Old 05-20-2016, 04:12 PM   #106
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
Hope all the G Force fans out there have a great time racing this weekend!!!!
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 05-22-2016, 04:00 AM   #107
@nikos2002, sent you a PM with more info about my esc, did you receive it??
Bob
Dadsrace2 is offline   Reply With Quote
Old 05-22-2016, 11:31 AM   #108
Airwave's Avatar
G-force users, be careful with the fans, I had a small short circuit this week-end with the program pins (damaged servo cable to connect the program box) and it instantly killed the ESC...
Airwave is offline   Reply With Quote
Old 05-24-2016, 03:20 PM   #109
nikos2002's Avatar
"Damaged servo cable to connect to program box" - that doesn't sound right -- connecting a damaged anything with an esc has the chance to hurt it. No matter the brand.
Nick Malato
Old 05-25-2016, 04:24 AM   #110
Airwave's Avatar
Indeed, but the "programmation" circuit is not protected again short-circuit. That's often the case on other ESC.
My point is to be prudent when you are using this port to connect a fan...
Old 08-28-2016, 09:31 PM   #111
RoyB's Avatar
Trader Rating: 16 (100%+)
I am going to use motor analyzer to check a 17.5 motor that will be used with 1s batttery in a pancar. Since the analyzer needs a 2s battery to work what amp draw should I set it for?
RoyB is offline   Reply With Quote
Old 08-28-2016, 11:25 PM   #112
MontanaMaxx's Avatar
What analyzer you using?
MontanaMaxx is offline   Reply With Quote
Old 08-28-2016, 11:38 PM   #113
RoyB's Avatar
SKYRC
Old 09-14-2016, 03:43 AM   #114
Hi , I have g-force ts120 aluminium case version with lastest firmware, it run smooth but there are few punch settings (only 5), I 'd like to have maybe 9
Nicola1024 is offline   Reply With Quote
Old 09-14-2016, 02:19 PM   #115
Airwave's Avatar
I just encounter a new problem on my other TS160... It seems that no matter what I do (change the sensor cable, change the motor, change the battery, change the setup in the ESC, flash it, recalibrate it, reset it), my ESC is unable to generate nor boost timing neither turbo... It's running in blinky mode...
Does it sound familiar to anyone? What can I do?
Old 09-14-2016, 07:57 PM   #116
You're running in Blinky - this is a zero timing mode. You're not meant to be able to add boost or turbo when running blinky mode.
Try changing to a different mode
On-Road - Xray T4'17 / Serpent 4-X / Tamiya Exo6 / Roche P10 & P12 & F1
4WD - Kyosho ZX6 / Yokomo YZ4 *** eBuggy - Tekno EB48SL
2WD - AE B5M (XFactory Chassis) / Kyosho RB6 / TLR 22 2.0 / Yokomo YZ2
SCT - Tekno SCT410 / Losi 22SCT 2.0
ST - Losi 22T 2.0
WagwanBumba is offline   Reply With Quote
Old 01-20-2017, 10:45 AM   #117
My g6p charger just died on the 240v side and still works on the 12v power supply side.
Anybody out there repaired theirs and knows what needs to be done
Cheers
Mi4cxl is offline   Reply With Quote
Old 01-20-2017, 10:56 AM   #118
Andy63's Avatar
You can try downloading the 1.08 version firmware to get 1-30 in punch settings.
Cheers// www.andrefossto.wordpress.com
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 01-20-2017, 04:29 PM   #119
nikos2002's Avatar
Cheers
Check your PM.
Nick Malato
Old 01-21-2017, 10:19 AM   #120
Replied thank you.
