orca VX3 problems
orca VX3 problems
hi
I have problem with my orca VX3 esc
while on the setup board today it was flashing away blue light in blinky ok then it had a solid red while still flashing in blinkyand the motor would not run
any suggestions
any suggestions
Remove Set up Board. Then redo TX &ESC Set up for Neutral, Full Throttle, & braking. Beeping on ESC confirms the setting. Then install the Customize board to set up.
May of been low voltage in the Lipo, Try with a Fully charged Lipo
