What rubber tires are working good on carpet >
Old 10-22-2005, 08:12 PM
Default What rubber tires are working good on carpet
Our local track has some new CRC carpet, and a group of stock racers are wanting to stop using foams and start running rubber. Can you give us some advice on what tires and inserts are working.
Beau
THE GOOCH is offline
Old 10-22-2005, 08:20 PM
Yeti35's Avatar
CS27's work well on carpet, they were the control tire in LV at IIC. Just get premounts no need to worry about inserts that way.
Yeti35 is offline
Old 10-22-2005, 08:22 PM
Sorex 28's and HPI red medium inserts
R/C Anonymous is offline
Old 10-23-2005, 05:18 AM
Big Daddy Boomer's Avatar
Cs-27's give you the best bang for your buck. Economical and easy. strap em' on and go! That is all we use at Trackside Hobbies in Milwaukee (Scotty's place/IIC)
Boomer
Big Daddy Boomer is offline
Old 10-23-2005, 12:38 PM
Revs's Avatar
My favourite rubber tires for carpet at the moment are cs22s, they grip very well with some addative.
Revs is offline
Old 10-23-2005, 04:45 PM
Do you scuff these tires to start out with, or before every run, or just take them out of the package and run them?
Old 10-23-2005, 05:24 PM
i always just threw them on the car...added tire traction and went to town...takes a couple laps the first time to scuff them up...my car always pushed more then usual till they got scuffed in
Old 10-23-2005, 08:02 PM
Yeti35's Avatar
In LV I took a sanding drum to them with my dremel and scuffed the center to get rid of the mold seam. They worked fine this way. Only other way I would have done it is mount them then take them outside and scrub them on the sidwalk. That was not an option in LV.
Yeti35 is offline
Old 10-23-2005, 08:05 PM
axel's Avatar
how do rp24's compare to cs27's?
axel is offline
Old 10-23-2005, 11:44 PM
Roger's Avatar
The 24 RP's will heat up quicker than the CS27's. Stick to CS27 up front and CS22's in the rear.
Roger is offline
Old 10-24-2005, 04:08 AM
Essnowyt's Avatar
NO Don't do that!!!! The life of CS-27 tires is really to short to do that. I start by wiping the mold release off with isopropyl alcohol. Then apply tire traction go to the track for one battery of practice. This will scrub the tires in just fine!
Snowy.
Essnowyt is offline
Old 10-24-2005, 04:22 AM
How many packs are a set of CS-27's lasting on carpet?
Old 10-24-2005, 05:06 AM
Anders Myrberg's Avatar
In Sweden, we use Sorex 28 for all indoor races. Have done it for some years, and everybody is happy. Works just great. Last quite long as well. CS seems to be good but quite uneven in quality/performance. Inserts are free, but all use JB thin blue inlays. Itīs just a very good combo. We only allow odorless additive and most use LRP.
Anders Myrberg is offline
Old 10-24-2005, 09:56 AM
kufman's Avatar
Serious racers say 2 or 3 runs, but at the club level we run these tires for weeks.
kufman is offline
Old 10-24-2005, 10:02 AM
RP 24 and RP 30 were used by Todd Hodge this past weekend to win the Region 12 Carpet Champs at Hobbyworld.
Tony Vega is offline
