Old 11-24-2015, 01:46 PM   #91
Ivan Dickson's Avatar
Trader Rating: 11 (92%+)
Thumbs up
Originally Posted by EDWARD2003 View Post
Bought the setup station and works like a treat! Highly recommended.
Yes I totally agree!! very accurate
SPECIAL THANKS TO ✦ MY WIFE ✦✦ MOTIV RC ✦✦ GRAVITY RC ✦✦ JGO PAINTZ ✦✦ TQ RC RACEWAY ✦✦ TAMIYA RACEWAY ✦
Ivan Dickson is offline   Reply With Quote
Old 11-25-2015, 03:56 PM   #92
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
Tell your friends!!!!
If you look around you can find some cool G Force stuff on Doorbuster sales for Black Friday!!
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 12-13-2015, 04:13 AM   #93
etgdpu's Avatar
Default windows 10 usb link connection problem
Hello,
Has anyone found a solution for the usb link software, which does not work in win 10?
Thanks in advance,
The intelligent can become anyone, anyone can not become intelligent.
etgdpu is offline   Reply With Quote
Old 12-19-2015, 12:19 AM   #94
nikos2002's Avatar
Originally Posted by etgdpu View Post
Hello,
Thanks in advance,
They have never given us a direct answer on Windows 10. Still trying to make sure everything is working as planned.
Nick Malato
Old 12-19-2015, 11:13 AM   #95
DBM
Found the weight of the 17.5 super extreme. They weigh 167g.
DBM is offline   Reply With Quote
Old 12-20-2015, 02:46 PM   #96
nikos2002's Avatar
UPDATE -- work is they are working on Windows 10 updates for the software, should be posted some resolution soon.
Nick Malato
Old 12-20-2015, 07:17 PM   #97
Logi Maker's Avatar
Trader Rating: 49 (100%+)
New Axis pit light is super dialed. Just need to tighten up the hinge points and it is money...
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 12-21-2015, 06:05 AM   #98
DARKSIDE's Avatar
yeah I had to do the same...2 minute fix, and it works great....and it seems to be pretty durable...Ive got to travel with it lately and have dropped it twice....once on the table and another on concrete floor....no scratches or nothing....
I really like the products they are putting out
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
2017 U.S.VTA+ Southern Nationals in Music City U.S.A.
Sept 21-24th @ Thunder RC Raceway
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 12-21-2015, 10:09 PM   #99
nikos2002's Avatar
Thanks Darkside - will pass on the kind words!!
Nick Malato
Old 01-17-2016, 04:48 AM   #100
alecladanga's Avatar
@nikos2002, sent an email requesting for ESC recommended settings for 17.5 blinky.
Many thanks.
Regards
Alec
alecladanga is offline   Reply With Quote
Old 01-18-2016, 05:15 PM   #101
nikos2002's Avatar
Many thanks.
Regards
Alec
Yep - wrote you back - if you didn't get the email, send me a PM here.
Nick
Nick Malato
Old 01-18-2016, 06:34 PM   #102
Nick
Many thanks for the speedy reply Nick, much appreciated
Regards
Alec
Old 05-12-2016, 08:41 AM   #103
Up date on infoHi I have a G-force 120A 1S ESC with V208 sofware installed running in blinky mode with 13.5 motor & 1S battery. It has been working great, however, last time out after hitting the boards and being hit from behind it stopped working. When switched on I get 3 beeps in quick sucession? If I turn it off and back on again it will work until I use reverse then I get the same again? I have tried a reset via the program box but it is still the same. Steering works fine amd reciever works in another car. Any iders?
No Help on here??? Also should have said sensor lead has been replaced.
Dadsrace2 is offline   Reply With Quote
Old 05-12-2016, 02:37 PM   #104
Gforce products rock.
I've got the setup station and other bita. Quality is easily as good as hudy for less money. Plus the gforce g6p charger is a top piece of kit... That is all.
Mi4cxl is offline   Reply With Quote
Old 05-14-2016, 05:43 AM   #105
I've got the setup station and other bits. Quality is easily as good as hudy for less money. Plus the gforce g6p charger is a top piece of kit... That is all.
I agree with the setup station being really good. Really good quality machining and no slop.
However, I don't think the G6P isn't as good as we're led to believe. I've had 2 replacement units due to the AC internals failing. Each time, the 12v still worked from my battery but it no longer turned on from the wall. I never took each unit to the limit, and was simply charging a few packs pre-race while powering my tyre warmers.
After looking into things a little further, it turns out that the AC parts of the charger is it's achilles heel. I was told it's only a matter of time until they fail. Also, when listening to peoples recommendations about the charger, they told me it was a top spec charger that would reduce charge times, and accurately balance etc. In actual fact, the max power is around 130W. I changed to an icharger 308 duo recently, which can charge at 1300W from 2 outputs. Charging the same pack at 1c from storage took 20mins longer on the Gforce. The icharger can also discharge at a much higher rate, as the Gforce has a limit of 50W or 1a due to it's AC unit on the discharge function, meaning packs can take 2hrs to storage charge.
The advantage of the Gforce is the AC power and the numerous outputs on the rear of the unit. But as it's weak point of the unit, I'll be using a 12v supply and the icharger. Although half the price of the Muchmore AC charger, it's still a pricey unit. For the money I would have expected a more powerful charger, better suited to fast charging that can deal with the rigours and loads it's rated at.
Just my views on the G6P. I am however, hugely impressed with the Gforce motors.
JimboAMX is offline   Reply With Quote
