ESC Quits in a crash
Hi i have a lrp Q c 2 ...
when i have a crash, the ESC seems to quit on me. the battery is still connected coz my transponder light is still on and also my steering servo still operates.... however when i push the throttle it does nothing except the motor make a small noise... (similar noise to that when you set your esc) i have to shut disconnect the battery and then plug it back in again... and then it may work..... this only seems to happen after i have a bit of a tumble... any ideas? thanks |
something may be slightly bent or broken inside the speed controller and is getting thrown around inside when u have a crash causing something to arck nad the speed contreoller shuts itself down. Have a look inside if something is lose see if you can fix it if not it might be a new speed controller for you.
ESC doesn't make noise, motor does.
Check your motor too, maybe the brushs are not seated properly after crashes. |
Check your motor too, maybe the brushs are not seated properly after crashes. u prob right there, it was an old 540 motor. i just chek the brushes and on one side its worn all the way thru :weird: |
Originally Posted by qwerty
any ideas?
im guessing it is time for a new motor.
