Like Tree2Likes
Old 07-27-2015, 05:28 PM   #91
phildoggg's Avatar
Trader Rating: 24 (100%+)
Originally Posted by 0verkill View Post
Do you know how many amps you're pulling? And what amp rating is your motor and what battery are you using?
I have no idea the amps drawn. using turnigy nano-tech a-spec 4250 65c. 4s
phildoggg is offline   Reply With Quote
Old 07-27-2015, 05:29 PM   #92
phildoggg's Avatar
Originally Posted by tc4basher View Post
http://youtu.be/XlyOYMAfnNs
Finally broke i to the 130's with my TC4. Check out thiis short vid
http://youtu.be/vPCZcLKwR1k
Heres a slow mo vid.
congrats!! I've moved mine over to the tc5 to play around with. nothing impressive yet..
Old 07-27-2015, 11:09 PM   #93
Thumbs down
Im sure your tc5 will be just as fast if not faster. Im still waiting on my Neu motor. Its been 6 wks since I ordered it. They said they are still waiting on a stator. Maybe I should have went with Cordova. Probably would have been here by now.
tc4basher is offline   Reply With Quote
Old 07-28-2015, 10:00 AM   #94
Check out TP Power as well. They make very powerful motors and they're a lot cheaper than Neu.
0verkill is offline   Reply With Quote
Old 07-28-2015, 12:46 PM   #95
I have considered TP motors but I have never seen anyone go fast with one. Have you had any good results?
Old 07-28-2015, 03:09 PM   #96
phildoggg's Avatar
I've seen a couple builds with them but usually 1/8 scale. the quality seems good. Stick with neu you will be glad you did..
So what did you change to break 130?
Old 07-28-2015, 05:04 PM   #97
Im currently running the Leopard 3665 2680kv on 2 Nano Tech A Spec gen 1 4500 mah 3s (6s). Geared 49/45. The motor gets only a little warm after each pass. I want to gear up more but these gears are litterally the smallest spur and biggest pinion Robinson racing makes. Still trying to figure out how to gear higher.
Old 07-29-2015, 08:09 AM   #98
Yes, I've had really great results with 2 of their motors. I have a 40x102mm in my 1/8 truggy and it's a beast. I don't have any data logs yet and I haven't run it on 8S yet. I'm waiting for Castle to release their new XL X ESC.
Tekno ET48 Build - TP 4070
Old 07-29-2015, 02:57 PM   #99
phildoggg's Avatar
contact rw and get a steel spur gear made. in 32 pitch.def. the way to go.
Old 07-29-2015, 03:27 PM   #100
Racermac73's Avatar
Custom works makes a adapter so you can use a spur gear for a pinion
TEAM SCREAM, McFACTORY, TQ WIRE, 360 RACEWAY, XENON-USA.COM, SANWA, DESOTO RACING, JFT TIRES, HOBBYWING, EAM, DESTINY USA, DRIVE RC, TOP USA
Racermac73 is offline   Reply With Quote
Old 07-29-2015, 10:18 PM   #101
Thanks for the tips fellas! Looks like RW has a 45t spur that would get my FDR down to 2.5 with the 45t pinion on there right now.
Old 12-02-2015, 09:51 AM   #102
Default TC4 speed run 137 moh
Bringing back an old post, Have any of you guys made recent speed runs? I have been running a TC4 with mamba max pro/5700kv. With 3s have gone 100mph on 55/43 (3.19) FDR. 4s managed 107 mph not fully opened up. What bodies has anyone had good luck with? Thanks
onroader1 is offline   Reply With Quote
Old 12-02-2015, 03:43 PM   #103
phildoggg's Avatar
I know i have made runs, and tc4 basher has also . they are on our youtube pages. check out the speed thread in here has some good videos. I ran 99mph on 2s. few weeks ago.. but bodies i like mccalister bodies, i have 2 different bodies. tc4 basher will chime in im sure on what he runs. also to go fast i reinforce my bodies with fiberglass as the will deform at high speed..
Old 12-03-2015, 11:53 AM   #104
https://youtu.be/f84CGrUa28A
https://youtu.be/u9G9nMQX-Hk
Here are a couple of my most recent tc4 speed run videos. My hardened steel rear diff broke on me at 124 mph this past Sunday. I lost brakes and coasted into a curb. It needs some repairs.
The body I run is a HPI FI McLaren that has also been reinforced.
Your speeds with the 5700kv mmp sound about rite. I had the same setup in my TC4 before and ran very similar speeds. Keep at it!
Old 12-03-2015, 12:50 PM   #105
Default Speed run TC4
I checked out the you tube videos, Nice runs. So Philldoggg, and Tc4basher you are both in the 130s? What are the current limitations for you guys now? Out of Battery, motor power, gearing topped out, or just staying on the ground?
