Rubber Tires On Carpet >
Old 10-20-2005, 09:08 AM
thecrow2k's Avatar
Default Rubber Tires On Carpet
We run on carpet at our track, looking on the weeb I found I could buy a full sorex tyre set for $30, I was looking as my foams tend to be pretty much useless after 45runs in tamiya class, I understand rubbers would get less grip and I was looking at the sorex 24r tires, how many runs do you think I could get out of them.
thecrow2k is offline
Old 10-20-2005, 11:26 AM
thecrow2k's Avatar
Anyone?
Old 10-20-2005, 11:31 AM
OVA
OVA's Avatar
Trader Rating: 86 (100%+)
Originally Posted by thecrow2k
Anyone?
depend on how thick is your insert..
OVA is offline
Old 10-20-2005, 01:06 PM
thecrow2k's Avatar
The team sorex medium or firm insert
Old 10-20-2005, 05:06 PM
Joel Lagace's Avatar
Sorex 24s with hpi blue front and hpi green rear inserts is what i used to run in rubber stock sedan. Great grip fairly good lifespan.
But your going from foam to rubber? If your racing against foam cars you will be at a huge disadvantage. LEss traction and much more rotating mass,
Joel Lagace is offline
Old 10-20-2005, 06:42 PM
Stevietd14's Avatar
At our track a set(4) of Jaco's runs $30 and a set of Twister's runs at $24.If foam tires are cheaper,hook up a lot better, and get a lifespan close to rubber, I would stick with foams.
Steve
Stevietd14 is offline
