Like Tree1Likes
Old 04-17-2017, 06:51 AM   #106
Default Taller mount
Why don't you sand the mount pedestal down? Make it shorter. The rc monster mount is meant for larger speed run motors. If you want you can send the mount to me and I will machine it shorter for you on the mill so it is same height. I make several motor mounts here for the MGt7 and we typically keep the drive train close to the same level so there is no excessive pinion angle. You can email me at tjscustomrcs using gmail if you want and discuss taking a few thousandths off to level it out. I presume you have both halves to address the height issue or the spool would be crooked. We can set it at stock height or make a new one altogether. The top center mount (motor over spur) we make only leaves the motor an inch off the chassis. Enough room for the center shaft to clear and then the chassis brace is made to attach to the top of the motor mount. Keeps everything balanced and for those doing speed runs they can use batteries on each side of the chassis plate. Those racing have a better balanced setup for the track. You have lots of options with a one off custom shop like ours.
Originally Posted by Jlemieux View Post
Well since I already purchased the RCmonster mount is there a taller diff mount? Maybe the nitro version is taller ?
Uguessedit is offline   Reply With Quote
Old 06-13-2017, 10:55 PM   #107
Hey everyone,
I just got myself a Mugen MGT7 eco and started to wonder how big of a pinion i can use with the stock 44T diff and motormount. Can anyone tell me something about it?
I'm not into speedruns, its only meant for on-track racing.
Bartje81 is offline   Reply With Quote
Old 06-14-2017, 12:56 PM   #108
Originally Posted by Evo 13 View Post
Anyone know when Mugen will release the Mugen MGT7 super touring eco kit? From the pics, it looks good!!
Not sure what the biggest is, but within a tooth or two of what came with the car is more than adequate for on-road racing. I went down a tooth with a 2050kv motor and 4s battery. Check out the setups I posted earlier here. My friend from Brownville came up to NControl in Austin and did very well with that setup until he broke a wheel in the mail.
John Wallace2 is offline   Reply With Quote
Old 06-15-2017, 12:11 PM   #109
just curious of how you guys are measuring droop for this car I bought the Hudy blocks and droop guage but they are the large ones said for 1/8 scale buggy( too large) I used to have smaller ones when I had my 1/8 scale Evolva would those work need to get accurate settings for droop. we run a organized street course her in Northern Virginia. My car is leaning a lot in the corners and slowng me down gotta try something
LEMANS FAN 64 is offline   Reply With Quote
Old 06-15-2017, 03:09 PM   #110
FMI Where in NOVA are you racing?
Old 06-15-2017, 03:30 PM   #111
Manassas Virginia Osbourne high school
Old 06-15-2017, 11:40 PM   #112
I used to race with a converted RB e One R. The electronics i used where:
Hobbywing XR8 Plus
Hobbywing 2600kv G2
25T pinion
2x 7500mah turnigy ultimate 2S
I'm hoping this car will have a more stable rear end as the lipo's in the RB are all the way back in the car. I'm hoping i won't have to sacrifice too much top speed.. (thats why)
Old 06-17-2017, 03:47 AM   #113
25T pinion does not fit.. I can get it in but there is too less room to set a good mesh.. Now hoping a 24T pinion will give enough room for a decent mesh and will work..
Top speed would be about the same with a 24T pinion as the spur is 44T where i was used to 46T on the RB.
46/25=1,84
44/24=1,83
Old 06-17-2017, 07:41 AM   #114
Well, it works (25T pinion on stock diff) after some small modifications:
Drift_Buggy likes this.
Old 06-19-2017, 02:46 PM   #115
Hobbywing XR8 Plus
Hobbywing 2600kv G2
25T pinion
Just wondering what track you run your car on with a 25 tooth pinion? Stock is an 18 tooth and that was plenty for most big 1/8th scale tracks (e.g., now closed Brownsville) and even then they were only using ~80% of the 2600KV motor and were as fast or faster than the Nitro cars.
Old 06-19-2017, 03:45 PM   #116
The track of Groningen (The Netherlands)
Top speed with this setup is a theoretical 115kilometers an hour
Equals 71 mph:
2600kv = 2600 tpm /V
2600 x 14,8 = 38480 tpm
Spur 44T Pinion 25T:
38480/44 x 25 = 21863 tpm center drive shaft
FR-Diff spur 42T Pinion 13T:
21863/42 x 13 = 6767 tpm wheel axel
Wheel diameter 9cm
Outline 9 x pi = 28,27cm
6767 x 28,27 = 191332 cm/min
191332/100= 1913M/min
1913 / 60 = 31,89M/sec
31,89 x 3,6 = 114,8km/uur
Theoretical top speed 114,8kph
Old 07-13-2017, 04:56 AM   #117
schluppy's Avatar
I would recommend to measure like you can see in this picture. But you have to disassemble the sway bar and shocks before you get a good result.
schluppy is offline   Reply With Quote
