Like Tree8Likes
Old 12-27-2015, 02:11 PM   #496
fyrstormer's Avatar
I'm sure the gearing is identical front-and-rear. Probably either 13/38 or 14/36, those are pretty standard across all of Hobbico's brands.
fyrstormer is offline   Reply With Quote
Old 12-27-2015, 07:33 PM   #497
Bought this car over the weekend. Quality seems decent but having some issues with one of the front wheels after a day of use. When I tighten the front left wheel all the way (to the point that there is no wobble) there is a ton of resistance along with a clicking sound when it rotates. The axle shaft rotates free and smooth in all conditions with the wheel removed. The wheel also rotates progressively smoother as i loosen the wheel nut.
Any suggestions on what to replace that could be causing this?
GripSpec is offline   Reply With Quote
Old 12-28-2015, 09:29 AM   #498
Unhappy rs4 not moving
hello all, I am new to rc and just bought an rs4 sport 3 flux, the first week i destroyed my gear mesh since i wasnt aware of adjusting the motor, now I took it out for the second time and after running it for about an hour the reverse wouldnt work, now it wont even move, I can steer the car and i hear the esc fan moving, but the car wont go forward, the motor makes no noise what so ever so it is not moving, I dont think the motor burnt, its too new. Any ideas? has anyone experienced this with this model. Thanks again all
gabe21946 is offline   Reply With Quote
Old 12-28-2015, 05:15 PM   #499
Check where the wires plugged into ESC. Had few Hpi vehicles that wires came loose. Are any lights flashing on ESC. Never had a problems with gear mesh when I had mine. Had other issues.
Billy Kelly is offline   Reply With Quote
Old 12-29-2015, 08:50 AM   #500
Thanks for the reply. I initially took a look at the wires, but did not see anything loose. I may have to take the ESC out to get a better look and confirm if this is indeed the case. Also, I wasnt aware the ESC had any lights, I will have to take a look and confirm if i see any lights. Thanks again for the comment. I will provide an update once i take a look.
Old 12-29-2015, 06:01 PM   #501
Originally Posted by bryangrizzlyohi View Post
doe anyone know the gearing of cars front an rear im gonna be using this as a indoor stock rtr class to run
Hpi parts list shows diff internal gears are 16t and spiders are 10t outer are 40t and 13t
Beef is offline   Reply With Quote
Old 12-29-2015, 07:24 PM   #502
MikeR's Avatar
Trader Rating: 15 (100%+)
Originally Posted by GripSpec View Post
Bought this car over the weekend. Quality seems recent but having some issues with one of the front wheels after a day of use. When I tighten the front left wheel all the way (to the point that there is no wobble) there is a ton of resistance along with a clicking sound when it rotates. The axle shaft rotates free and smooth in all conditions with the wheel removed. The wheel also rotates progressively smoother as i loosen the wheel nut.
Could be the plastic 12mm hex is deformed and now pressing against the bearings when the wheels are tightened? Try moving hexes to the opposite side of the car and see if it repeats the problem there.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 12-30-2015, 09:02 PM   #503
So basically no other wheel and tire combo will fit with the stock body?
Been running mine on the street. I had the rocks lodge the steering but otherwise it's been good so far. The x pattern tires you guys are running I guess are on standard wheels and tucked under the porsche body?
Dragonfueled is offline   Reply With Quote
Old 12-30-2015, 09:25 PM   #504
fyrstormer's Avatar
HPI makes several Porsche bodies. I like the 200mm GT3 RS body. Buy one, trim and paint it, and use normal 1.9" wheels and tires. Here's what mine looks like:
Old 01-01-2016, 06:38 AM   #505
Had a few runs with mine and destroyed the stock servo gears. Just put a spektrum s6070 in but had to trim some of the plastic off of the mount due to where the wires come out of the servo. I had problems keeping this thing tracking straight. Can someone recommend a turnbuckle kit that I can put on this?
midas is offline   Reply With Quote
Old 01-01-2016, 09:32 AM   #506
Default tracking
I had the same issue with mine tracking as well. I upgraded my transmitter to the futaba t3pl, an let me just say its night an day on handling, I was gonna go with the spectrum dx4c but ran into the issues you was talking about on having to trim the plug in. so opted a lil more cheddar an went with the futaba.. by the way the receiver in the hpi is a futaba.
bryangrizzlyohi is offline   Reply With Quote
Old 01-01-2016, 11:16 AM   #507
First thing I did when I got it was switch the reciever to use my dx4s. Much better response, but the tracking issue I am having is related to how loose the front steering components are at the front end.
Old 01-01-2016, 11:19 AM   #508
What wheels/tires did you put on there?
Old 01-01-2016, 11:19 AM   #509
ive not had that issue but I have had the dog bone issue but I solved that by putting some fuel tubing in the hubs...
Old 01-03-2016, 01:46 PM   #510
Check out Exotek, they got have some upgrades for the rs4 now, adjustable set of turnbuckles and an alloy diff gear are new.
http://www.exotekracing.com/rs4-sport-3-turnbuckle-set/
