Like Tree2Likes
Old 05-11-2015, 08:39 AM   #16
phildoggg's Avatar
Trader Rating: 24 (100%+)
Nice work TC4basher! good pick up in speed .. you run droop screws?how is your ride height?
phildoggg is offline   Reply With Quote
Old 05-11-2015, 11:46 AM   #17
Thanks PHILDOGGG! I got my droop setup for ride height at about 9mm front and 11mm rear.
The car wasnt going that straight on the 124mph pass so I let off kinda early. I was very surprised that it still went that fast.
I just got my 2 degree rear toe block. I only need the one rear toe block or do I need the middle rear one too?
I'm also waiting on some 6 degree caster blocks.
Hoping to make the car go straighter before more speed runs this weekend.
tc4basher is offline   Reply With Quote
Old 05-11-2015, 03:01 PM   #18
phildoggg's Avatar
just the 2 deg. is all. and yes 6 deg caster should help with steering..
Old 05-11-2015, 04:52 PM   #19
Thanks man. Just another few days of fine tuning until this weekend's speed runs since the road I use has a bit too much traffic on weekdays.
Is there any other 36mm motors out there besides the NEU that would be faster than my 7700kv?
Old 05-12-2015, 09:22 AM   #20
Please could you let me know the advantages/disadvantages of belt and shaft driven vehicles for speed runs.
cbs007 is offline   Reply With Quote
Old 05-12-2015, 12:46 PM   #21
I have had bad experiences with belts because they can snap at anytime. Especially at very high speeds. Little pebbles and debris will also destroy belts. Belt pulleys also wear down very fast.
The only advantage I can think of for belts is that they run quieter and smoother.
I will never run a belt drive car again.
Old 05-12-2015, 05:36 PM   #22
phildoggg's Avatar
also belt drive has lower ratio for higher gearing.
Old 05-12-2015, 05:38 PM   #23
phildoggg's Avatar
Tc4basher what kind of budget are we talking about? leopard motors are pretty good quality. try a 3660 can. I'll look.
http://www.valuehobby.com/power-syst...-inrunner.html
just gear up..
Old 05-13-2015, 10:28 AM   #24
What does lower ratio for higher gearing mean?
Please correct me if I'm wrong, but this is what I understand. Say, I'm using a 35T pinion and 60T spur on both the belt driven and shaft driven car, then the final drive ratio of the shaft driven car will be lower. Is this due to a lower transmission and/or differential ratio in a shaft driven car?
Old 05-13-2015, 10:33 AM   #25
And is there any reason why I see custom built Speed run cars running a belt drive (for example:https://www.youtube.com/watch?v=96OBzDI1ZIM&safe=active)
Old 05-13-2015, 11:54 AM   #26
Yeah you got it about rite. I'm not saying speed cars cannot be belt drive but i think most of the time they will need stronger, upgraded belts and pulleys.
Old 05-13-2015, 11:57 AM   #27
just gear up..
I was looking at that leopard motor before and I think I would probably need to run 6s to get it faster than my 7700kv on 4s?
I will probably eventually get the NEU motor but I guess I'm not quite ready to pull the trigger on a motor that cost more than the car haha.
Right now im running 43/52 gearing which puts me at 3.02 FDR. Should I try a 45t pinion (2.88 FDR)?
Old 05-13-2015, 12:53 PM   #28
Any opinions on the Xray T3/T4. It has a 1.9 transmission ratio and would result in a 2.85 FDR with a 40T pinion and 60T spur.
Old 05-13-2015, 12:54 PM   #29
Is the 7700kv motor the castle 1406 series?
If yes, are you having any heat issues since the manufacture says 2S LiPo max.
Old 05-13-2015, 01:28 PM   #30
Yes the motor is a 1406 series which gets hot fast whether its on 2s or 4s. I let the car sit and cool with the fans blowing for at least 3-5 mins between speed runs.
If the motor is really hot or I want it to cool down even faster then I'll rest it on my dashboard of my SUV with the motor directly above a vent with the AC blasting and it cools much faster.
