Like Tree2Likes
Old 05-29-2015, 05:23 PM   #76
phildoggg's Avatar
Trader Rating: 24 (100%+)
will do just let me get it back together.
phildoggg is offline   Reply With Quote
Old 05-30-2015, 02:27 AM   #77
Sound good. Hope you get her back on the road soon!
tc4basher is offline   Reply With Quote
Old 06-08-2015, 11:34 AM   #78
Default New personal best-128 mph
I did a few tweaks to the tc4 including: slightly decreased the front toe, replaced a missing grub screw from the front sway bar, changed the 40wt shock oil to 80wt, and raised the timing from lowest to highest.
Did 2 passes yesterday. The first pass the car was running over some pebbles and small twigs at the end of the track and was bouncing around and hit 123 mph.
I then went and swept all the pebbles and twigs to the side of the rd and made another pass and hit 128 mph!
The car goes much straighter now. Probably the straightest it's ever gone. I was thinking about doing one more pass but I decided to quit while i was ahead haha.
I'm coming for Phildoggg!! Lol jk.
Old 06-08-2015, 05:02 PM   #79
phildoggg's Avatar
Nice!! 128 is moving .. You are well on your way to 130 just keep at it.
Old 06-08-2015, 05:10 PM   #80
Thanks Phil. Its kinda crazy how fast these little things can get with just common off the shelf parts. I only got back into RC less than a year ago after at least 6 or 7 years and I had no idea electric had gotten so advanced.
Heres a couple pics I snapped yesterday. Man I need a new body! lol. But hey......Function>Form
Old 06-09-2015, 02:56 PM   #81
phildoggg's Avatar
[IMG][/IMG]
mine..
Old 06-09-2015, 09:30 PM   #82
[IMG][/IMG]
mine..
Nice Phil! I like the front splitter. Looks like your running toe out in front? No weights in front?
Only thing missing is a Cordova motor lol jk
Old 06-10-2015, 02:04 PM   #83
phildoggg's Avatar
Yeah a little toe out, makes it easier to steer. Not really a splitter it goes under the body and seals it. Thanks.. I may go cordova one day soon..
Old 06-10-2015, 03:56 PM   #84
Mite have to try some toe out. So no weights? I wouldnt even attempt a speed run without weights on my car. Too many blowovers in the past with this little car. But maybe the "splitter" of yours does just as a good a job?
Old 07-14-2015, 04:07 AM   #85
https://www.youtube.com/watch?v=ktIefcxlV94
check it out and subscribe if you like speed runs. thanks.
Nice speed! I'm curious what your "calculated speed" is in order to run 137mph? Using this calculator - http://www.scriptasylum.com/rc_speed/top_speed.html
0verkill is online now   Reply With Quote
Old 07-14-2015, 05:10 PM   #86
phildoggg's Avatar
Differential Ratio: 2.5
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 36
Pinion Tooth Count: 30
Total Voltage: 12
Motor KV: 6700
Tire Diameter (inches): 2.5
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor Coil Resistance: 0
Spur/Pinion Ratio: 1.2 : 1
Total Ratio: 3 : 1
Tire Circumference (inches): 7.85 inches (199.49 mm)
Rollout: 2.62:1
Total Motor Speed: 80400 RPM
Vehicle Speed: 199.32 mph (320.18 km/h)
Effective KV Value: 6700
KT constant: 0.2 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
that is using 3v/cell..
Old 07-14-2015, 07:34 PM   #87
Does the front splitter make a difference ?
illmatic94 is offline   Reply With Quote
Old 07-15-2015, 04:50 PM   #88
phildoggg's Avatar
Mine isnt a splitter, it takes up the room from the bumper to the body and keeps the air out of the front.
Old 07-27-2015, 08:41 AM   #89
Do you know how many amps you're pulling? And what amp rating is your motor and what battery are you using?
Old 07-27-2015, 11:57 AM   #90
http://youtu.be/XlyOYMAfnNs
Finally broke i to the 130's with my TC4. Check out thiis short vid
http://youtu.be/vPCZcLKwR1k
Heres a slow mo vid.
