Spur Gear Alloy Mount # 1541 $13.95
Exotek 1 pair Pro5 12mm clamping hex #1551 $13.95
HPI Option Parts
LXFRAC HPI Racing Center Drive Shaft Set Carbon Fiber Sport 3 $34.99
LXFRAD HPI Racing Shock Tower Front Carbon Fiber Sport 3 $21.99
LXFRAE HPI Racing Shock Tower Rear Carbon Fiber Sport 3 $21.99
HPI Racing 40T Spool Set Sport 3 2 $37.98
LXFNAB HPI Racing Aluminum Shock Set (4) Sport 3 $37.99
LXBTVE Hot Bodies Graphite Bumper Brace $17.29
The following will be placed on back order
These items will ship when available
LXFRAF HPI Racing High Speed Gear Set Sport 3 Out of stock, back ordering 1 $15.99
HPI Racing Porsche RSR alloy wheel Nuts # 109504 $23.54 (With stock hpi wheels)
Castle Creations 1/8th Brushless Motor Cooling Fan $11.14
Robinson Racing Spur Gear 48P 70T $8.00
Hpi foam wheels - Unavailable discontinued
Old 03-31-2016, 12:40 PM   #688
Thumbs up
Where are you ordering all these parts from? Especially shock upgrade and hpi carbon towers ?
Edit: NVM just noticed your parts list with part #'s
Michal006 is offline   Reply With Quote
Old 04-02-2016, 02:40 PM   #689
ignomirello's Avatar
Default Not enough traction
Help My setup has to much power. How can I get all the power to get traction? I know I can't go full throttle and expect to have traction. But when i'm half into the throttle & try go go FULL THROTTLE it just kicks sideways. What changes can I make without losing power? Is there better tires then the original tires? Softer tires for ash-fault? Higher gears? Please help
ignomirello is offline   Reply With Quote
Old 04-02-2016, 03:41 PM   #690
Sounds like you need a good tune with a Castle Link programmer.
If you have a Castle Creations system (HPI Flux) the Castle Link is invaluable.
