Old 10-30-2015, 09:15 PM   #76
nikos2002's Avatar
Trader Rating: 29 (100%+)
Send a message via AIM to nikos2002
All new stuff coming in.... great pit accessories for the indoor season.. get your Xmas lists together now!!!
Nick Malato
Spektrum Surface Product Manager
** www.spektrumrc.com - www.horizonhobby.com ***
Sponsored By: Spektrum RC, Horizon Hobby, TLR, Maclan Racing, J Concepts
nikos2002 is offline   Reply With Quote
Old 10-31-2015, 05:49 AM   #77
DARKSIDE's Avatar
Originally Posted by CamLS View Post
The Greek Force on road setup station looks nice but what sets it apart from the competition? It looks very similar to the Yeah Racing setup station, so just wondering what I'd benefit by going with a G Force model. Thanks!
I switched over to this setup station from my old one....I like it cause its less space, and alot quicker to put together. Its great so far.
I also got the new pit light, setup board, and stand.....all good quality and less space in my pit bag.
I highly recommend these products if you are looking for simplicity and less space. I will post a pic of my pit area with my new products.
https://plus.google.com/110031093043...ts/2xSYNArPdC5
Myron "BATTMAN" Kinnard
Team Associated/Reedy Powered/PROTOform
2017 U.S.VTA+ Southern Nationals in Music City U.S.A.
Sept 21-24th @ Thunder RC Raceway
1172 Park Ave, Murfreesboro, TN 37129
DARKSIDE is offline   Reply With Quote
Old 11-18-2015, 02:15 AM   #78
etgdpu's Avatar
Default TS 160 Firmware Upgrade
Hello,
How can we perform the firmware upgrade to the TS-160 ESC, using the wifi module and a smartphone?
Thanks in advance,
The intelligent can become anyone, anyone can not become intelligent.
etgdpu is offline   Reply With Quote
Old 11-19-2015, 07:16 PM   #79
nikos2002's Avatar
Originally Posted by etgdpu View Post
Hello,
Thanks in advance,
WiFi support is not designed for the TS160 that I have seen. The smartphone app can be used to changes settings on the esc's (TS120's, TS90). The to connect to PC to update firmware.
Old 11-19-2015, 08:22 PM   #80
Trader Rating: 32 (100%+)
Very nice!!!!!!
hobbs is offline   Reply With Quote
Old 11-20-2015, 04:03 AM   #81
etgdpu's Avatar
Hello and thanks for your reply.
Where is the procedure for the firmware upgrade described, for the compatible units?
Old 11-20-2015, 06:53 AM   #82
DARKSIDE's Avatar
Originally Posted by hobbs View Post
Very nice!!!!!!
thanks...so far its working out really well....easy to setup and take down and you save a ton of weight and space.
Old 11-20-2015, 08:20 PM   #83
nikos2002's Avatar
Firmware upgrades are done via the Progbox - info can be found here:
http://www.gforce-hobby.jp/products-en/G0017.html
Nick Malato
Old 11-20-2015, 08:37 PM   #84
vabroom's Avatar
Nikos
The O-rings on my setup cracked and broke apart. Can't get an accurate measurement on them. Do you happen to what size they are?
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 11-20-2015, 08:40 PM   #85
nikos2002's Avatar
Originally Posted by vabroom View Post
Nikos
I can try and find out..... can you PM me or email (nick.malato@hobbyauthority-dist.com) me a picture.
Nick Malato
Old 11-21-2015, 02:57 PM   #86
DBM
What are the differences between the two motors? One is a higher kv, the other more torque biased? Is the difference just in the 12.3mm vs 12.5mm rotor, or do they have different stators, too?
Also what are the weights on the 13.5t and 17.5t motors?
I'm interested in trying one of these motors, but would like a bit more info to help me with my decision.
Thanks!
DBM is offline   Reply With Quote
Old 11-23-2015, 11:44 AM   #87
nikos2002's Avatar
Thanks!
They never gave us the weight information - will have to look into that for you.
As for the differences - the Super Extreme is a complete new designed looking to match the higher RPM output that is being designed into many spec class motors now a days. Also the motor was designed around possibility of using higher timing settings on the can, another thing popular with newer motors of this class.
Nick Malato
Old 11-23-2015, 02:51 PM   #88
DBM
Thank you for the reply. I am currently using Trinity D4ss motors in my 17.5 stock touring car and 13.5 12th stock car, and am looking to try something different without adding weight if possible.
Old 11-23-2015, 07:40 PM   #89
EDWARD2003's Avatar
Bought the setup station and works like a treat! Highly recommended.
Check out my YouTube channel for 1/12th scale and 1/10th Touring maintenance tips!
YouTube Search https://www.youtube.com/c/EdwardPickering?gvnc=1
                 VBC 12M - D08 - FX
EDWARD2003 is offline   Reply With Quote
Old 11-24-2015, 07:49 AM   #90
DARKSIDE's Avatar
ditto
